ISO and for trade thread part 5
Old 11-18-22, 12:01 PM
  #5376
jethin
jethin's Avatar
Quoted: 238 Post(s)
Liked 197 Times in 108 Posts
Thanks! The nut is a 7mm x.75 and at this point, the most critical
Gran Sport. Unsure about compatibility.
jethin is offline
Old 11-18-22, 12:21 PM
  #5377
JohnDThompson
Old fart
JohnDThompson's Avatar
Quoted: 3193 Post(s)
Liked 2,502 Times in 1,471 Posts
Gran Sport pedal axles, cones, and locknuts will interchange with Record and Superleggero. The biggest difference is that the Record and Superleggero axles are rifled to help prevent contamination, while the Gran Sport are smooth.
JohnDThompson is offline
Likes For JohnDThompson:
Old 11-19-22, 06:50 PM
  #5378
Stevensb
Stevensb's Avatar
Bikes: Condor, Cinelli SC, MKM Metcalfe, Peugeot AE08, Bianchi, Cougar, Miyata, Harry Hall, Holdsworth Special, Raleigh Int'l, Le Croco, Bob Jackson, Zeus
Quoted: 103 Post(s)
Liked 93 Times in 49 Posts
Campy NR Globe gum brake lever hoods
Does anyone have a good, recent source of these hoods. So many of them online look like they're made of the wrong rubber.
thanks.
Brad
Better bike .. Better life!
Stevensb is offline
Old 11-20-22, 07:29 AM
  #5379
Schweinhund
Captain Dorkdisk
Bikes: More than I need, less than I want.
Quoted: 213 Post(s)
Liked 333 Times in 168 Posts
I need an ST-M071 left shifter (ft) repaired does anyone in this forum provide that as a service?
Schweinhund is offline
Old 11-20-22, 12:11 PM
  #5380
unworthy1
Stop reading my posts!
unworthy1's Avatar
Quoted: 1098 Post(s)
Liked 648 Times in 507 Posts
have you confirmed there are parts actually broken inside the unit? Cause if it's merely stopped shifting (as often occurs with age) the easy cure is to flush out the old dried up grease with a big long bath of WD-40 or PB Blaster and working the mech until all grease has softened up and moved along.
It's messy (wear gloves and use a bunch of cloth rags) and takes time but nearly always does the job.
After air-drying the works, spray in a light weight lube of your choice, it won't be as durable as the OEM grease so you'll need to repeat lubrication periodically, but DON'T rely on the flush-out fluid to be your lube.
unworthy1 is offline
Old 11-20-22, 12:47 PM
  #5381
Schweinhund
Captain Dorkdisk
Quoted: 213 Post(s)
It has a small problem...
Old 11-21-22, 08:00 AM
  #5382
Classtime
Classtime's Avatar
Quoted: 1503 Post(s)
Liked 1,126 Times in 676 Posts
Campy TT cable guide screw?
I lost one last night when the spring clip launched it over my shoulder. I think it landed on the work bench but…
I think it is a 1/2 size that my Ace doesn’t have. What size are they?
Jeff
Edit: it is a 5-40 machine screw.
Classtime is offline
Old 11-25-22, 05:58 PM
  #5383
cudak888
www.theheadbadge.com
cudak888's Avatar
Quoted: 2020 Post(s)
Liked 3,081 Times in 1,584 Posts
Need a long-cage Shimano RD for a flip that mounts to a conventional hanger - turns out all my spares are either short cage or integrated claw hanger. Doesn't have to be anything terribly specific.
Have stuff to trade. What do you need?
-Kurt
cudak888 is offline
Old 11-25-22, 06:25 PM
  #5384
jdawginsc
Edumacator
Quoted: 1708 Post(s)
Liked 1,774 Times in 1,190 Posts
-Kurt
MTB? Or standard touring? I am pretty sure I have some. Let me check.
1987 Crest Cannondale, 1987 Basso Gap, 1992 Rossin Performance EL, 1990ish Van Tuyl, 1980s Vanni Losa Cassani thingy, 1985 Trek 670, 1982 AD SLE, 2003 Pinarello Surprise, 1990ish MBK Atlantique, 1987 Peugeot Competition, 1987 Nishiki Tri-A, 1981? Faggin, 1996ish Cannondale M500, 1984 Mercian, 1982 AD SuperLeicht, 1985 Massi (model unknown), 1988 Daccordi Griffe (most not finished of course)...need to not buy any more.
jdawginsc is offline
Old 11-25-22, 07:43 PM
  #5385
cudak888
cudak888's Avatar
It's for that '88 Schwinn Voyageur I've had kicking around, so technically touring, but I'll take MTB too. Not picky, just want something that works that's compatible with the Shimano 6-speed shifter.
