Rotting/molding tire stuck to rim bead - clean-up Suggestions?p
Bikes: Cuevas Custom, Cimmaron, 1988 "Pinalized Rockma", 1984 Trek 510, Moulton custom touring, Raleigh Competition GS, Bridgestone Mb-2 & 3, 1980's Peugeot - US, City, & Canyon Express (6)
Quoted: 1061 Post(s)
Liked 3,538 Times
Taking advantage of a rainy day to do some maintenance on my Cuevas and discovered when I pulled a tire it was moldy and rotten inside and the bead had stuck to the inside of the rim. Got the tire off successfully but now trying to figure the best way to clean up inside of the rim? Assuming I will need to remove the rim tape? scrape? solvent? brush? combo?
Swapping to set of 32mm Gatorskins I got in an auction haul, surprised they fit, not by much, they have 2.5mm of clearance. We will see if I keep them this way?
Back tire was rotten/moldy
Tire stuck to inside of rim
White mold
White mold
Quoted: 5703 Post(s)
Liked 2,429 Times
Before getting to details, acrape/chisel the worst of it off, especially along the channel with an ice cream stick or wooden chopstick shaped to fit.
Then finish with something like a Scotchbrite sponge that ddoesn't scratch to clean it up.
It doesn't need to be beautiful, but you do want it to be smooth.
FB
Chain-L site
FB
Chain-L site
Likes For FBinNY:
What FB said. You can also find nylon scrapers easily enough in hardware stores. e.g.
https://caredistributors.com.au/prod...iABEgK2yfD_BwE
Likes For redshift1:
Liked 3,538 Times
Likes For SoCaled:
Liked 3,538 Times
Chopstick round 2 - Scotch-Brite wand:
Twist tie so I could keep moving the fold on the pad, to get a fresh section
had a hard time getting a good pic, but clean enough
Likes For SoCaled:
