Himiway Rear Rim Pierced Through
Hello
My friend's Himiway Cruiser gets flats every other week, despite of Mr.Tuffy and Tannus liners installed together. But today it went overboard. Huge bolt somehow went through the rim itself. Do you think it is still rideable if cleaned and filed off? Or we need to start long, expensive and painful process of rim replacement?
Thanks
Thanks
Likes For cat0020:
Fat tire bikes have lightening holes drilled in the rims that the rim strips cover up. I dont see any reason why you cant do a similar thing. I doubt if the typical rubber liner would work, but I'm sure you can find some sort of stiffer polymer to keep the tube inside the rim.
-SP
-SP
Likes For speedy25:
Clark W. Griswold
Quoted: 4342 Post(s)
Liked 3,978 Times
Would you want to ride a rim like that? I wouldn't.
Ride more, eat less
Quoted: 713 Post(s)
Liked 735 Times
Pre-drilled rims can save good amount of weight from the rims, combine with quality wheel build they can result in strong reliable wheels.
Depending on your usage, that may be a good option.
Quoted: 668 Post(s)
Liked 529 Times
Have to agree with veganbikes on this one. You need a new rim.
Likes For Pop N Wood:
Clark W. Griswold
Liked 3,978 Times
Keep in mind rims drilled with holes were designed to have those holes. This was not a hole that was designed to be there.
Likes For fooferdoggie:
Quoted: 18369 Post(s)
Liked 4,507 Times
That hole looks like it has dented the rim slightly going in. But, if the wheel can be trued, and the nearby spoke brought up to reasonable tension, the rim will likely have a long life.
I'd probably remove the bolt and the nearby spoke.
Then work on flattening the rim with a hammer, anvil, and perhaps a couple of blocks of wood. Reassemble, tension, and true up the wheel.
What does it look like if you remove the rim tape, and rotate it 180° and reinstall? Is it rubber or plastic?
Liked 4,507 Times
It might take a little hunting, but you should be able to find a reasonable replacement rim for about $50. Plus, of course, the work to swap the rim over.
I'd clean up the wheel as above, then decide if you wish to rebuild.
