cassette
Quoted: 17 Post(s)
cassette
I'm planning on buying second-hand wheels for my old MTB over the internet. I got some pics from the seller, among other things, of the cassette, and there's one thing that seems a little odd about it. So far I've had a freewheel and don't know much about cassettes. Could someone let me know:
1. if the part I marked red, i.e. a piece of metal In between the sprockets, is normal,
2. what the condition of the cassette is just by the attached pics, and
3. if it's possibile to run an 8-speed cassette on a bike with a 7-speed freewheel without additionally buying another shifter/ deraileur/other pieces of equipment. If so, what might be possibile adjustments?
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4337 Post(s)
Liked 2,980 Times
1. Can't be sure, but that looks like a ramp to help shifting - not seeing it on any other cogs though.
2. Looks "not worn out".
3. Probably not - depending on rear frame spacing, shifters, indexing, and wrap capacity.
Quoted: 3504 Post(s)
Liked 2,923 Times
I think you're seeing the same kind of ramp you can see more clearly on the largest cog in the third picture, at about 2:00 o'clock.
Quoted: 17 Post(s)
Mother Nature's Son
Quoted: 853 Post(s)
Liked 1,434 Times
That is a shifting ramp on a cog, normal. The cassette is obviously used and dirty, but the teeth look to be in good shape. If you are talking about a true freewheel hub, the freewheel screws onto threads on the hub. You cannot mount a cassette on it. The cassette and cassette hub have splines that match up to fit, then a locking ring to hold them all together, no threads.
It's MY mountain
Liked 2,980 Times
So you would have a hub that wouldn't fit in your bike.
And if you have 7-speed indexed shifters they will not work on an 8-speed cassette.
I advise you measure your dropouts - probably 126mm, and then find wheels with 126mm hubs.
If you do have 130mm dropouts, and friction shifters, then those wheels and that cassette would probably be fine.
You could also overhaul your existing hubs and build them up with new rims and spokes for something pretty nice.
Quoted: 645 Post(s)
Liked 797 Times
Hard to gauge the extent of wear from a photo, although the smallest sprocket teeth look to have some "shark fin" asymmetry suggesting wear. In any case, you'll just have to see how well the cassette plays with whatever chain you propose to use.
The number of speeds is irrelevant - you can't use a cassette on a freewheel hub
Quoted: 2337 Post(s)
Liked 2,821 Times
you could also get new something like https://www.velomine.com/index.php?m...oducts_id=6377 and https://www.thebikesmiths.com/produc...MaAm0jEALw_wcB
