VAR third hand — what thread do I need?
Quoted: 1088 Post(s)
Liked 1,205 Times
I know I should have left it alone — I had the bright idea that I would straighten out the curved clamp screw on my vintage third hand tool, and of course it snapped like a dry pretzel. Does anyone know what thread pitch I will need a replacement to be? The remnant (which I am guarding like a vital organ) fits into the 3/32 slot of my thread gauge, or also a bit loosely in the adjacent M5, but I’m still not sure what pitch to seek. Anyone know? Thanks in advance!
Quoted: 1824 Post(s)
Liked 3,366 Times
A quick check of mine indicates that the thread pitch is 1.0mm.
Steve in Peoria
Old fart
Quoted: 3582 Post(s)
Liked 3,394 Times
The newer VAR 3rd hand tools with the black knurled thumbscrew use 6mm x 1mm thread, but the older ones with the brass thumbscrew use a different thread. Unfortunately, I don't have one of the old ones to measure. It may be possible to re-tap the tool.
Bikes: 2013 Wilier Gran Turismo, 1983 Trek 760, 80's Colnago Super, 90's De Rosa SLX, 2009 Waterford 22 Series Singlespeed, 85 Medici Pro Strada, De Rosa Alumino frameset, Dave Molten Fuso frameset, 70's beater Peugeot PX10, Zizzo Liberte, 2022 Yoeleo R12
Quoted: 122 Post(s)
Liked 199 Times
Likes For momoman:
Bikes: Drysdale/Gitane/Zeus/Masi/Falcon/Palo Alto/Raleigh/Legnano
Quoted: 971 Post(s)
Liked 624 Times
I guess boring it out for an oversized Grade 8 bolt would be overkill...
Larry:1958 Drysdale, 1961 Gitane Gran Sport, 1974 Zeus track, 1988 Masi Gran Corsa, 1974 Falcon, 1980 Palo Alto, 1973 Raleigh Gran Sport, 1974 Legnano. Susan: 1976 Windsor Profesional.
Liked 1,205 Times
Thanks, everyone, for your help on this!
Bikes: yes
Quoted: 512 Post(s)
Liked 409 Times
Try contacting VAR and see if they have any institutional memory. You never know.
https://www.vartools.com/en/contact-bike-tools.php
Liked 1,205 Times
Well, based on the advice above and in the other linked thread, I took a chance on these (sized 3/16, 28tpi), and will report back once I get them:
https://www.ebay.com/itm/15425626998...708c%7Ciid%3A1
I also wrote to VAR to confirm the size and see about any old stock, so we’ll see what they say...
SE Wis
Quoted: 2740 Post(s)
Liked 3,386 Times
Just our of curiosity did you try a 1/4 - 28 NF screw?
Liked 1,205 Times
No, my thread gauge has a 1/4” entry, and this screw is considerably narrower than 1/4”. It fits in the imperial 10, which I saw in a different thread translating essentially to 3/16”, which is why I gave it a go with the linked ebay item.
Bikes: Jack Taylor Tandem, Oscar Egg Routier
Quoted: 21 Post(s)
Liked 16 Times
VAR is or was a French company. So expect it to be a metric screw. Sounds like it could be an M6x1mm or an M6x0.8mm or an M6x0.75mm.
Reid
Reid
Liked 1,205 Times
The linked thread in post #4 above has a lot of relevant info and pics, which show that the part I need was specced as M6x1 as far back as the 1980’s, but mine appears to be older. The thumb screw pictured in the linked thread is about 5mm diameter, and 28tpi or 0.9 appears to be the closest match for the thread pitch. I’ll report back when I get those screws delivered via ebay whether they’re a match. Also, if VAR responds to my query, I’ll report it here.
SE Wis
Liked 3,386 Times
https://www.sizes.com/tools/thread_sf.htm
Liked 1,205 Times
Yeah, I’m hopeful...
0.9mm = 0.0354331 inch
0.0354331 x 28 = 0.9921268
So, I’m hoping that’s close enough to 28tpi to hold the tool in place. It’s not mounting a rack, so my demand on it won’t be remarkable.
Liked 3,366 Times
OTOH, I'm not sure that stuff like Whitworth threads are any less troublesome.
Steve in Peoria
(this VAR tool really is nice to use, so I hope this ends up well)
Disraeli Gears
I'm not sayin' this is the answer, but just so you know: M5 x 1.0 really is a thing (or at least was BITD).
https://www.bikeforums.net/classic-v...ter-braze.html
and look near the end of the first page. Been there . . .
Liked 1,205 Times
Just closing the loop here — the 3/16” 28tpi screw does thread in, but it’s loose. Thankfully, it holds the arm enough that I can use the tool, but it’s clearly not exactly right. I have found a source for M5x0.9 online, but I’m trying to decide if it’s worth the shipping. This will work for now.
Quoted: 4507 Post(s)
Liked 6,373 Times
Likes For merziac:
Quoted: 1105 Post(s)
Liked 1,325 Times
What you need, sir, is this:
Which is a 5x0.9 thread, I know, 'cause I just made it.
pm me if you are interested (it'll be cheap)...
Likes For oneclick:
Liked 1,205 Times
