Two and Four Prong Freewheels Tools
Quoted: 66 Post(s)
Liked 48 Times
I need to buy a freewheel tool for a Regina two-prong freewheel. Can I use a two-prong tool also for four prong freewheels like Suntour?
Really Old Senior Member
I STRONGLY recommend using the correct tool for 4 prong FW's.
The 2 prong Sun Tour remover is prone to breakage. Sometimes when you do everything right, including using the skewer or axle nut to keep the tool snug against the FW.
You're basically gambling with fatal odds using the wrong tool.
Keep in mind. Most FW's that need these tools have been on a LONG time.
Likes For Bill Kapaun:
Bikes: !982 Trek 930R Custom, Diamondback ascent with SERIOUS updates, Fuji Team Pro CF and a '09 Comencal Meta 5.5
Quoted: 1188 Post(s)
Liked 593 Times
looking at the various tools and freewheels in question... Nope.i wouldn't even try it unless you like ruining parts.
FWIW.. most Regina freewheels are in the 40+ year old range and can be a Real Pain to remove.... heck, they liked to get stuck when they were new!
Find a different wheel and cut your losses... i've ripped a vise right off a bench trying to loosen one of those stupid things.
oh, and i ripped the prongs off a Park Suntour 2 prong tool last year... in a vise, after two days of periodic penetrant oil infusions, tool nutted to the axle with just enough room to break the evil bonds of age.... snap.
find a different wheel to save time, money, and possibly blood
Likes For maddog34:
Quoted: 5250 Post(s)
Liked 1,551 Times
2 prong Regina and Suntour have very different configurations.
The prong size, depth, and diameter are different.
I STRONGLY recommend using the specific correct tool (brand doesn't matter) for any freewheel. To do otherwise risks the tool, and especially with Regina, the freewheel itself
FB
Chain-L site
“Never argue with an idiot. He will only bring you down to his level and beat you with experience.”, George Carlin
FB
Chain-L site
Likes For FBinNY:
Likes For WT160:
Old fart
Quoted: 3409 Post(s)
Liked 3,011 Times
Liked 593 Times
I have 2-prong and 4-prong freewheel tools. The prongs are thicker on the 2-prong. It won't surprise me if you break the wheel instead. @maddog34 's vise wasn't securely mounted.
ever broken a bench vice? i have... at work.
I had a two prong freewheel removal tool for Suntour freewheels, and I was able to file down the notches on a Regina freewheel so that the Suntour tool fit. It came off with no problems.
