New Heavy Rider Feels Unsteady on the Bike
New to the forums. New rider (6'4", 350lbs) looking to try out cycling. Starting out with little/no experience -- haven't ridden a bike since I was a little kid. Went to a local bike shop and ended up getting a Trek Verve 2 Disc Lowstep. Question:
Does the correct seat height make it so your toes barely touch the ground?
The guy at the bike shop said the seat was set at the right height. Since I haven't ridden a bike in decades, I'm pretty unsure/unsteady on the bike (since I can't stand with my feet flat on the ground) and it makes me feel like an anxious kid – I assume I will have to re-learn being on the bike? Is this feeling normal?
Appreciate any advice.
Thanks.
Thanks.
Bikes: Most of my bikes are Single Speed Conversions
Quoted: 267 Post(s)
Liked 3,067 Times
Lower the seat a little until you get your cycle legs back . A seat too high is bad on your knees anyways . One too low just makes you work more .
You can worry about having the “ correct” height after you’ve lost a few pounds .
Good luck with your endeavor .
Likes For OldCruiser:
Expired Member
Quoted: 3665 Post(s)
Liked 5,412 Times
I agree that it won't hurt anything to lower your seat until you get confident on the bike. Probably as long as your rides are under a hour or so you won't hurt anything. At some point you'll want to move it back to where the shop set it.
Likes For shelbyfv:
Bikes: Velo Orange Piolet
Quoted: 2228 Post(s)
Liked 2,011 Times
WOW, are you riding a very small bike? I can't do that, no way on a 58 being 6'1. I have to slide off the seat at full stops. If I remained on the saddle and leaned to my left, I'd pretty much be a really wide A frame structure.
Against a curb, yes but on on flat gorund.
Likes For tyrion:
Mad bike riding scientist
Quoted: 6218 Post(s)
Liked 4,217 Times
As for riding with the saddle too low, it isn’t easier on your knees, it’s harder on them as well as harder on your quads. When setting up a new bike, I can instantly tell if my saddle is too low because my knees ache.
Stuart Black
Stuart Black
Likes For cyccommute:
Quoted: 229 Post(s)
Liked 327 Times
My wife has the same bike as you and it's currently slaved to our smart trainer. And, yes, toes barely touching the ground is about the correct saddle height. The benefit of the lowstep is you can stand off the saddle with both feet flat on the ground.
Thanks.
Thanks.
Appreciate all the responses and advice so far.
Unfortunately, the seat is already as low as it can go on the size Trek Verve 2 that I have. So I'm under the impression that the lowest seat setting on this frame also happens to be the correct seat height for me. Plan to go out to a parking lot this weekend to test things out for the first time.
Likes For jca2112:
Quoted: 267 Post(s)
Liked 3,067 Times
Shops and size charts try to put people onto bikes based on their height . A better way would be stand over and inseam , IMO .
I’m 5’11” but have a 28” inseam . I have a heck of a time fitting a bike .
With my medium Specialized Rockhopper, I had to cut the seatpost to get it low enough to where I didn’t have to leap off it when I stop .
If you’re cursed with short legs like I am , you may want to check out the crank length . I was about to give up biking until I figured out the 175mm cranks I had on several of my bikes were destroying my knees .
Bikes: 1996 Trek 970 ZX Single Track 2x11
Quoted: 614 Post(s)
Liked 565 Times
Most cyclists don't size it such that sitting on the seat while riding allows the feet to touch the ground. Most bikes with a reasonable fitment for a rider have a taller seat height than that.
But there are some exceptions. The Electra Townie bike comes to mind. With its "feet forward" placement of the bottom bracket, the pedals are noticeably ahead of the saddle compared to a typical bike. Particularly in the low-step variants of the Townie line, a relatively low seating position can still work with proper fit and pedaling, yet still afford easy reach to the ground. (In my case it did, last time I took one for a spin, and I've got pretty short legs for my height.)
