View Poll Results: how long does an application of drip wax last you?
<100km
2
5.26%
101-200km
6
15.79%
201-300km
13
34.21%
301+km
5
13.16%
don’t use it, feel like voting anyway.
12
31.58%
Voters: 38. You may not vote on this poll
drip wax longevity
#51
how often do you take them off for the cleaning? i basically never take it off between replacements, maybe i’m just not getting it clean enough.
the conditions of most of my rides *seem* benign but there’s definitely coastal fog (which may be salty?) and a little wind blown sand.
heavy fog maybe 1/3 of the time through here, with correspondingly wet ground in the AM
I pull the chain two or three times per year. Not that often.
#52
Quoted: 426 Post(s)
Liked 274 Times
looks benign!
but covered with sand 1/2 the time
looks benign!
I take my chain off every time for cleaning. I soak in mineral spirits for several days and put it in at least two jar. Then scrub it/wipe it down on 4x4. Hang it up to dry for several days before applying chain lube the night before a ride. I don't think the lube works as well if there is still mineral spirits between the pins. I rotate between several chains.
When I first started riding I used one of those automated cleaners like a few people have posted. I didn't give it much thought back then. I don't think that cleans inside the pins very well and then if you just put lube on semi wet chain with cleaner on it the lube does not go and stay like it should. No mater how much you dry your chain on the bike with towel etc.. the insides pins still going to be wet. Your lube is going to be diluted and probably not stay on as well.
Pre puppy ( sept, been hiking more with the dog ) I was riding about 500 to 700 miles a month and would rotate/clean/lube my chain once a week. I guess that's roughly 200km +
#53
Bikes: SL8 Pro, TCR beater
Quoted: 981 Post(s)
Liked 583 Times
how often do you take them off for the cleaning? I basically never take it off between replacements, maybe i’m just not getting it clean enough.
looks benign!
looks benign!
#54
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1939 Post(s)
Liked 1,463 Times
mschwett is either churning out megawatts or riding in extreme environments: is this cassette toast? - Bike Forums
Is your chain tacky (i.e., mildly adhesive) or greasy to the touch? Minimizing the accumulation of fine sand would increase drivetrain longevity.
#55
Quoted: 1273 Post(s)
Liked 1,384 Times
chain feels smooth to the touch, leaves a bit of grey/black grime on rag or fingers after a ride, but looks very clean and sounds good.
Liked 1,463 Times
The used chain at the top looks very clean on the outside for a chain that does not come off the bike for cleaning, but the interfaces between the inner chain plates and the rollers are more critical for chain and drivetrain wear.
#57
Liked 1,384 Times
Kilowatt! Got my metric prefixes wrong while typing in a hurry.
Quoted: 981 Post(s)
Liked 583 Times
Can't really get to the inside unless it's submerged and shaken in a liquid (fuel does the job - for the fancy people out here, an ultrasonic cleaner also does the job.
#59
Liked 1,463 Times
OMS is hard to buy in California, but you can still buy it from an art supply store for 3x what Lowes charges.
Gamblin Gamsol | Oil Mediums | Michaels
I have bought a quart from Michaels and a quart from Lowes.
#60
I like bike
Bikes: Roubaix Comp 2020
Quoted: 267 Post(s)
Liked 283 Times
Not to long ago I switched to using a Park Tool chain cleaner to apply the lube.. just fill up to the solvent line with lube (and re-use of course). This method extends the longevity based on results so far. It puts a lot more lube on the chain so it is also costing more.
At around 5:30 he starts lubing the chain. Notice zero splattering. He has a later follow-up video where he expects he can get 3x or so more life from a single lube with this method vs the hand drip-on of Silca SS.
#61
I remove the chain, put it with both quick links in a (clean) wide mouth pasta sauce jar with OMS, shut the lid tight, shake it for a minute, and let it soak overnight. If we are doing laundry on that day, I leave the jar on top of the laundry machine for one wash cycle (for the extra agitation). Then I transfer the chain and both quick links to another (clean) wide mouth pasta sauce jar with OMS, shut the lid tight, shake it for a minute, and let it soak for a few hours. The chain comes out spotless, and after hanging to dry for a couple of hours, it goes into the Crock Pot for waxing.
