For the love of English 3 speeds...
Quoted: 3803 Post(s)
Liked 6,639 Times
I've come to my decision on how to deal with the fork on my green Sports. To do a neat job, I'll need to take it apart again, get all greasy, clean it up and bring it over to my old shop and use the milling machine to elongate the hole on the back side downward. I'm figuring that the forward friction on the pads will want to force the mounting bolt downward at the rear, so I don't need to reinforce the elongated hole at the top. The bolt and contoured washer should hold it in place anyway. Yup, these old British bikes can have their quirks.
Bikes: 1973 Raleigh Sports, 1964 Raleigh Sports (Canadian?), 1969 Triumph Ladies, 70's Columbia Sports III, 07 Diamondback Venom
Quoted: 83 Post(s)
Hey quick question,
Is this kickstand a Raleigh thing or anyone know the manufacturer, i love this one and the one on my 64 sucks...lol
I'd like to find another if possible, is it a axle kickstand or?
https://flic.kr/p/YKuK4z
I cant get img linking from flickr to work
Got back home and had some time for fun. Threw some parts on the Raleigh frame I will use for my scorcher. About got them all cept a few.
Took some study shots. Last one shows what the 73' brakes look like without all that self tightening mechanism on the front.
Quoted: 230 Post(s)
Liked 18 Times
Quoted: 231 Post(s)
Liked 10 Times
what pump is that? Id like to find a pump to fit my pump pegs on my sports. I know they are not the best but they complete the look. Nice bike by the way....
Bikes: 1971 Hercules, 1978 Raleigh Superbe, 1978 Raleigh Tourist, 1964 Glider 3 Speed, 1967 Raleigh Sprite 5 Speed, 1968 Hercules AMF 3 Speed, 1972 Raleigh Superbe, 1976 Raleigh Superbe, 1957 Flying Pigeon, 1967 Dunelt 3 Speed
Quoted: 1028 Post(s)
Liked 439 Times
That's a very good looking bike. That stem is what I'm looking for, to finish my 61 scorcher....
I pulled it off my 61 Rudge 10 speed. It is a Raleigh branded item and the clamp area works with North Road bars. I will keep an eye out for one at the LBS I haunt. I am their shop ghost!
Liked 439 Times
I have a couple on other bikes but I don't want to start stripping complete projects.
I agree. Lucky enough I needed a little more reach on the Rudge so I found a GB stem and steel bar for it. That freed the chrome stem for the sport which also gave me a little more reach there.
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,446 Times
Hey quick question,
Pic assist:
Quoted: 83 Post(s)
That looks like the rear stand that came on the Fuji Cambridge III and the Cambridge VI back in the '80s. That one looks pretty grody and I've only ever seen shiny ones. On my own Raleigh Sports the one I use is a Greenfield alloy rear axle stand in black.
Pic assist:
Attachment 581871
Pic assist:
Attachment 581871
Would this be the one your using?
https://www.niagaracycle.com/categor...pouch-packaged
Quoted: 1299 Post(s)
Liked 103 Times
I needed cable adjusters for the calipers on my green Sports after I ditched the self adjuster levers. Luckily I found some in my parts box. A bit rusty but useable.
Inflate Hard
Inflate Hard
Liked 2,446 Times
Liked 103 Times
It is a solid idea. The only problem I envision with it is tightening the nut up inside the fork tube. Not much space in there. The other end of the bolt is a shallow screwdriver slot. With the right box wrench, it might just work.
Inflate Hard
Inflate Hard
Quoted: 83 Post(s)
So I pulled my 73 sport out today and while I was spinning the back wheel like I was riding and coasting was fine but if I move the pedals back like if it were a coaster brake It sounds like a metal groaning which I feel is due to it having probably no lubricant left in it as when I got the the hub was covered in a thick black layer of what I assumed was grease.
Again it sound normal riding forward but reversing the pedal rotation cause a intermittent deep scraping / grinding sound
It has the fill cap but I worry that it’s broken or isn’t sealing
So is the hub dead , is this normal or is it rebuild time?
The bin doth give bounty! This should give me cable adjustment after taking the auto adjusting feature off the brake lever.
Liked 103 Times
Inflate Hard
Inflate Hard
Liked 439 Times
Monkey See, Monkey Do
Overall a big improvement.
Reality has set in. Not going to be a simple swap for the adjuster. Way I see it, I have two options.
1. Drill the brake arm hole from .30 to .92 insert adjuster
2. Use the base of the Raleigh cable holder, drill and tap that hole to accept the replacements cable adjuster stop.
Time for me to think. It has to be done since I have taken away any means of adjusting the cable with the brake levers now.
I stopped by George from Parts Unknown and picked up an extended stem for $5.00. Not exactly what I'm looking for but will work as a place holder for now. I had to make a little leather shim to clamp the bars down.
Attachment 581930
Attachment 581931
Attachment 581930
Attachment 581931
On the road
Bikes: Old Schwinns and old Raleighs
Quoted: 373 Post(s)
Liked 847 Times
I may be one of the few people who actually like the self-adjusters. I have a set on my '74 Sports and they work nicely. They take a little of the "feel" out of braking because they auto-set the brake lever travel, but that doesn't bother me. I would not add them to earlier bikes that lacked the adjusters, but I left them on this sports, and they do fine.
Classic American and British Roadsters, Utility Bikes, and Sporting Bikes (1935-1979):
https://bikeshedva.blogspot.com/
