What is the purpose of this ring on my chainstay?
Bikes: 1983 Univega Super Strada, 1986 Panasonic DX5000, 1984 Fuji Team 85 Univega Gran Turismo, 1984 Lotus Unique, 1987 Centurion Expert, 1987 Centurion Ironman Master,
Quoted: 677 Post(s)
Liked 459 Times
I've never had one on any of my other bikes.
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,446 Times
Chainstay protector, to help keep the chain from slapping the paint.
Likes For thumpism:
Quoted: 4511 Post(s)
Liked 6,378 Times
Likes For merziac:
Quoted: 3464 Post(s)
Liked 2,829 Times
Should be something forward to sling a strap between
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4681 Post(s)
Liked 5,799 Times
That's a different type of brazed on bit. I think you're thinking of something like this:
Slotted tubing bits brazed on
The chainslap rubber protectors can either slide into a slotted tube as shown above, or slide onto a bit of solid rod bent up and around (they have a small hole through both ends). I can't find a pic of the 2nd method, but it's very similar to the OP's pic, except it's open on one side (doesn't loop around and get brazed at both ends).
The OP's protects the chainstay with one brazed on loop. Another classic way that used to be found is to carry spare spokes on the chainstay.
I've done two of those methods. The braze ons for the spoke method are available at framebuildersupply.com A small slice of tubing is used for the other method I showed, above.
Bikes: 1964 Huffy Sportsman, 1972 Fuji Newest, 1973 Schwinn Super Sport (3), 1982 Trek 412, 1983 Trek 700, 1989 Miyata 1000LT, 1991 Bianchi Boardwalk, plus others
Quoted: 583 Post(s)
Liked 697 Times
On the Gran Tourismo maybe? Chainstay protector as others have said. A surprisingly overbuilt solution to something a plastic sleeve would do. I have one on my 89 Miyata 1000. Actually, it is a good mechanics reminder of how good your “slack” setup is.
My 1000 had the oval Biopace rings, and obviously the oval 28t inner would noisily bounce off that with too much chain slack, or if one was cross chaining. Annoyingly, on that small 28t it would clatter unless in the 3 largest rear sprockets. Forget running a 24t or 26t front ring.
Being old and weak, I wanted some lower gearing on this bike. Switching to a round 24t and paying attention to chain length, I was able to use the largest 4 or 5 sprockets on the rear with no noise from the chain bouncing on that protector. In my case it served as a confirmation of proper setup. As a side note, those Biopace rings really make the chain bounce when on the smallest sprocket.
Liked 6,378 Times
Wouldn't even want to snap one on a good paint job.
Quoted: 3241 Post(s)
Liked 2,512 Times
Knowing the purpose of the ring, this is what came to mind when I read the thread title.
Quoted: 677 Post(s)
Liked 459 Times
Likes For robertj298:
Liked 2,829 Times
Heck, the maker is expecting that wire form to protect the whole chainstay from chain slap.
better than nuthin’
better than nuthin’
Quoted: 3810 Post(s)
Liked 6,693 Times
It’s an homage to French constructeurs.
Quoted: 677 Post(s)
Liked 459 Times
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,105 Times
Pop top?
Genesis 49:16-17
Genesis 49:16-17
Likes For Darth Lefty:
