Compass tires/Rene Herse vs Panaracer
ignominious poltroon
Quoted: 2239 Post(s)
Liked 3,434 Times
https://www.bikeforums.net/singlespe...e-warning.html
Sock Puppet
Bikes: 2014 Cannondale Synapse Carbon, 2017 Jamis Renegade Exploit and too many others to mention.
Quoted: 1031 Post(s)
Liked 863 Times
This is required reading (right up there with the thread about the guy setting his wheel on fire while trying to burn off his dork disk):
Liked 3,434 Times
All tires are gardenhosen if they aren't Rene Herse.
Likes For Polaris OBark:
Fat n slow
Quoted: 3259 Post(s)
Liked 2,085 Times
I used to use them in may different sizes but only in extralight casings. In my testing, if you run heavy butyl tubes, you are wasting your money. For whatever reason the extralegere versions run much better with latex tubes. I stopped running them tubeless due to sloppy fit and blowoff. I don't find them worth the money. There are faster, cheaper, more durable, and longer lasting tires for my application. So, if want to use them with latex tubes? Maybe. $90-96 per tire plus shipping is steep. The casings are so, so supple. Just don't pinch them to check tire pressure, that popping noise of ruptured threads can be unnerving.
Thread Killer
Quoted: 3136 Post(s)
Liked 1,704 Times
That was the final straw for me, and I happily been running them with Aerothan TPU for +2 years now.
Likes For chaadster:
Sock Puppet
Liked 863 Times
Hmmm. Maybe this is why I can't tell a difference between Panaracer GK Slicks and Rene Herse Extralights. I run them with standard butyl tubes.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
Both attempt to be "fast" tires, but using different approaches: GravelKings use a thinner tread, RHs use a lighter casing. If you need long tread life or a little better puncture resistance, the RHs have the advantage, but I've been pretty content so far with the durability (and cost) of the GravelKing type.
Likes For ThermionicScott:
Liked 3,434 Times
I've run Barlow Pass EL with and without tubes and can't tell much (if any) difference.
For the wider tires (44 mm, 48mm, 55 mm), I have never tried with tubes. I imagine I would feel more of a difference.
I think their official advice is not to run anything narrow than 35mm tubeless.
IIRC, Jan says tubeless setups with their tires are marginally slower.
Quoted: 2604 Post(s)
Liked 1,928 Times
Well then, it's obvious Rene Herse makes you faster, because of all the weight you're carrying when you ride the Panaracer!
Likes For pdlamb:
Fat n slow
Liked 2,085 Times
Don’t trip; Bon Jon ELs with Aerothan tubes are extremely sweet, like 95% as sweet as running them tubeless…if you could. I mean, you can run them tubeless, and I did, it’s just a matter of how much BS you want to put up with to do it. I had one blow off the rim while inflating it, trying to get the beads to lock.
Advocatus Diaboli
Quoted: 4733 Post(s)
Liked 1,532 Times
AFAIK, you can run tires approved for hookless with tubes on hookless rims. Though I don't know if you can inflate to higher pressures in doing so than is advised running without tubes.. I'm kinda hazy on the industry direction there.
Quoted: 6963 Post(s)
Liked 10,962 Times
I ran the RH Bon Jon Pass (standard casing) tires for about 7500 miles on one of my bikes. They were terrific: very smooth and supple, great grip, and very puncture resistant -- I ran them tubeless, and don't recall ever even seeing a little sealant splattered on my frame. I certainly never had to put in a tube mid-ride.
The tires also lasted a looong time. RH uses thick rubber and no puncture protection layer in those tires. I got 3300 miles on a rear and still had no cords showing through when it was replaced; the front tire went 7500 miles and still had plenty of life left.
Eventually, I had to take off one of the tires for some reason (can't recall why) and couldn't get it to seat on my rim...so I bought a couple of Gravelking Slick+ tires, which are fine. Not as supple as the RH, though.
Thread Killer
Liked 1,704 Times
Sock Puppet
Liked 863 Times
That life is pretty much typical of a good road tire. 3000 miles is about what I get out of a rear Vittoria Rubino. Front tires generally last more than 3 times longer than rears.
Liked 10,962 Times
Sock Puppet
Liked 863 Times
For what it's worth, I was talked into buying a set of oooooh so smooth and supple Vittoria Corsas. They cost twice as much as Vittoria Rubinos and I could not tell a difference in ride quality. I could however tell a difference in ride quality between Vittoria Rubinos and Maxxis ReFuses. The ReFuses are bombproof, but ride like a garden hose.
Likes For Lombard:
Liked 10,962 Times
Sunshine
Quoted: 10957 Post(s)
Liked 7,487 Times
Im all for high quality tires and have various brands/models on all my bikes, but the fact that you were forced to run a tube in a tubeless tire because it wouldnt seal AND wouldnt even just stay on the rim? That shouldnt be a vote in favor or a tire.
Havent you had multiple RH tires that had literal holes in the tires too?
Pays a small fortune for tires that are advertised as tubeless yet wont hold air, have visible holes, and wont even stay on the rim...recognizes the whole process is infuriating and total BS, yet is also critical of those buying cheap tires that dont have all these issues.
There is a wide sweet spot between cheap department tires and the money you wasted on tubeless tires that hemorrhage sealant, blow off a rim, and cant even be run tubeless.
Likes For esasjl:
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
Thread Killer
Liked 1,704 Times
I think Aerothan are worth it, though, especially in the Herse extralight casing tires.
And yeah, tubeless can be a hassle, but when you’re geared up for it, and have a good tire/wheel combo, it’s sweet. I run 4 bikes tubeless right now, one TPU, and the balance butyl.
I'm fortunate in getting very few punctures (less than one a year) which reduces my rationale for tubeless. My most used setup has Humptulips Ridge with TPU tubes (Mavic D521/Shimano wheels); as grippy as slicks (RTPs) on tarmac and brilliant on unsealed roads and bridleways.
Likes For esasjl:
Advanced Slacker
Liked 2,537 Times
RH had issues with at least one of their newly tubeless models a few years ago. That made me hold off of going tubeless with them until about 2 years ago. IIRC, that’s been addressed. I and a friend of mine have set them up tubeless since, and they set up relatively easily.
Mine (Barlow Pass EL) did start weeping a lot after about a year. Having run tubeless for a long time on MTBs, I have had a lot of tires weep, and it is generally not a big deal, but these weeped too much. I use mostly Stans regular, I’ve read other sealants are more highly recommended.
Some manufacturing problems are pretty easily solved, like tubeless setup and fit. I see no reason to believe this issue has not been resolved. There is nothing about an EL casing tire that would be more prone to bead related issues.
OTOH, I think the weeping issue is going to be a tough nut to crack with the EL sidewalls.
FWIW, there are also reports of Panaracer Gravel Kings blowing off rims. I was once with a friend when his Maxxis tire blow off a rim when inflating at the trailhead. Over the past 25 years, I have had defective or highly problematic tires from Maxxis, Schwalbe, Kenda, Michelin, and Continental. It is important to understand the difference between isolated production issues and underlying design limitations or flaws.
Likes For Kapusta:
