Removing / replacing V-brake spring assembly?
Old 12-01-12, 08:10 PM
pstake
Bikes: Which one?
Quoted: 10 Post(s)
Liked 19 Times in 7 Posts
Is it possible?
I don't see how to get the spring off / the assembly apart?
pstake is offline
Old 12-01-12, 08:20 PM
FBinNY
Quoted: 5352 Post(s)
Liked 1,791 Times in 1,016 Posts
Brakes vary, but basically once the arm is off the pivot you can disassemble it and remove the spring from the back.
The challenge is getting replacement springs. If you can find he right one, buy a pair so they're a better match han a new and used one would be. Often the best source for parts like these is in a local shop or co-ops junk brake bin.
FB
Chain-L site
“Never argue with an idiot. He will only bring you down to his level and beat you with experience.”, George Carlin
FBinNY is offline
Old 12-01-12, 08:27 PM
pstake
Bikes: Which one?
Quoted: 10 Post(s)
How do I dissasemble the spring once I get it off the bike?
pstake is offline
Old 12-01-12, 08:38 PM
FBinNY
As I said it varies brake to brake, but most aren't attached to the arm. They're loose and simply trapped between the arm and the boss. If you have halfway decent mechanical instincts, remove the arm and take a look.
BTW- why are you asking?
FB
Chain-L site
FBinNY is offline
Old 12-01-12, 08:42 PM
pstake
Bikes: Which one?
Quoted: 10 Post(s)
It's off and the spring assembly is still attached ... I got a set of arch rivals but the pin the gives the spring purchase, that goes through the frame next to the bosses (the three holes) — that pin is gone from both sides of the brakes. So I wanted to try and take the assembly apart, and the assembly from a donor set ... or at least the pertinent parts, if possible.
Does that make sense?
pstake is offline
Old 12-01-12, 09:00 PM
FBinNY
As I said not all brakes do it exactly the same way. From your description, I suspect that your brakes use a spring stop cam behind the arms. This usually goes through the aluminum arm all the way to the front. But it's a slip fit and you should be able to push it out.
FB
Chain-L site
FBinNY is offline
Old 12-01-12, 10:24 PM
pstake
Bikes: Which one?
Quoted: 10 Post(s)
That's what I needed to know. I had to pry a cap off the front side and then it pulled through ... you're a gentleman, sir!
Thanks...
pstake is offline
Old 12-02-12, 03:36 AM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
Liked 1,350 Times in 857 Posts
N/m
fietsbob is offline
qwe123
Bicycle Mechanics
6
07-02-20 11:43 AM
elpado6872
Bicycle Mechanics
3
12-21-15 10:42 AM
sb88
Bicycle Mechanics
5
09-15-15 08:25 AM
americanlt2
Bicycle Mechanics
1
06-06-14 02:49 PM
DBRPOD3
Bicycle Mechanics
6
08-13-12 08:16 AM