If you purchased from a dealer, they ought to be able to help you identify if your bike's size and fitment is the correct one for you.
The parking lot idea is a good one. One with lots of space, no cars, no obstructions to run into or worry about. And likely lots of lines to practice weaving around, following. Until you get your "sea legs" (balance), it's a good idea to spend numerous sessions in that lot until you're not having to think about the balance aspect. Be sure to practice lots of stops and starts, to get comfortable with the sequence of steps that works.
Might turn out the feeling of "instability" on the saddle simply isn't about the seating position or the ride height off the ground so much as just the basic balance question of keeping the bike moving forward and in control.
Once you've nailed the balance aspect, you can then revisit the position on the bike in relation to the ground, and your ability to safely stop and start the bike touching the ground. With most people and most bike fitments, it'll involve feet on the ground while standing in front of the saddle, placing one foot onto the pedal, then riding forward balanced as you move up onto the seat. (As kids we also used to be running alongside the bike, placed one foot on the nearest pedal, then swung the other leg over as we sat down.) It'll take a little experimenting to see which method feels safest and easiest to accomplish. I suspect standing across the top tube forward of the saddle then placing one foot on the pedal as you move forward will turn out to be the method that'll feel most comfortable. At least, for starters.
Some years ago, dealing with old leg/hip muscle injuries, I found that I'd lost my ability to be stable on a bike saddle. Acquired a previously-owned $20 Next LaJolla low-step bike. (Not a quality bike, but it was the right size for my situation.) Big wide padded saddle, feet-forward pedaling arrangement (in relation to the saddle), and very easy to get onto and off of. The low-step frame design really helped with on/off. I deliberately acquired a smaller one than reasonable, until I got my hip stability and balance back. Took only a few days of tooling around for the balance aspect. But, the muscle damage in my hips/legs took awhile to get the stability strength back. After a year, I was going along like it was just any other bike (that long, due to the injuries). Got a "proper" bike at that point, once my injured muscles had gotten stable and strong enough to handle.
You might find the balance question quickly resolved, once you get a few weeks' of riding in. You might find the ease of getting on and off the bike to be more problematic, if the sizing is in question. If you're already bottomed-out with the saddle it might well be a bit large for you, but that's a general fitment thing the dealer (or any dealer, really) ought to be able to assist with.
Likes For Clyde1820:
Bikes: 1986 KHS Fiero, 1989 Trek 950, 1990 Trek 7000, 1991 Gary Fisher Hoo Koo E Koo, 1992 Trek 1400, 1997 Cannondale CAD2 R300, 1998 Cannondale CAD2 R200, 2002 Marin San Rafael, 2006 Cannondale CAAD8 R1000, 2010 Performance Access XCL9R
Quoted: 284 Post(s)
Liked 385 Times
Quoted: 284 Post(s)
Liked 385 Times
Thanks.
Thanks.
Pic provided to show where I've been and where I am now. So the left was me 32 years ago, about 225. Middle was 6 years ago about 350. And the right was 2 years ago, about 245. Same bike though, just a lot of changes over the years. Sort of like me... Oh, I'm 6'1"...
I suspect your bike is too small for you if you can touch the ground from the seat. But. I was pretty unsteady on my bikes at my heaviest weight of 378. Even on my indoor trainer I felt I could fall over at any point. And that is a very uncomfortable feeling.
After breaking my back in a cycling crash 10 years ago, I wasn't on a bike for 3 years. This 29er mtb was a gift at a time I needed a boost. But, I didn't feel as top heavy. It certainly boosted my confidence, so I rode from time to time.
3 years ago I got a lot of bad health news, and was up to 378. I chose weight loss surgery as an expedient tool to keep me off insulin, and other meds. Which, worked and put me in a position to be able to stay out of diabetic range, but also got me of my BP and heart meds. And reduced my pressure in my CPAP as well.
For you, I would just ride to get more steady and confident, raise your seat from that point. Your knees will thank you later.
