Help Identify this CX/Gravel Frame (non-vintage)
Honorary Bicycle Rider
A friend gave this frame to me and he thought it was a Nashbar Frame, but since he also received used it could not be confirmed.
Serial Number: GW12L00782
Steel Frame (~26.6mm seat post diameter)
Tapered headset 44mm on both ends
135mm rear spacing
Both V/Canti and Disc Mounts
135mm rear spacing
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
Here's a Nashbar CX frame -- kinda/sorta similar, with the top- and down-tube gussets, top-tube cable stops, and rear brake cable guide. But I don't see the tapered headtube, and the seat tube/seat stay junction is different, so maybe yours is a more recent model?
Randomhead
Liked 3,687 Times
That doesn't look like a steel frame to me, got a magnet?
I'm not sure what the benefit of identifying it is. It's not a valuable frame.
Magnet sticks, steel frame.
I just wanted to know if I build it and based on quality what other parts ($) belong on it.
Quoted: 2952 Post(s)
Liked 3,106 Times
Are you sure it's meant for 700c wheels? Maybe it's just the angle of the photo but the chainstays seem short and the brake bosses kinda low. Could it be an old-school 26-in mtb frame?
Guest
Liked 3,270 Times
Not positive, but this might be it. The seatstays still look different, though. Discussion can be found here: https://www.mtbr.com/threads/cheap-f...ntent.1018242/
Likes For kansascity:
Expired Member
Quoted: 3657 Post(s)
Liked 5,393 Times
Likes For shelbyfv:
