What size frame for my 5'1" wife?
Bikes: Leader 722TS, Surly Steamroller, Panasonic DX-3000, Trek 4900
As a birthday present for my wife I've decided to get her a new townie style bike. In order to have it be a fun project we can do together I either wanted to get a vintage bike we could fix up or a frameset we could build together. I did a bit of research and unfortunately it seems her first choice in style (vintage English 3-speed) isn't going to work for her due to her being a bit vertically challenged (5'1"). Her second choice is to get a mixte frame and build that up as a townie. Soma has their Buena Vista frameset that she likes but I'm having a hard time figuring out what size would work best for her. The smallest they have that uses 700c or 650b wheels is a 50cm. I'm afraid that might still be a bit big for her but I'm not sure. They also have a 42cm size that uses 26" wheels, but I have no idea how sizing works when converting to a different size wheel so am not sure if that would be too small. I could really use any advice I can get. I unfortunately don't have her inseam measurement but I can try and get it if it will make a huge difference.
EDIT: In case it's relevant, her current bike is a single-speed Electra Townie. That bike only comes in one size and it seems to fit her fine. I don't know what the frame size is and I can't seem to find it published anywhere.
Señor Member
Quoted: 649 Post(s)
Liked 292 Times
there are two measurements you need to check to see if the frames and bikes you are considering
are in the same ballpark as your wifes current bike
on the drawing below
A
is the seat tube length
usually the length of the tube between the centre of the bottom bracket axle
and the top of the frame where the seatpost emerges
B
is the top tube length
the distance between the top of the head tube
and where a horizontal line meets the seat tube or seat post
if A is close then the seat will almost definitely
be able to be adjusted to the same height as her current cruiser
if B is close then the reach to the handlebars can almost definitely
be able to be adjusted to similar to her cruiser
when a bikes size is given in inches or cm it is usually the seat tube length
my wife is a tad under five foot three
and she has a 14 inch mountain bike
and a 43 cm road bike
A
B
working on my sandal tan
Quoted: 3870 Post(s)
Liked 2,563 Times
The confound is that the Townie has that goofy geometry (really slack seat tube) in order to let the rider put their feet on the ground from the saddle, so it's not directly comparable to a more conventional bike. Otherwise, I'd suggest using a level ruler between the top of the head tube and the seat tube to measure the "effective top tube length" which you could then use when looking at the geometry of other bikes.
5'1" a better fit and balance happens with smaller than 700c wheels . so let go of that wheel size.
OM boy
Bikes: a bunch
Quoted: 507 Post(s)
Liked 634 Times
this chart was posted in Road forum a little while back.
https://pistescyclables.ca/bikes/ebic...road-bikes.pdf
now it doesn't work for everyone, but it's handgrenade close for many. It might help/confirm some of you rthoughts on a size for her.
without the basic sizing measurements, I would say that sizes from 49 down to 45 should/might be workable, with 47 being in the middle and 43 being on the extreme small side for someone 5'1".
Ms Terry uses 559 wheels a lot.. She ha long been making bikes for women, now you can get one from her
built around a frameset she gets from Waterford to her Specs. so its quality.
https://www.terrybicycles.com/Bicycles/Semi-Custom
Bikes: 1986 Raleigh Competition (Restored to Original), 1986 Cannonade SR400 (Updated to Dura Ace 7800)
It all depends on her inseam. My first wife was 5'2" and rode a 46 cm. My 4th wife is 5'1" and rides a 48 cm.
Bikes: 2010 Felt DA, 2012/6 Felt F5, 2015 Felt AR FRD
Quoted: 27 Post(s)
+1. My wife's bike is a BD giant clone. it's a 48.5 cm frame and she's ~ 5'5"; the front wheel is already oncomfortably close to the tip of her shoe on turns if she's not careful about it. at 4" shorter, she'd probably need a 45-46 cm frame in that style.
Usual fit tweak for many frames is just make the seat tube steeper to shorten the reach .
making weight shift to the hands..
Bikes: 20" Folder, Road Bike
Hi,
A 26" wheeled bike is more likely to fit a person around 5' than a 700C wheeled bike.
Around 5' and 700C requires extreme geometry, for 26" more conventional.
https://www.flickr.com/photos/somafab...57632050563429
rgds, sreten.
A little too small is generally better than a little too big.
rgds, sreten.
