Are Carbon Road frames really worth the extra cost?
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,094 Times
Sometimes a more useful question is "what else are you saving it for?" If there's something specific and important, well, there's your priority. If not, well... What I think everyone needs to find is a bike you really like, one you want to get on all the time, one that will last you through all the evolution your riding future might hold. If the enthusiasm is tempered, don't spend much. If the enthusiasm is ingrained and growing, look up the line. If you know you will be doing this for hours and hours every week for as far as you can see, then go big or go home.
Advanced Slacker
Quoted: 2749 Post(s)
Liked 2,516 Times
Bikes: two blacks, a blue and a white.
Quoted: 442 Post(s)
Liked 839 Times
What I'm saying is that it's ok to invest in what you FEEL is great, because everyone will have a different opinion.
Veteran, Pacifist
Quoted: 3876 Post(s)
Liked 4,780 Times
An Al frame** with higher-end, supple tires will ride as well or better than any CF with gatorskins (no slight to gatorskins, they have a place too), or any stiffer tire.
edit: ** AL frame - meaning an Al road frame from the manufacturers mentioned in post #1.
Quoted: 4227 Post(s)
Liked 2,488 Times
Carbon frames have absolutely zero advantages over steel or aluminum frames...Even if carbon bikes became dirt cheap I still wouldn't purchase one.
Bikes: 2022 Salsa Beargrease Carbon Deore 11, 2020 Salsa Warbird GRX 600, 2020 Canyon Ultimate CF SLX disc 9.0 Di2, 2020 Catrike Eola, 2016 Masi cxgr, 2011, Felt F3 Ltd, 2010 Trek 2.1, 2009 KHS Flite 220
Quoted: 4266 Post(s)
Liked 2,938 Times
Carbon frames tend to be lighter but stiffness will depend on models, new carbon bikes these days also prioritize comfort. Either way bike manufacturers make a huge margin between price of manufacturing and selling price and they can get away with it. In my opinion, the workmanship of the carbon frames in bicycles are not held to the same standards as in other industries and should be better especially for the price we pay for. For the most part it's fine, but sometimes the poor tolerances can cause issues. I personally have a carbon bike and i love it, but I also did my research before purchasing, because not all carbon frames are the same.
First Level Cyclist
Bikes: 2007 Specialized Sequioa 3x10, 90's DiamondBack 64cm heavy steel commuter 3x10, Niner RLT 2020 GRX 2x11 Steel, 3x10 tandem (KHS?, 90's), 2014 Giant Trance X2 Di2 2x11, + others I'm buying/building/selling
I have multiple good road bikes in each of steel, alu, titanium and carbon. I cannot tell the difference between them; the arm waving that folks do regarding 'ride quality' is solely due to tires, tire inflation pressure and the saddle. But the bikes definitely sound different.
Exception to my above assessment - carbon bikes are lighter. You can build a strong, stiff, and well-tuned road frame for the following weights:
All things being equal, carbon for the win.
- Steel: 1,500-1,700g
- Alu: 1,300g
- Titanium: ditto
- Carbon: <1,000g.
Clark W. Griswold
Quoted: 4253 Post(s)
Liked 3,866 Times
Steel is real, Ti is fly, Wood is good, Bamboo is for you but aluminum and carbon don't rhyme and there for are insufficient for a frame material.
Likes For veganbikes:
Guest
Quoted: 1346 Post(s)
Liked 3,269 Times
Likes For Rolla:
Rhapsodic Laviathan
I don't see a reason to go carbon, unless you're racing.
Likes For Jax Rhapsody:
Tragically Ignorant
Liked 9,094 Times
OP's question was whether carbon really feels better than aluminum, not whether he should spend money to get carbon if he had a strong feeling about it.
Quoted: 2332 Post(s)
Liked 2,094 Times
In short, you are wrong.
I own or have owned frames in all of the above material but experience isn't needed, this is basic material science.
Likes For GhostRider62:
Quoted: 338 Post(s)
Liked 408 Times
I'd rather buy CF from a "2nd tier" manufacturer than aluminium from Trek or Specialized and the price would be almost similar.
Lighter, comfortable, longer lasting than alloy... I'd get it. CF bike with CF handlebars and seatpost is more comfortable than steel plus alloy components in my experience.
Quoted: 4274 Post(s)
Liked 4,712 Times
I don't see a reason not to go carbon unless you can't afford it or simply prefer a *insert frame material of choice here* frame for whatever reason.
Carbon just happens to be a great material for making light/stiff/comfortable bike frames. Only real downside is relatively high cost.
Quoted: 18320 Post(s)
Liked 15,297 Times
Chum and they will come.
Likes For indyfabz:
Quoted: 3192 Post(s)
Liked 2,460 Times
Likes For seypat:
Tragically Ignorant
Liked 9,094 Times
Agreed, the real question is whether those advantages are going to make a noticeable difference to the OP. That's the subjective question we really can't answer, but may or may not be able to make some pretty good educated guesses.
BTW, nothing in what you say excludes the possibility that a well-made and designed non-carbon frame would not possibly have huge advantages over a crappy quality carbon frame.
Tragically Ignorant
Liked 9,094 Times
Tragically Ignorant
Liked 9,094 Times
Likes For livedarklions:
Quoted: 811 Post(s)
Liked 1,946 Times
To the OP: if I was on the market for a new road bike, I would look at the quality of the builds, specs and if the bottom bracket is threaded or press fit.
Frame material would be just one of multiple factors to consider besides price.
Liked 2,094 Times
I did not read all of the posts in the thread but tire selection and pressure can make more of a difference than frame material. If money is a consideration, I would suggest OP get the aluminum but put supple, wider tires at lower pressure.
Tragically Ignorant
Liked 9,094 Times
Yes, there are crappy engineers and crappy companies out there.
What I find funny about these frame material arguments is people acting like there's only one possible correct answer to a clearly subjective question--which is really some version of "what best suits my tastes and preferences?"
