Maxle comes loose on rides
Bikes: Canyon Ultimate CF SL Disc, Canyon Spectral
Quoted: 73 Post(s)
Liked 24 Times
My rear maxle gets loose on every ride. I've got it on very tight and after a bit of riding I can feel it loosening up b/c the shifting gets wonky.
Anyone know how I can fix this?
Quoted: 1438 Post(s)
Liked 1,092 Times
Yes, get an internal cam skewer, like Campy or Shimano, keep it lubricated and do it up correctly; the lever should leave an impression on the heel of your hand if it is tight enough..
Those external cam skewers like yours do not generate as much holding force as the internal cam kind.
Both types need to be tightened correctly to work properly.
Likes For dsbrantjr:
Quoted: 2479 Post(s)
Liked 2,948 Times
Here is one of many instructional videos on YouTube describing proper quick-release use.
Likes For Trakhak:
Quoted: 4195 Post(s)
Liked 3,837 Times
Maxles are not the common QR skewers that have been suggested. I have to admit that my experience with the modern through axle based systems is lacking. I know that some TAs can interchange and some are very dropout dependent.
Lyle- You say it's loosening up and that you can tell by the shifting. When this happens does the rear wheel flop about inside the frame, like a loose bearing adjustment would do? Have you looked carefully at the guide pulley and the cog it's suppose to be below to see if that alignment (what some will call the SIS adjustment) is centered and good? Is the Maxle's lever also loose in its engagement tension?
There are other possibilities like an axle end cap or cassette lockring issue that can affect shifting after a while. We assume you have checked out that common cable condition issues are not present, have you? With so little info... If your problem continues to be a problem, and you can't figure it out, I suspect NYC has at least one good shop that could help with their expertise. Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
Quoted: 2026 Post(s)
Liked 1,095 Times
Are you using the locking lever like a wing nut and just screwing the axle in with it or are you doing it correctly and snuging the axle in and then camming over the lever? Like a qr skewer, it is possible to install thru axles incorrectly.
Likes For HillRider:
Clark W. Griswold
Quoted: 4335 Post(s)
Liked 3,958 Times
Make sure everything else is properly torqued and installed and then if the skewer is being done up correctly and still coming loose maybe try a different axle Robert Axle Project makes some great stuff and if that one keeps coming loose I would use a mild threadlocking compound or better yet figure out the issue with the frame and the threading within.
Likes For veganbikes:
Quoted: 6178 Post(s)
Liked 4,795 Times
Since many haven't picked up on the fact, this is a thru-axle of sorts. Not a QR or skewer.
https://www.sram.com/en/sram/models/ax-ult-mxlr-a1
https://www.sram.com/globalassets/do...ser-manual.pdf
Likes For Iride01:
Quoted: 2493 Post(s)
Liked 738 Times
I don't know ... the dropouts on that bike look sufficiently tight that the shifting wouldn't (shouldn't) be affected by a loose 'quick release'. Moreover, that axle has seen some abuse. What about the drive side? Has there been any trauma to the drivetrain that we should know about?
Likes For Leisesturm:
Quoted: 73 Post(s)
Liked 24 Times
Thanks for all the replies.
The wheel definitely gets loose after some riding. Whenever I stop, I tighten the axle and the wheel feels firm and the shifting improves. This gets undone after a mile or so. So I don't think it's a rear derailleur adjustment issue. The cable is new, the jockey wheel is centered under the cassette ring, etc. The cassette was installed to the proper torque.
I did a couple of things that may resolve the issue. I'll test it out this weekend on the trails.
- I lubed up the thru-axle's threads and shaft. They didn't appear to be dry but the lube maybe got me an extra quarter turn.
- There is a set screw on the maxle that needs to be tightened. It operates on clicks. Prior to this post I had tightened it a few clicks. I turned it one more click and when locking the lever down, it definitely leaves an imprint on my hand.
Liked 4,795 Times
You might contact SRAM/RockShox support about it. Seems like an axle of theirs coming loose would get their lawyers worried.
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1939 Post(s)
Liked 1,463 Times
... There is a set screw on the maxle that needs to be tightened. It operates on clicks. Prior to this post I had tightened it a few clicks. I turned it one more click and when locking the lever down, it definitely leaves an imprint on my hand.Red arrow points to the set screw on the maxle.
Likes For SoSmellyAir:
Bikes: 2019 Trek Stash 7, 1994 Specialized Epic 1986 Diamondback Ascent 1996 Klein Pulse Comp, 2006 Specialized Sequoia Elite
Quoted: 418 Post(s)
Liked 521 Times
Lyle, my rear Maxle does the exact same thing. As you mentioned, it's quickly noticed because the shifting gets a little wonky.
The only thing I found to fix this issue is to tighten down that allen bolt that you mention after you cinch down the lever. This works fine me, but it also means I have to loosen the allen bolt when I remove the wheel.
Likes For mtnbud:
Quoted: 73 Post(s)
Liked 24 Times
I'm going to try my current fix and if it doesn't work, I'll just tighten that allen bolt.
Is this a known issue? I wonder if SRAM will replace the axle? It's kind of a pain b/c you can't contact SRAM directly. You have to take it to a bike shop, leave the axle, bike shop will call SRAM, etc etc. And I doubt they will warranty an axle that's 6-7 years old.
Likes For lyle.coop:
