Who built this ?
Quoted: 36 Post(s)
Liked 13 Times
Who built this ?
Hello,
I bought this Italian ? frame some time
ago as a refurbishment project and ever since I've been trying to find out who built it, without success.
Can anyone identify it please ? There are no marks of any description on the frame, only a 5C punched on to the fork steerer tube. There are no rivet holes on tne head tube for a badge. The frame appears to have been refinished at some time in the past - possibly powder coated.
I will measure the tube diameters and the seat post diameter would need to be 25 mm or so, as the seat tube top is mis-shaped The bottom bracket is 70 mm with Italian threads.
The rear drop-out is 105 mm
Edumacator
Quoted: 2434 Post(s)
Liked 3,108 Times
Hello,
I will measure the tube diameters and the seat post diameter would need to be 25 mm or slightly more. The bottom bracket is 68 mm with Italian threads.
Quoted: 600 Post(s)
Liked 778 Times
See https://www.bikeforums.net/classic-v...rame-lugs.html
@fredrico has a nice post in above link as below
Yeah, all the suits of a deck of cards: Hearts for DeRosa, Clubs for Colnago, Spades for Ciocc, and Diamonds for Pinarello. Quatro Assi has all four. Richard Sachs has all four on the inside tang of his flat fork crowns. They'll bring ya good luck, the luck of the draw.
ciao,
Fredrico
ciao,
Fredrico
Quoted: 3803 Post(s)
Liked 3,324 Times
Old fart
Quoted: 3583 Post(s)
Liked 3,396 Times
Not necessarily. Shell width is unreliable in predicting thread spec. The shell could have been overzealously faced, or started out BSA, got damaged/stripped, and was reamed and re-tapped Italian. I assume that the OP determined it was Italian by threading an Italian thread cup into the shell, or measured the inside diameter of the threads as 36mm rather than BSA 35mm.
Edumacator
Liked 3,108 Times
Interesting. Did not know that.
Bikes: Two Peter Mooney customs, a 1980 Trek 510 townie, a Marin Stelvio set up for TTs.
Quoted: 227 Post(s)
Liked 293 Times
I don't see these as much hearts as wings echoing the external shoreline of the lug.
Edumacator
Liked 3,108 Times
Which begs the question, can Campy Italian cups (36X24) be used with an BSA 68mm spindle?
Liked 3,324 Times
yes indeed, unlike T.A. & Stronglight* the Campag Italian thread cups have the same wall thickness as the metric and BSC threaded ones (within a given series such as R, NR, etc.)
T. A. & Stronglight make the walls of their Italian dimension bottom bracket cups one mm thicker than those of their BSC, metric and CH ones
this permits them to get by with one series of cotterless spindles
the system is ingenious but has downsides:
a) it renders difficult fitment to 70mm BSC shells as employed widely by Flandria for example
b) unable to accommodate the 74mm shells found on some vintage Italian cycles
c) unable to fit the 71mm BSC shells found on many Japan produced cycles (shell width used up through early 1970's as copy of a Raleigh dimension)
Stop reading my posts!
Quoted: 1440 Post(s)
Liked 1,058 Times
Made by somebody who didn't bother leaving any identifying marks: it appears to be a production frame of "good quality" but perhaps not any thoroughbred.
If the BB is Italian threading, then also check the inside butt of the fork steerer for any "rifling" and what size seatpost fits the seat tube?
And forkends and DOs are what brand?
One detail is there are no reinforcing tangs on the fork blades: some folks here say that's a clear deficiency cause the crown alone will not give the blades enough strength, but I dunno...
one more thot; only a 5C punched on to the fork steerer tube...isn't that something like a "date of manufacture" code like Tange used? If the fork ends are JP then this may not be the OEM fork.
Liked 3,324 Times
readers note that shell width has now been revised in original post from 68 to 70
date appears ca. 1973
possible fork crown may be a ROTO (Rampinelli) design -
Likes For juvela:
Old fart
Liked 3,396 Times
Old fart
Liked 3,396 Times
Yes, although Campagnolo bottom brackets of that era are a hot mess, what with "thick" (Nuovo Record) and "thin" (Gran Sport, Record) cups, pre- and post-CPSA offset changes, etc. Sugino and Sakae Ringyo spindles are fairly close to Campagnolo Gran Sport/Record spindles in physical dimension, and generally work with Campagnolo "thin" cups.
Campagnolo Bottom Brackets
Likes For JohnDThompson:
Quoted: 36 Post(s)
Liked 13 Times
It has chromed Campagnolo fork and rear drop-outs.
Atala and De Rosa street racer / cyclo-cross.
Possible braze-ons added later.
De Rosa type slots on underside of bottom bracket and oval cut-outs in bb shell
mycocyclist
Quoted: 910 Post(s)
Liked 811 Times
Our 50 Cents, (Inflation)
Made by somebody who didn't bother leaving any identifying marks: it appears to be a production frame of "good quality" but perhaps not any thoroughbred.... I dunno...
Fiorelli didn't serialize much of their work, only stamping the size on the steerer tube and sometimes on the BB shell.
Olmo also used the dual BB shell slot cutouts, but they featured a Serial Number.
Edumacator
Liked 3,108 Times
Could that "5C" actually be "50," which appears to be, C to C, the size of this specimen?
In the early 70s Fiorelli used BB shells with those slotted double cutouts, finished dropout ends as with this example, and stay ends are not inconsistent either.
Liked 3,324 Times
if cycle a Rizzato product at this era it would exhibit a serial stamped into the side of the seat tube just below the seat lug
this practice followed regardless of how Rizzato products were badged
to confirm or deny possibility of a Rizzato origin all that is needed would be to gently sand this area of the seat tube to see if any markings may have been filled in or filed away
the company owned something like six or eight marques...and did make extensive use of the Prugant 62/d lug pattern on its quality models
Quoted: 36 Post(s)
Liked 13 Times
Thanks for your replies.
There are no numbers, letters or any other marks on the frame.
As far as I know, Fiorelli early frames had distinctive circular fork crown ends.
A friend has suggested that it might be a Galetti frame
Liked 3,324 Times
member MauriceMoss sure to be able to sort this in two shakes of a lamb's tail
it has been a few weeks now since he last dropped in so perhaps he is getting close to time for a visitation...
wrt Fiorelli tubular crowns:
"some" examples of certain era received them and many did not
so their absence is not definitive of non-Fiorelliness...
framebuilder
I have many of those same bottom bracket shells in my inventory. I use them as brazing practice for my frame building class students. I got them from Miele in Toronto when they closed their doors in 1995. So it is possible that the frame might have been made in Canada. Well among many other possibilities.
Liked 1,058 Times
"Fornoni"?
I've heard of hundreds of Italian marques but that's a new one!
AFIAK it doesn't show up on the (nearly comprehensive) big Map of Italian Cycle Brands AKA Italia Bicycle Map, but there's always gonna be a few that didn't get included, especially if "Fornoni" was in the South (or out of country), so tell us more about that brand.
EDIT: came across your other post
https://www.bikeforums.net/classic-v...noni-frme.html
asking for info on Fornoni and @juvela posted many links to articles on the racer (and Olympic champ in 1960) Giacomo Fornoni.
There's no mention of him fronting a bicycle brand but it's a common tradition in Italy for a successful racer to cash in on his name applying it to a bicycle (contract-built by a multitude of makers). He did race for Molteni...FWIW but this frame in question doesn't ring any bells with attributes of (oh say) Colnago or DeRosa, IMO
He seems to have been from Bergamo, also FWIW
