Chris King grip nut?
Bikes: Handsome xoxo, Serotta atx, Canyon Endurace CF8
Quoted: 904 Post(s)
Liked 1,897 Times
Does this look correct? the bike tech who installed it said it is correct. every one I have seen before the lockring nut is contacting the adjusting ring. he said the gap is fine, which it may be I just have not seen a gap between the two parts before. It feels tight and it is smooth.
Quoted: 836 Post(s)
Liked 1,061 Times
Looks right. From the CK website. GripNut™ – Chris King Precision Components
Bikes: 2013 Custom SA5w / Rohloff Tourster
Quoted: 1237 Post(s)
Liked 321 Times
Good luck with that POS. I used one briefly. Not even the LBS veteran could figure the stupid things out. Near impossible to get the too small tab to stay in the notch.
I then found a nice old Shimano one that came with 15 caged 1/4" balls. I buggered one, so it now has 18 loose balls. I liked it so much I got another NOS on fleabay.
Edit .... Never mind I guess it was my installation error.
Quoted: 836 Post(s)
Liked 1,061 Times
Quoted: 904 Post(s)
Liked 1,897 Times
Likes For jadmt:
Quoted: 904 Post(s)
Liked 1,897 Times
Not sure what "small tab" you're talking about. Diagram is not showing it. GN_032004-A1page (shopify.com)
Likes For jadmt:
Quoted: 836 Post(s)
Liked 1,061 Times
Ah, OK. I just realized I didn't read your post correctly. To me that gap also looks normal. Of several that I have seen they had the same gap and my threadless CK also has the same gap. Great headset by the way, fit and forget. I clean and grease the bearings every 3 years or so which seems to be waaay overkill but for what these cost, I'm not taking any chances.
Likes For Crankycrank:
Liked 321 Times
OK I was likely installing it wrong, I just got it out and played with my broken steerer. I think I figured out what we were doing wrong.
The think I had the top 3 pieces separated, while it should be all together and almost tight already. Maybe I should also have greased the angle compression too.
And the top nut has a lip that may or not be a good idea. The top of steerer needs to be cut down precisely. So changing it to a different headset later may be a problem. I have 4 threads sticking out of mine now and have a thicker nut.
I also just didn't like the feel of the sealed bearing fit anyway. I also had a Cane Creek one at first.
Quoted: 4806 Post(s)
Liked 3,928 Times
I have owned very few headsets that were worse experiences than that Gripnut. And I am pretty certain my issues have nothing to do with the bike. (Headtube and crown facing and alignment. Nothing changed there when I went to the Tange. It pressed in like it belonged and functioned perfectly outside that one tweak to dial in the adjustment (despite having a random assortment of Tange parts to get a stack that matches the Gripnut). Now the headtube has been shaved down and the Tange drops right in. Pure joy.
Quoted: 904 Post(s)
Liked 1,897 Times
chris king got back within a few hours and said it looks correct and it is the 2Nut that does not have the gap but the grip nut does.
