Confirming I can run this Shimano setup of mixed parts.
Old 11-25-22, 01:15 PM
jamesdak
Bikes: Paletti,Pinarello Monviso,Duell Vienna,Giordana XL Super(2)Lemond Maillot Juane (2) & custom,PDG Paramount,Serotta CSI,Fuji Opus III,Davidson Impulse,Pashley Guv'nor,Evans,Fishlips,Prologue TT,Y-Foil,Softride, Tetra Pro, CAAD8 Optimo,Klein Quantum II
Quoted: 2052 Post(s)
Liked 3,046 Times in 1,218 Posts
Looking to run ST-6510 shifters with BR-6600 brakes, RD-6600, FC-6600 and then the big question a FD-7700? Obviously as a 9 speed configuration. I can't find a compatibility chart showing this but I'm pretty sure it will work.
Looking to upgrade a beautiful bike that is being held back by the lowly Exage groupset. Rear dropouts take a 130mm wheel easily.
Been googling for 30 minutes but can't find a combo like this...
Thanks!
Steel is real...and comfy.
jamesdak is offline
Old 11-25-22, 02:16 PM
rccardr
aka: Dr. Cannondale
rccardr's Avatar
Bikes: Bob Jackson, Wizard, Pegoretti Duende, Merckx ProSLX, Pelizzoli, Cannondale ST, Schwinn Tempo, Schwinn Voyageur, Canyon Endurace, Richard Sachs, Davidson Discovery
Quoted: 1886 Post(s)
Liked 2,189 Times in 840 Posts
Yep, that’ll work just fine.
rccardr is offline
Likes For rccardr:
Old 11-25-22, 02:20 PM
maddog34
maddog34's Avatar
Bikes: !982 Trek 930R Custom, Diamondback ascent with SERIOUS updates, Fuji Team Pro CF and a '09 Comencal Meta 5.5
Quoted: 616 Post(s)
Liked 60 Times in 49 Posts
info... the Front Der. is also mentioned, and will work fine with 9sp.... if you swap to 10sp. in the future you may want to swap out the front der. too. https://www.roadbikereview.com/threa...d%2010%20speed.
maddog34 is offline
Likes For maddog34:
Old 11-25-22, 02:28 PM
jamesdak
Thanks Doc! I'm used to going the other way where I run a newer STI shifter with older drivetrain but I seem to have a wealth of 9 Speed STI shifters on hand somehow. LOL
jamesdak is offline
Old 11-25-22, 03:04 PM
70sSanO
70sSanO's Avatar
Quoted: 1815 Post(s)
Liked 1,955 Times in 1,200 Posts
If they are NOS, then wealth is a good descriptor.
John
70sSanO is offline
Likes For 70sSanO:
Old 11-25-22, 10:34 PM
tFUnK
Quoted: 203 Post(s)
Liked 138 Times in 118 Posts
Not sure the 6500 shifters will work with the 6600 RD. Everything else looks like it'd get along fine.
tFUnK is offline
Old 11-26-22, 03:10 AM
KCT1986
Quoted: 168 Post(s)
Liked 135 Times in 101 Posts
This should be fine. Both RDs uses the same actuation ratio @1.7 and should work properly.
As for the FD-7700, it should work properly also.
KCT1986 is offline
Likes For KCT1986:
Old 11-26-22, 08:45 AM
jamesdak
So based on comments above I got back into my stash to look for a RD-7700 since the RD-6600 is a longer cage. Realized I have a complete set of DA 7700 parts I could put on this minus the brakes. But I do have a set of BR-7800 so could really go this route. Dang decisions......
Whatever I use is going on this bike since it's pretty much mint and deserves so much better than the Exage stuff on it. I do have some Dura Ace hubbed wheels on it right now.
jamesdak is offline
Old 11-26-22, 06:43 PM
Lombard
Sock Puppet
Lombard's Avatar
Bikes: 2014 Cannondale Synapse Carbon, 2017 Jamis Renegade Exploit and too many others to mention.
Quoted: 586 Post(s)
Liked 475 Times in 325 Posts
They will work just fine. Same actuation ratio. And the RD doesn't care how many speeds the shifter is as it just does what the shifter tells it to do.
Shimano didn't change the actuation ratio of road groups until 5800/6800/9000 when they went to 11-speed.
Lombard is offline
Likes For Lombard:
Old 11-26-22, 06:59 PM
jamesdak
Ok, just to wrap this up. Put this together throughout the day. Only change was using a RD-7700 I had on hand. Paired the parts with a SRAM 9 speed 12-26T cassette and SRAM chain. Everything seems to be working fine I just need to do some finishing tweaks and then trim and cap the cables and wrap the bars. Should come in right at 21 lbs even once I put on the bar tape.
jamesdak is offline
Likes For jamesdak:
Old 11-27-22, 04:05 AM
tFUnK
Quoted: 203 Post(s)
Glad to be corrected; learned something new.
Also glad that OP got the bike set up 👍
tFUnK is offline
