Fitting a 1-1/8 stem on 1-1/4 steerer
Hello,
I have a Giant TCR that comes with an oversized steerer tube (OverDrive 2) which is 1-1/4 inch. I really like Zipp's Sprint SL carbon stem that is 1-1/8 inch, so it is smaller. Are there any options to fit such stem on the oversized steerer? Maybe expanding the stem clamp in some way so it fits on the steerer? Or use brute force?
I know it might seem a silly question (probably was asked ten times already) but I am curious what are the options (if there are any), in before changing the fork with the correct steerer or simply buying the right stem.
Thanks
Thanks
Likes For Kontact:
Quoted: 2026 Post(s)
Liked 1,095 Times
Likes For HillRider:
Quoted: 4790 Post(s)
Liked 3,918 Times
TiCycles has made most of mine. For them it is pretty straightforward although not cheap. They outsource the clamp for 31.8 bars and they'll make any shim you need to go smaller. Steerer dimension, length, angle - whatever you want. But they aren't cheap.
Likes For 79pmooney:
Quoted: 6177 Post(s)
Liked 4,794 Times
If the stem means that much to you then you should sell the TCR and buy a bike you can use that stem with. Or maybe just set it up on the mantle so you can gaze at it in the evenings and dream about how much better that TCR will have been if Giant had only designed it for and put those stems on it.. <grin>
Welcome to BF!
Welcome to BF!
Quoted: 4340 Post(s)
Liked 1,526 Times
Or have someone make one for you. (I have bikes to common standards but arms that aren't and have custom stems on most of my bikes.)
Quoted: 3370 Post(s)
Liked 5,491 Times
Years ago, when I attempted to install a new stem on a Cannondale M700, i discovered it had a 1.25" stem.
After much searching, I finally found what I needed from a tandem shop.
It is branded "Santana", but looking at Santana's site, they list "Control Tech" stems now:
https://santanatandem.com/components/
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1939 Post(s)
Liked 1,463 Times
I am generally all for CF upgrades, but I don't see the point of a CF stem, which does not save any weight compared to light weight Al models.
Likes For SoSmellyAir:
Quoted: 836 Post(s)
Liked 1,058 Times
IMO it's a no-brainer to just get the right stem. Changing the fork brings up all kinds of potential issues such as finding another fork that has the same rake/trail, length, same disc caliper mounting, color, new headset bearings,etc.
Quoted: 513 Post(s)
Liked 445 Times
And getting a top bearing with a 1-1/8" ID and an OD and bevel that matches the head tube on the giant. And would cost $300-400 for the privilege of such a fishing expedition.
Likes For wheelreason:
Quoted: 5766 Post(s)
Liked 2,538 Times
It may not be cost effective, depending on access to the required tooling, but it's not impossible.
A 1-1/4" steerer has a 1-1/8" ID. So, an expandable tube can be fitted and extended above the existing tube. You'd also need a structural washer to be a base for the stem and allow it to press a stack of spacers and load the headset. A long expander draw bolt would complete the job, doing double duty as expander bolt and headset loading bolt.
If I were doing this (not that I would) I'd also consider cutting the steerer down to reduce the overall stack height. So, while it's not ideal (or even close) is is doable if, for some reason or another, one is committed to using a 1-1/8" stem on this bike.
Now that the OP knows it can be done, and how, It's his decision whether he wants to or not.
FB
Chain-L site
FB
Chain-L site
Likes For FBinNY:
Liked 1,526 Times
Why would it be safe to put an expander in a carbon tube? The steerer would almost certainly split.
Likes For Kontact:
Liked 2,538 Times
In any case, the reference to "adequate tooling" implies making rather than buying. Also, it's not at all difficult to use an expander to generate enough traction for the purpose without damaging a CF steerer.
FB
Chain-L site
FB
Chain-L site
Liked 1,526 Times
FWIW, I offered this as a mental exercise, and thought I adequately I qualified it as such.
I guarantee you that an expander inserted and tightened enough to prevent the bearings working loose would cause the steerer to fail at the base of the expander, causing a horrendous accident. Carbon has very little crush strength, but we get away with clamping stems because that is compression and there's a plug. An unreinforced steerer being pushed out would yield almost immediately.
That's some extremely dangerous advice. It doesn't take much more than a few items from the hardware store make what you describe, so it wasn't a silly hypothetical that no one would do. Hopefully no one ever reads your post without reading the follow on, because your idea could get someone killed.
Please delete it.
Likes For Kontact:
Liked 2,538 Times
Every of your objections is surmountable. Also my closing sentence was an argument against it.
So, sorry, but I'll let it stand as is.
FB
Chain-L site
FB
Chain-L site
Liked 1,095 Times
Instead of making a metal steerer extension/reducer why not make a carbon one and glue it in place using a strong epoxy.
Liked 2,538 Times
Thanks for the thought, interesting. What about doing something to the stem? It's a carbon stem but I just thought maybe there is a way to expand its clamping area somehow? Could it be possible to use sandpaper or something similar to sand down the carbon? Do you think this would be a more practical or realistic way of fitting the stem?
There are no rules; it's always about the situation.
So, the answer depends on how much material and it's strength. Is there enough to remove 1/16th inch per side, and is there enough left to do the job?
It's fairly easy to make this call with metal, but with CF, you'd need to know where the CF is vs. resin.
Whether and how you opt to procede, keep in mind that there are other considerations, so it becomes a complicated judgement call. odds are you'll encounter unforseen issues to overcome. It's a case of whether there's sufficient reason to bother, and your own skill set.
As always, being able to do something, doesn't imply that you should.
Likes For FBinNY:
Quoted: 2337 Post(s)
Liked 2,811 Times
as noted before, no practical options
Anything else is a theoretical kludge at best, more likely non workable in reality
failure in the area of the fork/stem is likely painful
Just use the right size stem
Likes For squirtdad:
Quoted: 513 Post(s)
Liked 445 Times
Liked 1,526 Times
Why aren't you taking the excellent advice to buy a 1 1/4" Zipp stem instead of inquiring about complicated forms of suicide? The people egging you on have zero experience with anything being discussed.
Likes For Kontact:
Liked 1,526 Times
Should you be advising people about modifying a technology you don't understand the basics of?
