Mixing front and rear tyres
Old 05-02-22, 11:05 AM
Fletch1969
Going for a tyre change now it's finally stopped raining...
Very tempted to try mixing fronts and rears, any thoughts or advice??
Rear - Low rolling resistance, high puncture protection. Thinking Marathon Greenguard 28 x 1.75"
Front - Lighter weight, bit more grip.
Thinking Marathon Almotion 28 X 2.0"
Anyone doing similar, if so what would you advise?
Fletch1969 is offline
Old 05-02-22, 03:52 PM
chas58
chas58's Avatar
Bikes: too many of all kinds
Quoted: 1147 Post(s)
Liked 415 Times in 335 Posts
I do it. Mostly to get more traction and lower pressure on the front (kind of like having a front shock).
On the rear I want something efficient that isn't going to have a lot of tread distortion under heavy power. That, and 60% of my weight, 90% of my flats, 100% of my power comes from the rear.
Spot on with Rear - Low rolling resistance, high puncture protection.
your two tires are great for a gravel bike that is ridden like an urban bike (not the best choice for pure gravel).
chas58 is offline
Old 05-02-22, 04:10 PM
Fletch1969
Thanks Chas, quiet a lot of my riding is on old canal tow paths, lots of badly kept and VERY bumpy compacted ground. Most of the gravel was gone by the mid 1990's....
It's too bumpy for a road bike, not rough enough for an MTB.
Old 05-02-22, 04:34 PM
Elvo
Quoted: 630 Post(s)
Liked 369 Times in 206 Posts
I run a 700x50 front, 700x44 rear
Elvo is offline
Old 05-04-22, 07:18 AM
chas58
chas58's Avatar
Got it. Those tires should work well for that.
FYI, I usually run less pressure in my front tire as my weight distribution is 40/60. With a larger front tire, you could drop it another 5lbs and get the same footprint and rolling resistance.
One trick I do is after riding through a damp patch, look at the width of the wet part of my tires. It should be same width front/back. (its not if I inflate both to the same PSI.
For those tires, I'd probably start at 30psi front, 35 rear - maybe 40 rear if I was more concerned about speed than comfort. You can go up or down from there based on your preference.
chas58 is offline
Old 05-04-22, 01:04 PM
Rolla
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times in 1,439 Posts
I think mixing the width is more important than the tread, but there's nothing wrong with experimenting.
Rolla is offline
Old 05-04-22, 02:54 PM
GrainBrain
GrainBrain's Avatar
Quoted: 1221 Post(s)
Liked 629 Times in 472 Posts
I pretty much do the same, but I keep tread width equal between front and rear (no reason really). I've found I need puncture protection on the rear tire. Front tire puncture protection hasn't seemed as important, but more supple tire gives a better ride. A grippier tread is also helpful. On the rear I don't notice much of a difference between a tire with puncture protection vs non for ride quality.
GrainBrain is offline
Old 05-04-22, 04:11 PM
Fletch1969
Interested to hear what you guys are using front and rear?
Old 05-05-22, 07:02 AM
chas58
chas58's Avatar
I have a garage full of tires/wheels.
but for your case, I use a Furious Fred (2" or 50mm) in the front (light weight, cush, good dry traction) and a Gravel King SS (semi Slick) for the rear for good protection, decent mileage, and low rolling resistance
chas58 is offline
