Clunker 100 Challenge COVID 2.0 edition #7
#76
Quoted: 350 Post(s)
Liked 276 Times
After a few pulls on the frame I was able to work the seatpost loose. I hit it some with a Scotchbrite to clean off the embedded rust and paint.
Now to switch ends and go after the stem. WD40 and oil to soak.
**This is a factory installed CTA stem. Does it have a wedge or an expanding quill? I tried driving it out from the opposite end of the fork but had no luck.
#77
updates on the red Mixte, we have good news and bad. The good news is i found one tire for 15 bucks, basically brand new. the bad news, the derailleur is ruined. The good news, i found another one.
If all goes well, this thing will be cleaned up, have 15$ fenders, a 10$ derailleur, and a tire for 15$. Just over 61$USD. Also, im thinking of cleaning up the derailleur and seeing if i can make it hold chain tension, and just swapping out the cog, so i can maybe use the "new" simplex on my blue Mixte, so as to have it more original.
Likes For Ayeobe:
#78
Quoted: 350 Post(s)
Liked 276 Times
While the handlebar stem was soaking last night, I decided to tackle the missing seatpost clamp on the Peugeot. I had already found a steel seatpost clamp in my pile of crap, so I robbed the upper piece along with the hex nut and bolt. Now I needed to fabricate the lower half of the clamp. Peugeot made these from delrin and so often times, they broke. I don't think that they are readily available, definitely not for this build anyway. I have lots of wood in my shop, and had thought of making the lower clamp from this, but then I would have to make the concave radius somehow. While digging through the wood, by a stroke of luck, I noticed the ductwork on my dust vacuum. I abandoned the wood idea and began looking for a piece of leftover PVC drain pipe. I found said piece and compared the seatpost to the ID and it was a very similar radius, so I cut a section from the pipe and then quartered it. With some C-clamps and PVC glue, I laminated my cradle together.
Likes For tyler_fred:
#79
Quoted: 350 Post(s)
Liked 276 Times
After allowing sufficient time for the glue to dry, I started trimming the excess on the miter saw. I used locking pliers to hold while cutting. Through the trimming process I lost a layer of the laminate due to insufficient glue and a slight gap. I thought I would had to start over, but this was a blessing because three pieces was too thick. So now with a two-piece laminated clamp, I cut two shoulders on the table saw and knocked the edges off with a belt sander. I drilled the bolt hole and gave it a trial fit.
#80
Quoted: 350 Post(s)
Liked 276 Times
More pics of the process..
#81
Shifting is fun!
Bikes: Yes, please.
Quoted: 2193 Post(s)
Liked 4,587 Times
Nice work, tyler_fred!
Likes For non-fixie:
#82
Shifting is fun!
Bikes: Yes, please.
Liked 4,587 Times
Got the bottom bracket and headset back in place on the France-Sport and spinning smoothly:
I am currently trying to deal with the rust on the frame and particularly the seatpost, although mrs non-fixie doesn't seem to mind the rust much, as long as it is non-structural. Which it isn't.
What she will mind is the saddle that came with it. She is definitely not going to ride that for more than a couple of hundred yards:
So I need to find a replacement for that within budget. She like the Brooks S models, but that will be a challenge ....
BTW, I also found a serial number. 5601:
#83
Quoted: 887 Post(s)
Liked 335 Times
I have some questions before I enroll in the contest..
1. Do previously owned MAFAC brakes equate to the Weinmann brakes that came with the project?
2. Do you get a credit for replacing an adjustable stem from the vintage bicycle population. If so - which cheap stems qualify?
3. Do you get credit for installing the wrong bottom bracket? I hope so.
4. May original stem shifters be equal to salvaged and shabby bar end shifters?
#84
The dropped
Bikes: Pake C'Mute Touring/Commuter Build, 1989 Kona Cinder Cone, 1995 Trek 5200, 1973 Raleigh Super Course FG, 1960/61 Montgomery Ward Hawthorne "thrift" 3 speed, by Hercules (sold) : 1966 Schwinn Deluxe Racer (sold)
Quoted: 1739 Post(s)
Liked 1,014 Times
You get out what you put in, but we want you to 'compete'. If you suffer from a condition that prevents safe use of stem shifters or DT shifters, we're not going to cry foul about it.
But you ride that plastic ass hatchet the bike came with! No excuses there.
#85
Quoted: 350 Post(s)
Liked 276 Times
Thou wicked stem, I shall smite thee into submission. Release thyself thou wicked abomination!!
