Go Back  Bike Forums > Bike Forums > Professional Cycling For the Fans
Bike Fit Question: Change your crankarms, lower your seat?
Professional Cycling For the Fans Follow the Tour de France,the Giro de Italia, the Spring Classics, or other professional cycling races? Here's your home...
Old 03-11-10, 05:53 AM
xfimpg
xfimpg's Avatar
Bikes: RichardZEP
Quoted: 21 Post(s)
Hi Everyone
My current bike configuration has 172.5mm cranks.
If I reduce my crank length to 170mm, would that mean lowering the seat by 2.5mm or 5mm?
xfimpg is offline
Likes For xfimpg:
Old 03-11-10, 06:05 AM
Metzinger
Primate
Metzinger's Avatar
Bikes: Concorde Columbus SL, Rocky Mountain Edge, Sparta stadfiets
Liked 5 Times in 5 Posts
You should be able to raise the seat.
The measurement saddle-to-pedalstroke-bottom will reduce by 2.5mm.
Seat should be able to come up that amount.
Metzinger is offline
Likes For Metzinger:
Old 03-11-10, 06:59 AM
xfimpg
xfimpg's Avatar
Bikes: RichardZEP
Quoted: 21 Post(s)
I'm not sure that I follow.
If my crankarms will be shorter, I will therefore be lower to ground - 2.5mm so to speak. If I want to keep the same pedal-to-seat length ration, would I not be lowering my seat?
xfimpg is offline
Old 03-11-10, 07:41 AM
Metzinger
Primate
Metzinger's Avatar
When trying to picture a mechanical relationship, it helps to imagine extremes.
Picture:
a: cranks so long they hit the ground. It's hard to reach the pedals because they're on the ground at full extension. Lower your saddle so you can reach those distant pedals.
b: 1cm cranks. It's easy to reach the pedals because they're basically at the level of the bottom bracket. Raise your saddle so you can extend your leg more.
Old 03-11-10, 07:49 AM
xfimpg
xfimpg's Avatar
Bikes: RichardZEP
Quoted: 21 Post(s)
Picture:
Yes! You're right, because you're measuring from the bottom of the stroke.
I'm so glad there are smarter people out there than me.
Thanks!
xfimpg is offline
Old 03-11-10, 03:47 PM
umd
umd's Avatar
Bikes: Specialized Tarmac SL2, Specialized Tarmac SL, Giant TCR Composite, Specialized StumpJumper Expert HT
You lost?
umd is offline
rekon
Road Cycling
17
01-13-15 03:38 AM
Long Tom
Road Cycling
13
03-15-14 05:57 PM
thook
General Cycling Discussion
21
04-13-11 09:21 PM
KasbeKZ
Road Cycling
5
04-19-10 06:45 AM
