White powder on bonded carbon frame, is it safe?
Old 05-09-23, 02:50 PM
Kontact
Kontact's Avatar
Quoted: 3354 Post(s)
Liked 776 Times in 517 Posts
Originally Posted by Atlas Shrugged
7 posts to answer the same question?
Just the one you quoted.
Are you complaining that he asked, complaining that I answered, or just complaining?
Or is your post an attempt to get rid of extraneous posts by adding your own extraneous and off topic post?
Keep up the good work.
Kontact is offline
Old 05-10-23, 05:19 AM
PhilFo
Tinker-er
Bikes: 1956 Rudge Sports; 1958 Rudge Sports; 1983 Univega Alpina Uno; 1981 Miyata 610; 1973 Raleigh Twenty; 1971 Raleigh Twenty; 1994 Breezer Lightning XTR, V4 Yuba Mundo aka "The Schlepper", 1987 Raleigh "The Edge" Mountain Trials, 1951 Rudge Aero Clubman
Quoted: 113 Post(s)
Liked 158 Times in 109 Posts
Originally Posted by fishboat
I read somewhere, can't remember where, before I bought this bike that Trek used the same process-procedures bonding the aluminum lugs to the carbon tubes as the aircraft industry(or maybe that process is just good-practice known at the time).
The whole "same process used in aerospace..." is a great marketing hype. They also use adhesive tape. The one thing that the average cyclist does not do, which A&P techs do for a living, is to inspect and completely rebuild frame components on a frequent and regular basis.
PhilFo is offline
Old 05-10-23, 07:03 AM
Kontact
Kontact's Avatar
However, isolating the carbon from the aluminum with fiberglass is obvious and normal solution to the problem of galvanic corrosion. It isn't just marketing.
Kontact is offline
Old 05-10-23, 07:40 AM
PhilFo
Tinker-er
Quoted: 113 Post(s)
Kontact don’t get the notion that I’m disagreeing with you. Isolating the dissimilar materials is absolutely necessary. What I’m saying is that while “aerospace industry” processes have been used, it does not negate the fact that in the aerospace industry, entire vehicles from the rubber touching the tarmac to the top of the tail are inspected and repaired/replaced very frequently. This is not something that a cyclist is doing regularly, if at all.
As for the hype of “aerospace” in cycling, yes, it is hype used by bicycle manufacturers to make their products seem superior to other technology. The Wright Flyers were made of wood, so that’s “aerospace industry” right? Where are the wooden bicycles? Yes, I know they exist, I’ve built some wheels for early 20th century safety bicycles with wooden rims. My old sneakers had velcro straps and I wanted them because velcro was used by astronauts and that fact was used to market the shoes to me.
PhilFo is offline
Old 05-10-23, 11:59 AM
Kontact
Kontact's Avatar
I wrote an article once about how poor the engineering in cycling actually, so I get you.
However, bikes are really easy to inspect compared to a wing root. The OP inspected his bonds.
Kontact is offline
Old 05-10-23, 02:14 PM
fishboat
Bikes: Lemond '01 Maillot Jaune, Lemond '02 Victoire, Lemond '03 Poprad, Lemond '03 Wayzata DB conv(Poprad), '79 AcerMex Windsor Carrera Professional(pur new), '88 GT Tequesta(pur new), '01 Bianchi Grizzly, 1993 Trek 970 DB conv, Trek 8900 DB conv
Quoted: 716 Post(s)
Liked 746 Times in 434 Posts
The whole "same process used in aerospace..." is a great marketing hype. .................................
I didn't read it in any Trek documentation..it was off some forum, possibly BF. In this case, apparently it wasn't marketing hype as Specialized seems to have ignored best-practice at the time and taken the "let's save $.94..by the time it becomes a problem it won't be our problem" pathway.
I don't doubt what you're saying is true(aerospace inspection & rebuild), however your broad generalization doesn't apply here. The point, in this case, is either the mfg did the bonding right or they saved a few cents and ignored what was known at the time as the proper process, regardless of the source of that process. It's likely the aerospace industry did develop the carbon-aluminum bonding process..that doesn't make it hype or a bad process.
fishboat is offline
Old 05-10-23, 04:22 PM
PhilFo
Tinker-er
Quoted: 113 Post(s)
Tough crowd.
I’m not saying these manufacturing processes are bad, nor the products themselves; my point is that the inspection, repair/remediation, and/or replacement go hand-in-hand with the product itself and the replacement or recementing of tubes/lugs is simply not something that is done by all but a handful of cyclists.
PhilFo is offline
Old 05-10-23, 06:12 PM
Zara Sp00k
Quoted: 18 Post(s)
Liked 7 Times in 5 Posts
I have a '92 Trek 8900 that's now..31 years old and it shows no evidence of this corrosion. I read somewhere, can't remember where, before I bought this bike that Trek used the same process-procedures bonding the aluminum lugs to the carbon tubes as the aircraft industry(or maybe that process is just good-practice known at the time). My condolences to the OP, but it is good to see what this corrosion looks like. I did a ton of research on carbon/aluminum lug frames prior to purchasing the 8900 and didn't come across a discussion like this. Hopefully this discussion will help someone in the future.
