BB5 brakes are noisy.
Old 07-08-17, 06:01 PM
Mark42
Bikes: Nothing a Bike Weenie would ride.
Quoted: 76 Post(s)
Have changed from V brake to BB5 disc front and rear (no adapters needed) using the OEM BB5 pads. The front is a 205mm disc and made a squeak until I shimmed up the caliper a few millimeters to get the wear pattern past the radial spokes of the disc. Now it just makes that nasty grind/sandy noise. The rear made the same noise squeak but its a 160mm disc. Tried shimming it up too, but no change. The brakes work well, the disc is not pulled far off center when squeezed and the brakes stop hard. Just hate the noise.
I have another bike with front disk using Organic pads, and it nearly dead silent.
I can live with that semi-metalic pad grinding noise as long as the darn squeak goes away. Hate that loud squeal every time I touch the rear brake.
BTW, under heavy braking, the rear does not squeal.
What is a guy to do?
Mark42 is offline
Old 07-08-17, 10:42 PM
cobba
Quoted: 184 Post(s)
Liked 65 Times in 51 Posts
Did you check that the outer edge of the pad isn't overhanging the outer edge of the rotor?
cobba is offline
Old 07-09-17, 12:32 AM
maddog34
maddog34's Avatar
Bikes: !982 Trek 930R Custom, Diamondback ascent with SERIOUS updates, Fuji Team Pro CF and a '09 Comencal Meta 5.5
Quoted: 1295 Post(s)
Liked 736 Times in 531 Posts
220 grit emery paper.
hit the pads and disc with it.
AFTER everything is aligned, of course.....
maddog34 is offline
AcornMan
Bicycle Mechanics
12
08-10-14 09:32 PM
Swoop
Bicycle Mechanics
1
04-09-14 07:36 PM
1 guy 1 bike
Bicycle Mechanics
17
04-07-12 08:23 AM
lamboluver
Bicycle Mechanics
3
09-20-10 04:18 PM
wunderkind
Bicycle Mechanics
2
05-31-10 11:41 AM
