New bike. Disc brake noise (not squealing). Will this go away?
Bikes: 1980's Norco MTB, 2015 Giant Fastroad Comax 1
I'm about to pickup a new bike with Shimano hydraulic disc brakes. During a test ride of the floor model, I noticed they made a "friction-y" noise when I applied the brakes. NOT an annoying squeal. Just a noise that sounds like "shhhh".
This is my first experience with disc brakes. My old rim brakes were practically silent. While disc brake noise is not super annoying, I'd prefer it not being there.
Is this noise normal?
Will it go away after break-in?
PS: this is my first post--Hello!
Last edited by Bikram; 06-17-15 at 10:56 PM. Reason: I wasn't very clear. The noise was DURING brake application. ...also I slagged the wrong company... brakes are Shimano...
Custom User Title
Bikes: Fuji Roubaix Pro & Quintana Roo Kilo
Quoted: 2863 Post(s)
Liked 31 Times
I don't have any experience with disc brakes, but I imagine that is normal considering the materials and forces involved.
Bikes: Trek Domane 5.2, Ridley Xfire, Giant Propel, KHS AeroComp
Quoted: 1648 Post(s)
I have only had one bike with hydraulic disc brakes, I sold it after about 6 months, but do not remember any noticeable noise from the brakes.
Quoted: 1850 Post(s)
Liked 669 Times
There should be no noise from the brakes when you are not actively engaging them - even then, there should not be considerable noise. It could be that the brakes are poorly adjusted and rubbing the disc.
I'm about to pickup a new bike with Tektro HD-M330 hydraulic disc brakes. During a test ride of the floor model, I noticed they made a "friction-y" noise. NOT an annoying squeal. Just a noise that sounds like "shhhh".
almost like a flutter sound.
I'm doing it wrong.
Bikes: Rivendell Appaloosa, Rivendell Frank Jones Sr., Trek Fuel EX9, Kona Jake the Snake CR, Niner Sir9
Quoted: 9742 Post(s)
Liked 2,812 Times
Well...my xt brakes on my mountain bike do this every so often when it gets dirty and my friend's disc brake equipped cross bike does it seemingly all the time. Tell the shop to see if the rotor is slightly bent when you get your bike...that's a possible fix.
Bikes: Salsa Ti Warbird- 2014/ November RAIL52s
Quoted: 67 Post(s)
Front wheel?
The disc isn't aligned with the caliper.
Can be for any number of reasons, improper QR torque being typical, pads dialed in too close to the rotor, caliper wasn't properly aligned when installed...can be temporary while riding because of rotor heat buildup, flexing the frame, road schmeg, etc..
Rotor should spin freely and silently through the caliper, no rub, or grab. Make sure your shop goes over the brakes, and it's something you should learn how to adjust yourself.
My car does it..."shhhhhhhh" very lightly, like a jazz drummer using a brush on a cymbal. Dealership says it's fine. Annoys me.
Thanks everyone. I wasn't clear enough, sorry: the noise only comes about when the brakes are APPLIED. In a way, it wasn't unexpected; there's greater force needed to slow something down when it's concentrated so close to the hub. It's just that it was more noticeable than I thought it'd be. Bike store says the noise will go away after a while.
It's just that I've been spoiled by the near complete silence from my very old (original pads!) cantilever brakes even when braking moderately hard.
Also, I noted that I slagged the wrong company. The brakes are by Shimano, not Tektro.
I've edited my original post. --what a lame 1st post!
I've got Tektro Novella's (lower-end mechanical discs) on my Trek hybrid and after about 2,000 miles they still make a somewhat audible "shhhhhh" when applied. But, they don't squeal and don't make a sound or rub when not applied.
Bikes: Specialized Diverge E5 Comp, Specialized AWOL Comp, Scott Solace 10
Quoted: 137 Post(s)
Liked 27 Times
My experience with metallic pads is that they always make noise when you brake. And, if they get road grit in there (which happens quite frequently when riding in the rain) they can scream pretty loudly. Despite this, I do like the braking performance they provide.
I haven't tried organic brake pads though, they are supposed to be quieter.
Quoted: 137 Post(s)
Liked 27 Times
One thing that I didn't say is that (again, in my experience) the noise will get quieter after the brakes are bed in. They can get much louder if and when grit gets in, but they can be cleaned. Even if you don't clean them, this doesn't seem to affect braking performance.
How "delicate" are the holes in the discs themselves. I've found that the more "delicate" the pattern, the more noise the brakes are likely to make because of the greater amount of edge going past the pads.
However, judging on recent experience, disc warp does have influence on the amount of noise the OP is discussing. I have one disc out of the eight on the family's bikes that makes more shhhh noise than all the others, and that is the one that is warped the most.
Also, bedding in the brakes is another factor -- speed up, brake hard; speed up, brake hard; speed up, brake hard; or just ride a steep downhill with the brakes applied will do the trick.
I like the concept of disc brakes because replacing rotors and pads are cheaper than replacing and relacing rims. Plus, with the right actuation set-up, they really do work reliably and consistently.
Also, further questions perhaps should be directed to the MTB forum where disc brakes have been in use for ummmm.... a long time.
Barrel Racer
Bikes: t-5 litespeed (just ordered) 6-20
Old Fart
Bikes: '97 Klein Quantum '16 Gravity Knockout
Quoted: 163 Post(s)
Hey, enjoy that new bike!
