Dia Compe Rim Brake Spring Creaks when Brake is Pressed
Old 12-05-14, 11:00 AM
OldBikesRules
This post has been deleted. Thank you.
OldBikesRules is offline
Old 12-05-14, 11:13 AM
repechage
Quoted: 3267 Post(s)
Liked 2,563 Times in 1,827 Posts
Originally Posted by OldBikesRules
Hello, I need some advice. I have Dia Compe 500G side pull brakes on my vintage bike. The rear one works fine, but the front one emits a rather loud creaking sound from the spring rubbing against the calipers every time I pull the cable. I've already cleaned it and lubed the whole brake, but the annoying sound is still there. It also seems to be harder to pull vs the rear brake. Any thoughts? Thanks.
remove the mounting bolt with the brake still attached by the operating cable.
hold it in hand backside toward you and squeeze the lever and observe.
Look for scraping wear.
I am assuming you have adjusted the main pivot with the spring disengaged to observe smooth movement.
Be sure to grease the spring horns where the spring is retained by the arms.
There is excess friction in the system, so the task is to locate it.
Also check to see if there is grinding between the arms themselves, on the cheaper Dia-Compes, this was common, usually associated with one of the arms being bent due to the front end swinging around and the brake taking the load as it hit the frame or shift levers.
repechage is offline
Old 12-08-14, 09:14 AM
OldBikesRules
Old 12-08-14, 10:40 AM
JohnDThompson
Old fart
JohnDThompson's Avatar
Quoted: 3484 Post(s)
Liked 3,150 Times in 1,806 Posts
If it bothers you enough, replace the caliper. 500G calipers or reasonable equivalents from Weinmann, etc. ought to be abundantly available. Otherwise, inexpensive and effective modern dual-pivot calipers are also available from e.g. Tektro.
JohnDThompson is offline
Old 12-08-14, 11:52 AM
The Golden Boy
Extraordinary Magnitude
The Golden Boy's Avatar
Quoted: 2560 Post(s)
Liked 1,589 Times in 877 Posts
And if you're like me, you'll shock yourself with how well dual pivot brakes stop.
Commence to jigglin’ huh?!?!
The Golden Boy is offline
Old 12-08-14, 03:00 PM
noglider
noglider's Avatar
Quoted: 7138 Post(s)
Liked 2,086 Times in 1,240 Posts
I know you're 105% sure it's the caliper, but lubricate the lever. Lube the pin that holds the cable and pivots against the handle. This may be the real source of the squeak.
noglider is offline
Old 12-09-14, 06:21 AM
Bikedued
Bikedued's Avatar
Quoted: 160 Post(s)
Liked 29 Times in 23 Posts
Also flip the bike over and dribble some light oil into where the cable exits the threads on the adjuster. let it sit a few minutes, then flip the bike back upright.,,,,BD
Bikedued is offline
Old 12-09-14, 04:18 PM
dddd
Ride, Wrench, Swap, Race
dddd's Avatar
Quoted: 1485 Post(s)
Liked 1,164 Times in 787 Posts
+1^^, very common source of creaking, and easy fix.
On some calipers, molded plastic "sleeves" cover the spring "horns" where the spring ends contact the arms. I've used the plastic tubing that covers exposed runs of cable, which slips right on and stops squeeks and creaks that originate here.
On my 1987 Motiv Defiant road bike with safety levers, I finally tracked down the creak to where the tang on the safety lever pulls down on the font edge of the main lever.
There's some flex-caused movement there between the two levers, so I took a toothpick and dabbed a speck of grease in there, which immediately smoothed things out.
Yet further from the OP's question, I took the bike off-road yesterday for almost two hours, crossing creeks, dodging rocks and skirting mud pits. Afterwards, the once-mottled braking surface on the rims was smoothed to perfection from all of the abrasion, and the new pads fully settled against the fresh surfaces. Braking has never been better.
dddd is offline
Chesterton
Bicycle Mechanics
6
07-17-19 04:30 PM
steve0257
Bicycle Mechanics
2
08-15-15 03:19 PM
efiste2
Bicycle Mechanics
12
05-27-15 05:23 AM
Ai52487963
Bicycle Mechanics
4
03-21-13 10:27 PM
no1mad
Bicycle Mechanics
6
12-19-11 09:54 PM