No point in long soaks, agitation is what's needed. See if you can buy camp stove fuel at walmart. I get crown brand for much less than coleman.
#62
Liked 1,463 Times
I can buy camp fuel at REI but would not dare to use camp fuel with the laundry machine agitation method, especially since I have a gas dryer.
#63
Bikes: Trek Madone 5.2 SL 2007, Look KG386, R022 Re-framed Azzurri Primo, Felt Z5, Trek F7.3 FX
Quoted: 404 Post(s)
Liked 85 Times
The hole body vibration machine also gets used as a leg stretching device.
Likes For timtak:
#64
climber has-been
Quoted: 3416 Post(s)
Liked 3,544 Times
#65
Quoted: 404 Post(s)
Liked 85 Times
Well spotted. A Freudian slip from my gay side, quite probably....
The hole [in my] body, vibration machine...
My hole [every]body, vibration machine!
Here it is being used to clean my chain (these days I use a container with a lid). Click through for a video.
Chain Cleaning by Timothy Takemoto, on Flickr
#66
Liked 1,463 Times
This is a great idea. I was looking at orbital shaker (like from biochemistry lab back in college) but these are < half the cost.
Likes For SoSmellyAir:
#67
Quoted: 567 Post(s)
Liked 563 Times
I posted this on Bike Mechanics discussion:Switching to a Catrike recumbent trike on bad arthritis days and finding my calf/clothes get marked by that very long bike chain, times 3 length, I switched to solvent wax and am very happy with the results. Still early but wear rate looks good to date and being retired I take the time to keep my bikes spotless and the trike was much more work with my homebrew when compared to my uprights.
Tried scottfsmith application method with a never used dusty Park Tool Chain cleaner going slow to not make a mess and it was pretty clean and much faster than dripping on 100s of links.
#68
Liked 1,384 Times
resurrecting my own semizombie thread...
still pretty happy with drip wax except for chain longevity. replaced last chain at 2,500 miles and it was far enough gone (maybe .6%) that the 11t and 12t cogs also had to be replaced (skipping under load, by load i mean 500-1000w).
the latest chain, which i've been cleaning more and lubing a little less, per shop recommendation, is at 1,600 miles and almost fits into the .5% side of my chain checker. .4% or so. seems like the wear rate is extremely similar. seems like very short chain life.
Liked 2,946 Times
I do like being able to not "mark" my own territory with the cleanliness of the waxed chain.
-Oh Hey!
-Oh Hey!
#70
Bikes: yes, i have one
Quoted: 1136 Post(s)
Liked 1,179 Times
its funny, i've been waxing for a long time and i still get chain ring tattoos. pretty sure the dark color is from the chain ring anodizing wearing off.
#72
Liked 1,179 Times
not sure if it matters but i don't use drip, i do the hot wax thing. but, i think you are right about the dirt. just today while adjusting my FD on a very new bike and was surprised to find as much black dirt on the underside of the BB shell. i've only had it out for about 6 rides now. i never ride in wet conditions.
#73
Sock Puppet
Bikes: 2014 Cannondale Synapse Carbon, 2017 Jamis Renegade Exploit and too many others to mention.
Quoted: 1031 Post(s)
Liked 863 Times
Dry riding won't collect as much dirt, but there is still dry road dirt kicking up all the time. Sometime at the end of your ride, wipe a tire with your hand as you roll it. You will have a black stripe on your hand.
#74
Liked 1,384 Times
I started using a little less drip wax per application, but slightly more frequently with more frequent cleaning with the park cyclone. Bike sounds great, less accumulation of visible crud, but wear rate appears identical.
latest chain is almost reading .5 on the checker, at 2,000 miles. Measuring it carefully under moderate tension suggests the same. Thinking i might bite the bullet and replace it now to save my 11t and 12t this time… although they’re pretty cheap.
Squirt user here. I would guess about 2-300 miles between applications, but in the summer I wash my bike that often anyway, so reapply. Dawn dish liquid gets my drivetrain sparkly clean.
But in the cold, wet salty days.....those are inside days for me. And it's not because I want to keep my chain dry.