#86
Likes For Narhay:
#87
2k miles from the midwest
Quoted: 525 Post(s)
Liked 931 Times
tyler_fred Was that the "Pickle fork and a big hammer" technique?
#88
Quoted: 350 Post(s)
Liked 276 Times
Dylansbob I have no pickle fork..thankfully this bike doesn’t have ball joints.
This was strictly oil, WD40 and a ball peen hammer and lots of impatience. lol
#89
Quoted: 350 Post(s)
Liked 276 Times
Narhay Along the lines of dweenk’s questioning, this Peugeot came with a non-stock Shimano 105 rear derailleur. It works fine but looks so out of place. I have a Campy 980 derailleur that would look so much better. I assume I would have to account for the 980 value..or maybe not?!?!? Remind me again.. How does this bribery thing work?
#90
Well, leave it to me to find a reason to buy another bike. I was keeping an eye out for suitable candidate, and found this 1970 Schwinn Typhoon. Compared to the asking price, I sent the seller a real low-ball offer. Got it for $100. The seller says his neighbor was the original owner and put it out on trash day. Let's see how I can pretty her up for $0. I'm thinking I might do a full Evaporust dip (why not) and overhaul everything else.
I am somewhat troubled by how much I like it. I was looking for something stupid like an auto bike or goofy off-brand cruiser, but these middleweight Schwinn's are probably my favorite bikes to work on. The paint, chrome and mechanics almost always turn out awesome. Fortunately, I got all kinds of free parts after talking to the seller of my previous Schwinn, I'm pretty sure I got some free new-ish tires that will work.
I'll probably give it to a friend or something when this is over. I have a 1964 Typhoon that I built into a ridiculous klunker, and non-cycling people love riding it. They're awesome loaners.
And here's my silly colorful typhoon klunker-
Likes For J-Shooter:
#92
Quoted: 3804 Post(s)
Liked 6,643 Times
Possible entry is now in the house, $35 later. I probably paid too much given that it's a fully steel (rims, bars, stem, frame, chainrings) beast that needs work to make it rideable. Still, perhaps there's potential. The frame brazing is very clean, the lugs quite nicely lined, and the headbadge is cool. I imagine it was made in Taiwan or China, but I'm getting a UK vibe with this somewhat British-sounding marque. A full repaint would screw up that nice lug lining, so I'm thinking a barber poll seat tube and downtube contrasting panel might be fun. Not sure about components or setup. Single-speed maybe.
Sorry about the odd lighting.
Chang-Star Weinmann/DiaCompe knock-offs!
Cool headbadge.
Lugged and lined.
SunTour drivetrain.
Cool headbadge.
Lugged and lined.
SunTour drivetrain.
Likes For nlerner:
#93
Edumacator
Quoted: 2434 Post(s)
Liked 3,108 Times
Cool headbadge.
Lugged and lined.
SunTour drivetrain.
Cool headbadge.
Lugged and lined.
SunTour drivetrain.
#94
Quoted: 350 Post(s)
Liked 276 Times
Very cool head badge. Reminds me of a handlebar engraving. Looks vey Cinelli-esque.
#95
Bikes: Yes
Quoted: 3230 Post(s)
Liked 3,865 Times
Were they trying to break the saddle rails? That's really far forward.
That drivetrain is very nice for a clunker. That's like what I usually wish I could upgrade to but don't have the budget for. Maybe I shouldn't be starting with such crappy bikes to begin with.
I'd be worried that replacing the steel wheels would blow my budget, but rumor has it you have a "wheel grotto" at your disposal.
My Bikes
My Bikes
#96
Liked 6,643 Times
That saddle is actually in decent shape; not sure when it was last ridden. The seller had a storage locker alongside the Boston waterfront in a really old warehouse building. The stuff there seemed like the product of various cleanouts.
#97
Got everything but the frame and wheels into my Evaporust tank. There's also a chainring off a 1964 HVZ Meteor in there. I'll probably flip the fenders over tomorrow so I can get at the other side. The stem bolt was much rustier than any other part of the bike, we'll see how it cleans up. Probably wasn't necessary, but I'm interested to see how the chrome looks when it's all said and done. I had a mini freak-out over how many bikes I have (20?!?), what's the optimal # for you guys? I have a couple I'll never fix up, but they're great parts donors. I'm sending a few to the big dumpster in the sky later tonight. At least this guy probably won't be sticking around forever.
#98
Edumacator
Liked 3,108 Times
I need a bike thrift store near here. Actually that would probably be a bad idea...
#100
Liked 6,643 Times
Likes For nlerner:
