Dynamo hub interchangeable?
Old 09-25-21, 08:26 PM
Lbxpdx
Quoted: 161 Post(s)
Liked 267 Times in 98 Posts
I saw a Shimano hub at a yard sale that has a disc brake rotor on it. Is it possible to take the disc rotor off and use it on a fork with cantilever brakes? I know nothing about disc brake hub sizing vs standard hubs.
Lbxpdx is offline
Old 09-25-21, 11:49 PM
downtube42
downtube42's Avatar
Quoted: 878 Post(s)
Liked 2,019 Times in 1,055 Posts
Should be fine.
downtube42 is offline
Old 09-26-21, 06:24 AM
sweeks
sweeks's Avatar
Quoted: 978 Post(s)
Liked 574 Times in 395 Posts
The hub will have asymmetric flanges because of the disc mounts. This means the wheel will have to be "dished", similar to a rear wheel.
sweeks is offline
Old 09-26-21, 08:17 AM
GamblerGORD53
Bikes: 2013 Custom SA5w / Rohloff Tourster
Quoted: 1222 Post(s)
Liked 314 Times in 241 Posts
Depends on the rim, does it have brake tracks? A few don't.
@sweeks >> Yes the wheel IS dished, so it will be weaker using a rim brake. But it can NOT be changed.
GamblerGORD53 is offline
Old 09-26-21, 08:48 AM
sweeks
sweeks's Avatar
Quoted: 978 Post(s)
OP said it was a hub, not a wheel, so he can (hopefully!) get a rim with brake surfaces.
Not sure I understand why a dished wheel is weaker with a rim brake, assuming it's properly built.
EDIT: Heh... I notice we both have exactly the same number of posts at this time: 1,749.
sweeks is offline
Old 09-27-21, 08:40 AM
zacster
Bikes: Kuota Kredo/Chorus, Trek 7000 commuter, Trek 8000 MTB and a few others
Quoted: 22 Post(s)
Liked 456 Times in 358 Posts
In your case it wouldn't be too bad a kluge but why not just get the proper hub if you don't already have it? Shimano 3N72 dynamo hubs are not that expensive, although I just looked it up on Amazon and it is a lot more than I paid a few years ago.
zacster is offline
