JACO Bike Air Chucks
I got those 2 JACO air chucks and they work fine. I only have Shrader, so i couldn't test the Presta.
I first didn't realize there was instructions included and didn't do the screwing on and it leaked on some valves. So thanks for posting the video above, which made me look for the instructions :-)
You have to be a bit careful screwing on to not cross-thread the valve thread. not sure if this is an actual danger, though.
I also got the JACO 100 psi digital gauge (0.5% = 0.5 psi accuracy). https://smile.amazon.com/dp/B07VV78R...roduct_details
i also got this 100 psi analog inflator. FWIW, at my car it is within 1 psi of what the JACO shows. So good enough. https://smile.amazon.com/dp/B07RVHPW...roduct_details
it would be nice if they had an inflator combined with the 100 psi digital gauge. Look at the ASME classification. The "A" for example is 1% accurate in the middle of the scale, but 2% at 25 and 75%. Mine is "2A" and is 0.5% at full scale (note it says working range 5-100 psi, so the accuracy at under 5 psi will be crap). https://jacosuperiorproducts.com/col...curacy-100-psi
The above listed JACO inflator has a 200 psi range at 1%, so that is +/1 2 psi vs. mine that is +/- 0.5 psi.
I got mine yesterday and tried it on presta mode on one of my bikes.
Followed the instructions and it worked great with my digital inflator.
I supported it with one hand to prevent any leaking which I am not sure is necessary but easy to do.
Hopefully it will last.
Quoted: 18319 Post(s)
Liked 15,288 Times
at myself. I confused this thread with the Jack the Bike Rack thread and thought to myself "What is this dude talking about?" when I read your post.
