Hydraulic Brake Bleeding Interval
ignominious poltroon
Quoted: 2238 Post(s)
Liked 3,429 Times
Well, just do the pads first. That is dead easy and might make all the difference. If you do use the fluid, wear gloves and eye protection.
Is the whole caliper moving? If so, you absolutely have to address that. If it has an adapter, figure out which part is moving. If it is between the adapter and the caliper, you have nothing to lose. If it is indeed the fork, I would very cautiously tighten it a bit more, and perhaps use some locktite. The force vector should be straight down, so it shouldn't have to be insanely tight.
SE Wis
Quoted: 2744 Post(s)
Liked 3,390 Times
I've never replaced a brake line that corroded from the inside out. Either corrosion from the outside (especially where strapped to the frame) or a rubber hose/caliper/wheel cylinder failure first. Living in the salt belt, owning a plow truck, and having replaced hundreds of feet of brake lines, I now only use Ni-Copp on replacements with stainless fittings and bleeder screws.
Likes For dedhed:
Quoted: 3948 Post(s)
Liked 7,291 Times
Likes For tomato coupe:
Liked 3,429 Times
The MSDS that comes with every container labels it corrosive. Not me.
My main objection to its use is that it is hygroscopic.
How compelling. Just like the chain smoker who says they've [cough-cough] avoided lung cancer.
Dismissing mineral oil because it isn't good for stopping a semi is equally comical.
I don't bother to wear nitrile gloves when bleeding. I've been bleeding automotive brakes since 1969.
SRAM has many videos on bike maintenance. The bleed video is particularly good, since there are certain steps that must be done in the correct order. Buy a bleeding edge .bleed kit first.
Likes For DaveSSS:
Quoted: 800 Post(s)
Liked 512 Times
Both my bikes are Shimano/mineral oil. I do a lot of hill riding and I ride my brakes a lot on descents. Because of this I flush my disc brakes annually. For the cost of my time and one bottle of Shimano mineral oil, I find the time to be well invested.
Likes For NoWhammies:
The whole fear of Dot is way over done. Water gets into both Dot and mineral oil systems. The difference is Dot distributes the water throughout the whole system while with mineral oil it gathers in the lowest point often the caliper. And yeah Dot is corrosive so don't leave it on your skin or paint for hours or drink it. If you can avoid those things you will be fine.
Likes For Canker:
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
I would flush the fluid at intervals where the fluid actually gets noticeably dirty. Try it after one year, if it looks pretty clean, extend the interval.
On my XTs, they are just noticeably dirty after one year of heavy riding.
Of course, some people never flush their fluid or do a bleed. Sometimes it works out OK for many years, other times not.
I will add this: I can’t speak for road brakes, but half the time I try someone else’s hydros on their mountain bike, it feels to me like they need to be bled.
With a mighty wind
Quoted: 1086 Post(s)
Liked 859 Times
So many people, have had terrible experiences with SRAM brakes, and good experiences with Shimano and Magura. The mind likes to make connections ya know.
Quoted: 2333 Post(s)
Liked 2,097 Times
https://m.youtube.com/watch?v=mO5lipPGGlo
The thing about Sram brakes is they are less forgiving about half assing bleeding than shimano. There are multiple ways you can bleed shimano brakes and still get a pretty good lever. Sram you have to follow the directions. If you actually step by step bleed shimano brakes the way you are suppose to Sram really isn't much harder these days. Back BACK in the day avid(sram) were a pita. My fingers would hurt for a day or two after bleeding my juicy 5s but my Avid elixirs which are still pretty freaking old aren't bad.
Quoted: 818 Post(s)
Liked 1,652 Times
Believe me, if the fluid in the ABS unit is allowed to get bad enough to corrode the sensitive parts in the unit, you're looking at a huge bill, both in parts and labor.
Sock Puppet
Bikes: 2014 Cannondale Synapse Carbon, 2017 Jamis Renegade Exploit and too many others to mention.
Quoted: 1031 Post(s)
Liked 863 Times
I'm using Shimano/ mineral oil; looks like I'm good for some time then. The brakes were mushy from brand new. The service guy told me that's how it's supposed to feel. I didn't believe him so I took the bike home and flushed it myself (multiple times). It seems he was right because nothing changed. I'm using the short reach shimano 105 shifters that came on my 52cm bike. What a difference in pull stroke and force vs performance moto master cylinders, such as a brembo rcs19 or an Accosatto equivalent.
Quoted: 29 Post(s)
Liked 9 Times
If you have ABS on your car, you may want to re-think that. Failure to flush out your braking system is bad, but not flushing it on an ABS equipped car can get very, VERY expensive. Have a shop do it, as they will probably need special tools and/or procedures to do a "secondary bleed" of the ABS unit itself, which opens the solenoids and activates the internal pump to flush the fluid out of the unit.
Quoted: 818 Post(s)
Liked 1,652 Times
Changing the brake fluid won't do it. The solenoids, pump and valves within the ABS unit have to be activated by a tool (usually a computer) in order to get all the old fluid trapped in the unit itself out.
Quoted: 8274 Post(s)
Liked 9,030 Times
If there is moisture in there it could be considered cheap insurance to flush the system but flushing is certainly no guarantee the ABS module won't fail. Not flushing is no guarantee that it will fail.
Advanced Slacker
Liked 2,537 Times
I was not aware that ABS was so common in bikes these days.
Liked 9,030 Times
Quoted: 4227 Post(s)
Liked 2,488 Times
Not might...It's 100% guaranteed that few years from now high end bikes will have some sort of ABS , traction control,, radars, sensors, all kinds of detectors and maybe even electronic assisted steering.. Even cycling bibs will have built in sensors to keep your whole body in perfect harmony while riding.
Liked 9,030 Times
Likes For big john:
Sock Puppet
Liked 863 Times
Liked 7,291 Times
