SRAM TRX Trigger Shifter - Help
Hi all, my 3 speed SRAM TRX Trigger Shifter are ok but the rear 7 speed SRAM TRX Trigger Shifter, seem to have broken. Well it wouldn't click no more so I took it apart and all the bits came out,
( Which I have no clue where most of the bits go) I noticed the red plastic bit inside is broke. ( See pic's below) I can't seem to find a replacement part for that bit. So what shall I do? Glue it or buy a whole new 7 Speed SRAM TRX Trigger Shifter just because of that 1 bit that is broke ''Sign''
Here are some pic's below:
https://www.sram.com/sram/mountain/pr...rigger-shifter
Bikes: Trek 520, Peugeot PX-10
17 bucks to replace assembly and you won't have to go nuts trying to find it...or just call and see if your lbs has a busted one in their part bin you could part out, but you will still have to reassemble yours. I'd just go get a new assembly. Get back on the road
