Numbness in fingers and elbows - Glove recommendation
Quoted: 2332 Post(s)
Liked 2,097 Times
Isn't fore/aft determined by balance, meaning the bent torso puts little weight on the hands or the reverse where this would tend to load the shoulders where the median nerve can be impinged causing hand numbness. It is often the left arm
I doubt the problem is gloves.
Likes For GhostRider62:
Quoted: 6166 Post(s)
Liked 4,783 Times
Part of that equal and opposite reaction thing we were taught a long time ago.
Think about it. If your saddle were also a scale, and you were not pushing on the pedals. Then consider what would happen to the weight it shows when you are pushing on the pedals. The amount of power you use to push on that pedal at any one particular moment will affect how much weight the saddle is carrying.
Similarly it affects the weight on your other attach point to the bike which is your hands. But balance of your body over the BB for your power vector affects how much weight is on either.
Also, there is some core body strength maybe could be sort of though as a working similar to a cantilever to relieve weight on your hands also. (Probably technically an incorrect analogy, but go with it). After all, you can only bend so far. The stronger your core is to hold your upper body in a certain position, then also the less weight on your hands.
Likes For Iride01:
just another gosling
Quoted: 3880 Post(s)
Liked 1,933 Times
Bending the elbows is good and solves some problems. But elbow bend should be independent of bar height, unless one were lowering the bars more than max hip angle would allow, which does point to the possibility that getting one's hip angle measured might be a good idea. My guess is that's not an issue with the OP since they found increased power and muscle activation after lowering the bars. That makes sense.
Other than that, yes, gloves with an ulnar nerve relief channel will help a lot. What helps a lot more is proper hand position, meaning the exact way one holds the bars. It's not always obvious what that is. We have a very good explanation of that in the famous Numb Hands post:
https://www.bikeforums.net/road-cycl...l#post12953035
And yes, using saddle setback to manage hand weight is the way to go, though as Numb Hands mentions, more reach will also reduce hand weight. Saddle setback first, then reach.
Results matter
Results matter
Likes For Carbonfiberboy:
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2560 Post(s)
Liked 5,589 Times
Followed the advice contained in the first video and went on a 50 miler today and had no problem today, for the first time in months. Thanks for posting.
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
Likes For rsbob:
Asleep at the bars
Quoted: 234 Post(s)
Liked 203 Times
You could have excess weight on your hands for many reasons. You might lack the core strength to maintain a light touch on the bars for the full duration. Or there could be a fit issue where you're too far forward of the BB. Your weight should be centered over the forward pedal spindle, slightly in front of the BB, when pedaling. Think of your seated position with your butt on the saddle, hands on the bars, and pedal/BB as a triangle that can be rotated around the BB point at the bottom. Moving either of saddle or bars requires moving the other to maintain the same geometry, and the effect of doing so is mainly to shift your front or back. Another way of viewing it is that the weight should be over the BB, and the other two points are adjusted for fit, but changing one requires changing the other; for example, to reduce reach (the top side of the fit triangle) requires moving both handlebars and saddle, or your weight will no longer be over the BB.
"This 7:48 cycling session burned 5933 calories. Speed up recovery by replacing them with a healthy snack." - Whoop
Likes For sfrider:
Cheerfully low end
Quoted: 644 Post(s)
Liked 1,044 Times
I recently started road biking again. Rides are typically 20 miles, with a 40 miler on the weekends. I am not wearing gloves - b/c they are falling apart. I did feel some mild numbness on these rides, but the numb feeling dissipated quickly after the ride.
For the last 2 rides (20m, 40m) I flipped my stem (90mm, 10* ) right-side up. When it was upside down it gave me a more upright position. When I flipped the stem, my handlebar stack height was lowered by 22mm & my handlebar reach increased by 5mm. The position feels great - i'm riding faster with less quad soreness post ride. I feel I'm generating more power from my hips.
On the 40 mile ride is I was feeling numbness in both hands. (Pinky and ring finger). It was worse on my left hand. After the ride my left elbow was numb. It's the ulnar nerve.
Does anyone have a good padded half finger glove recommendation?
Stem is Upside down
Stem is right side up.
Stem is Upside down
Otto
Bikes: Canyon Ultimate CF SL Disc, Canyon Spectral
Quoted: 73 Post(s)
Liked 24 Times
Update
** My left hand and elbow were numb for a few days. I decided to lay off the bike for a few days.
**I moved the seat up 20mm. That works out to half way forward. I went for a 15 mile ride 6 days after initial numbness ride. Hands felt good. But I had a slight right knee pain. The pain was on the top of the knee. After the ride I was fine.
** I slide the seat back 10mm and went for an 18mile ride this morning. Less pain in the right knee and it was more in the center of the knee. Hands felt fine. Knee was fine after the ride.
I'm going for a slightly longer ride tomorrow morning. Will report back.
I'm riding gloveless. I ordered a couple of pairs from Amazon and I'll see which pair's padding doesn't impinge my ulnar nerve.
Thanks for all the advise.
Quoted: 73 Post(s)
Liked 24 Times
Made one more change last night. I noticed the hoods on the handlebars were cocked in toward the center of the bike. Not sure why they were setup that way. I read in one of the articles a user posted above that the wrists should be perpendicular to the flats on the handlebar. I straightened them out.
Did a 18mile ride today and I felt pretty good. Less pressure on my hands. Hopefully I can get a 30 miler in tomorrow morning.
Before and after shot of the handlebars:
Quoted: 30 Post(s)
All great info, but I'm so glad core strength was finally mentioned in addition to ditching padding gloves for an unpadded version as well as a proper bike fit. Strengthening my core has been crazy effective in relieving many of my pain points on the bike. It'll allow you to take unnecessary weight off your hands, feet, and saddle at different times during your ride.
Bikes: Shmikes
Quoted: 10147 Post(s)
Liked 5,838 Times
Stem is Upside down
Stem is Upside down