Have thrown too much effort and money at the thing already - the goal is simply to get rid of it with the least additional expense.
-Kurt
cudak888 is offline
Old 11-25-22, 07:56 PM
  #5386
jdawginsc
Edumacator
-Kurt
So 6 speed indexed? Or friction okay?
Old 11-25-22, 08:18 PM
  #5387
cudak888
cudak888's Avatar
Six or seven speed indexed Shimano, ideally.
-Kurt
cudak888 is offline
Old 11-26-22, 08:42 AM
  #5388
jdawginsc
Edumacator
-Kurt
Old 11-26-22, 10:23 AM
  #5389
curbtender
curbtender's Avatar
Quoted: 1302 Post(s)
Liked 1,521 Times in 797 Posts
That Deore is the ticket.
curbtender is offline
Old 11-26-22, 12:08 PM
  #5390
mountaindave
tantum vehi
mountaindave's Avatar
Quoted: 1090 Post(s)
Liked 749 Times in 396 Posts
Maybe itís my eyes, but I canít see whatís going on that needs repair.
I have used T9 to refurbish many early STI shifters. It works more often than not, but sometimes they just wear out.
mountaindave is offline
Old 11-26-22, 02:18 PM
  #5391
seagrade
Quoted: 17 Post(s)
Liked 66 Times in 30 Posts
Triumph of optimism over experience but looking for one or two sets of seat rail plastic supports and elastomer bumpers for Selle Italia Turbomatic Gel Flow saddles. I have two and while the leather cover and padding have held up great the supports and elastomers/bumpers cut out over time, which is probably the cause of the incessant creaking both now produce. EDIT - on renewed and closer inspection the creaking may be between rails and nylon base immediately aft of front mounting. Have sandwiched a piece of leather in between and will see if that improves things, but still after the supports/bumpers if any spares exist...
seagrade is offline
Old 11-26-22, 04:55 PM
  #5392
cudak888
cudak888's Avatar
[Derailer pics]
Any of those would work exceptionally well...
-Kurt
cudak888 is offline
Old 11-26-22, 05:00 PM
  #5393
wesmamyke
Quoted: 196 Post(s)
Liked 79 Times in 70 Posts
That shifter does look a little sorry. Might be worth mentioning though, many early integrated rapid fire shifter will stop working if the pod is contacting anything, like the bend in a riser or swept handlebar.
wesmamyke is offline
Likes For wesmamyke:
Old 11-26-22, 06:02 PM
  #5394
jdawginsc
Edumacator
-Kurt
Take your pick!
Old 11-27-22, 12:08 AM
  #5395
Iowegian
Iowegian's Avatar
Quoted: 99 Post(s)
Liked 8 Times in 8 Posts
Originally Posted by Dirt Road Blues View Post
​​​​​When you have time to check on what's there, I'll be interested to hear about it. Preference for rectangular, but would stoked for a pair of bear traps just the same.
I have 2 pairs of the XC-2 bear trap pedals and some Cyclone pedals that look like track pedals since the cages don't go all the way around the body, there are just 2 plates on either side. I'll clean them up and get pictures in a few days.
Iowegian is offline
Old 11-27-22, 08:01 AM
  #5396
jdawginsc
Edumacator
@merziac
@cudak888
Old 11-27-22, 09:40 AM
  #5397
Schweinhund
Captain Dorkdisk
Quoted: 213 Post(s)
Looking for a Trek System 2 rear wheel. WTB Maverick rim (Dark but not black) to go with my front. Conversely, if you're building something and you'd like this wheel... what you got?
Old 11-27-22, 11:00 AM
  #5398
SJX426
SJX426's Avatar
Quoted: 1402 Post(s)
Liked 1,673 Times in 858 Posts
I did a little work on the left pedal from post #5376. It needs a little more encouragement to get back to the original shape Can someone provide a measurement to help me determine how far to go? Or is it the same as the SL pedal?
GransSport1 on Flickr
@Jetfin sent me the pedal to provide the washer I needed. Kudos!
Now all I need is another dust cap.
SJX426 is offline
Likes For SJX426:
Old 11-27-22, 11:08 AM
  #5399
unworthy1
unworthy1's Avatar
a 26" rim, right? If so: 130 or 135 spacing?
I MIGHT have had one in the recent past, will check if anything's still in my "pile".
Old 11-27-22, 11:15 AM
  #5400
Schweinhund
Captain Dorkdisk
Quoted: 213 Post(s)
Don't have a specific build in mind, so yes? even 126 is on the table, lol.
What I'm trying to match
Likes For Schweinhund:
