Flat Mount Location
Port
Quoted: 983 Post(s)
Liked 1,861 Times
Flat Mount Location
Quick question...
Is the location of the mounting holes for flat mount disc brakes universal? Ie are the holes mounted in the same place regardless of the size of the rotor? Or are 140mm rotor mounting holes in a slightly different location than for 160mm?
thanks!
thanks!
Likes For Rocket-Sauce:
Quoted: 321 Post(s)
Liked 263 Times
Good question. I would hope it's standard and that the offset you need for a particular size of disk is built into the caliper.
But it's not like the bike industry to miss an opportunity for creating new and surprising sources of incompatibility to catch us all out so nothing would surprise me.
Randomhead
Liked 3,696 Times
My understanding is that there is only one location and there are adapters. Maybe that will change as companies unwisely adapt it to mountain bikes.
What size rotor do you want to use?
Likes For dsaul:
Port
Quoted: 983 Post(s)
Liked 1,861 Times
I ask because I am having a frame built and got a call from the assembler telling me that he didn't know I ordered 160 rotors but they built the frame for 140 in the rear so they need to take the rear stays apart to reinstall the proper mounts....
I am using Campagnolo Record which have different calipers for 140 and 160 and have an adapter for going from 140 to 160.
Still confused by this.
Randomhead
Liked 3,696 Times
Doesn't sound like they know what they are doing.
Likes For unterhausen:
Quoted: 4201 Post(s)
Liked 3,857 Times
I wonder if the builder is actually referring to the rotor/stay clearances and not the caliper mounting points. But I agree with Eric in the suggestion that the builder isn't on top of the game. At the least he didn't get a final components being used spec hammered out PRIOR to cutting any metal. This isn't exactly surprising or a new problem. Poor business practices are as equally common as poorly fitted bikes are. Andy (who has only two disk bikes under his belt and was glad all the parts were in hand each time.)
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
Quoted: 103 Post(s)
Liked 144 Times
My understanding is that you need an adaptor to take your 140 mounts to 160 rotor. Does it make sense to go to 140 discs? A lot less painful than re-doing the rear end and more than 140 on the rear is generally excessive anyway for the road/skinny tires.
https://www.flickr.com/photos/54319503@N05/
https://www.draper-cycles.com
Randomhead
Liked 3,696 Times
the adapter does move the caliper up a little more than it moves it forward. It's wedge shaped though, with the thick part in front. I could see the caliper possibly hitting the seat stay if there was very little clearance.
Quoted: 321 Post(s)
Liked 263 Times
Sunshine
Quoted: 10955 Post(s)
Liked 7,484 Times
Set the flatmount at 140mm, use the adapter, and move on. I wouldnt think twice at that.
Quoted: 714 Post(s)
Liked 800 Times
I know of no 160 flat mount dropout currently available and there is no fixture available to place mounts in a 160 position. The only possible issue is not enough clearance to the seatstay for the caliper or the rotor.
Likes For dsaul:
Randomhead
Liked 3,696 Times
From what I have seen, not everybody is using a fixture (that we know about anyway). So far my opinion of flat mount is that it's kind of evil and no production company seems to be able to get the rear positioned properly unless they use a dropout with it built in. Even the carbon builders have problems with it. I haven't seen any frames from the custom metal framebuilders, but experience says it's probably hit or miss from many of them too.
Quoted: 714 Post(s)
Liked 800 Times
I'm not a fan of the flat mount, but its where the industry is going. The rear calipers are a pain to mount and adjust, because the bolts go in from underneath the chainstay. The front is a better system and I'd like to try it on the rear. The brake could then be mounted with a pair of M5 bottle bosses.
Randomhead
Liked 3,696 Times
I think the rear needs to be redone. It just doesn't make sense to have two giant holes in a chain stay.
I agree about the front though, for a steel fork it seems ideal. But a lot of people like more reinforcement up there.
Campagnolo has frame and fork location specifications for their disc brakes. They are essentially the same as the original Shimano(140mm) mounting locations. If your builder has followed these specifications then your locations will be correct.
Likes For incepi:
