'84 Dia compe 400 question, help plz?
Old 08-09-19, 09:08 AM
WildRalph
Bikes: '85 Le tour Luxe, Puch Mixtie, Raleigh Gran Sport, Mystery Machine
Quoted: 34 Post(s)
Liked 12 Times in 9 Posts
This may be a really silly question, but...here goes: cleaning up a toasty '85 League Fuji ($10 yard sale bike) needs some TLC to be a daily beater. Anyway, broke the rear brake down for clean and lube, but upon re-install, the one arm does not pivot unless the mounting bolt is loose. The problem appears to be the spring holder portion that the mounting bolts extend from, and its interface with the arm that the spring holder is in immediate contact with. I assumed the spring holder and that arm were integral (attached) to each other. But that defies logic, cuz it appears that arm should pivot independent of the spring holder (sorry for lack of nomenclature). Perhaps rust/oxidized welded? Not familiar with these brakes, so figured i would ask the pro's before i break something trying to separate them.
WildRalph is offline
Old 08-09-19, 09:14 AM
TenGrainBread
TenGrainBread's Avatar
Quoted: 1099 Post(s)
Liked 536 Times in 298 Posts
Difficult to see what you're talking about without pictures.
TenGrainBread is offline
Old 08-09-19, 01:04 PM
WildRalph
Quoted: 34 Post(s)
Pics
1. Brake arm. 2. Black spring holder. 'Sposed to be welded together, or no? Has a weird (to me bolt "nut") too. Doesn't shimano use an unshakeable nut, or dbl. Nut?
Old 08-09-19, 01:05 PM
WildRalph
Quoted: 34 Post(s)
Pic
Old 08-09-19, 01:07 PM
WildRalph
Quoted: 34 Post(s)
Pic
Old 08-09-19, 01:36 PM
cinco
cinco's Avatar
Bikes: Forty of them
Quoted: 99 Post(s)
Liked 33 Times in 21 Posts
Yep, rusted together - both arms are supposed to move independent of the central shaft (which the spring holder is a part of). I've had that happen and it usually doesn't take much to get everything apart once you set your mind to it. Plenty of spare parts out there if it's too bad to be saved or if you mangle something.
cinco is offline
Old 08-09-19, 02:59 PM
SurferRosa
señor miembro
SurferRosa's Avatar
Bikes: '70s - '80s Campagnolo
Quoted: 3684 Post(s)
Liked 6,086 Times in 3,026 Posts
No worries. Just fully dismantle and overhaul. These are easy to adjust, because there are two nuts you can lock together. You might need a cone wrench or an $11 Park Tool obw-4. (Check ebay.)
SurferRosa is offline
Old 08-09-19, 04:16 PM
WildRalph
Quoted: 34 Post(s)
Thanks, folks
That is what i suspected. I have adjusted/installed a handful of brake sets over the years, mostly shimano, some dia diacompe, perhaps; but think i was having short And long term memory loss on this one. LOL. Broke every thing down but that separation. I am sure it wont be much trouble. The stuck cable housing stop adjuster was interesting. Ended up chasing the threads. Thank You.
Likes For WildRalph:
Old 08-09-19, 05:06 PM
clubman
Phyllo-buster
clubman's Avatar
Quoted: 2269 Post(s)
Liked 1,968 Times in 1,217 Posts
Grease that washer between the brake arms. Between everything except the pads and rims...
clubman is offline
Old 08-09-19, 08:25 PM
WildRalph
Quoted: 34 Post(s)
Well that was harder than one would think it should be! Ended up using heat just like removing a pedal shaft from an aluminum crank arm (Sheldon trick). Careful not to damage the spring's heat treat. All worked out in the end. +1 on the grease! Thanks again!
Chesterton
Bicycle Mechanics
6
07-17-19 04:30 PM
wdmn
Bicycle Mechanics
14
09-16-15 01:20 PM
no motor?
Bicycle Mechanics
9
05-22-15 01:33 PM
americanlt2
Bicycle Mechanics
1
06-06-14 02:49 PM
john hawrylak
Bicycle Mechanics
3
12-27-09 01:19 AM