..just looked at the 1992 Trek Spec Manual and found this:
I guess this pretty much explains why my two bonded AL/carbon fiber frames do not have this problem.
I was a mechanical engineer for 44 years, I worked with at least 50, if not 100 companies, most were very religious about proper design, a few were not, often it was management that decided they would go against engineering to save a buck. The only time I can remember one of my engineering managers being like that was when I told him we should not mount a PCB upside down, after all, heat rises is pretty basic. Eventually many PCB's were returned, the electrolytic capacitors failing due to excessive heat.
Zara Sp00k is offline
Old 05-10-23, 08:24 PM
Atlas Shrugged
Quoted: 993 Post(s)
Liked 1,039 Times in 527 Posts
There is a whole lot of assumptions and judgment going on here with no facts other than a few bike shop urban myths.
Meanwhile the OP is happily riding along and will continue to do so for another decade.
Atlas Shrugged is offline
Likes For Atlas Shrugged:
Old 05-10-23, 09:27 PM
Kontact
Kontact's Avatar
I've worked in aviation and the bike industry for decades. You don't know what you're saying.
Kontact is offline
Likes For Kontact:
Old 05-11-23, 03:47 PM
flipchip
Chipper
flipchip's Avatar
Bikes: 1984 Miyata RidgeRunner, 2001 LeMond Buenos Aries
Quoted: 16 Post(s)
Liked 12 Times in 9 Posts
Thanks for all the advice fellas. It's not actually mine, just a bike I was considering purchasing. I've since found a mint 1990 model.
flipchip is offline
Likes For flipchip:
Old 05-12-23, 07:23 AM
Kontact
Kontact's Avatar
That was you takeaway from reading this thread?
Kontact is offline
Likes For Kontact:
Old 05-15-23, 04:48 PM
wheelreason
Quoted: 271 Post(s)
Liked 225 Times in 144 Posts
We toured the Trek factory back in the early 90s when the OCLVs were first coming out, and got to see the 2000 series frames being bonded, and yes, "aerospace technology" was hyped, in truth, they just used the same adhesives. They did have a batch of them that came undone due to the seats not being returned to their upright position...
wheelreason is online now
Old 05-30-23, 08:50 PM
flipchip
Chipper
flipchip's Avatar
Quoted: 16 Post(s)
Yes. I didn't buy the pictured bike, I found a mint model without any signs of corrosion. Given its already lasted 30 years, I figure it'll probably last another couple, and in the meantime I know what to look out for.
So, uh, thanks anyway?
flipchip is offline
Likes For flipchip:
Old 05-31-23, 07:27 PM
Kontact
Kontact's Avatar
I think your assumption that bonding failures with this particular frame only happens with white powder is.... misplaced.
Kontact is offline
Old 06-05-23, 06:54 AM
Zara Sp00k
Quoted: 18 Post(s)
Your statement could lead someone to believe bonded carbon frames are prone to failure, not true. Properly designed and manufactured, it will last as long as any other frame.
It might be a good idea though, to avoid any brand that shows this symptom unless you know for sure they eventually changed their design and process, and then only buy after the date of the change.
Old 06-05-23, 06:59 AM
Kontact
Kontact's Avatar
The only conclusion my comments should lead anyone to is that the Allez Carbon bikes were prone to failure - and they almost all did. We know they weren't built correctly.
Kontact is offline
Old 06-05-23, 07:02 AM
Zara Sp00k
Quoted: 18 Post(s)
that's what you should have said in the previous post, no need to brow beat the guy and leave others confused by what you mean
Old 06-07-23, 04:55 PM
VtwinVince
Quoted: 142 Post(s)
Liked 186 Times in 111 Posts
I had a '95 Epic Comp for 14 years, until it was stolen. An absolutely fabulous bike that never hinted at failing. Anecdotal? Sure. I also have a '93 Cadex CFR2 which I wouldn't hesitate to flog all day long. Safety is an illusion which our society seems unduly obsessed with these days IMHO.
VtwinVince is offline
Old 06-07-23, 05:06 PM
Schweinhund
Bikes: a couple
Quoted: 556 Post(s)
Liked 854 Times in 455 Posts
Am I right in assuming this is galvanic corrosion, and just how bad is it?
I blew apart, not one, but two Raleigh Technium MTB frames from this problem.
I was young then, I cannot imagine what it would feel like now.
Hang it on the wall and treasure your memories
Schweinhund is offline
Old 06-07-23, 08:45 PM
Kontact
Kontact's Avatar
Because neither of those frames was defective like the Allez.
Kontact is offline
