Questions for Specialized Hardrock 2000's era
Member in Training
Hi everyone,
I have been searching for a bike to go out and ride some rail trail's and the occasional off-road dirt trail's with loose gravel. So I came across a Specialized Hardrock 19" w/ silver and red paint scheme, listed as a 2000 model. I did some research and from what I have read it was supposed to have a front shock Rock Shox Jett S, the one pictured does not, just a solid fork and the paint matches. So I doubt it was replaced. Is it a 2000 model or another year? I just want to know, so when I go to research parts or sizes, I'm looking at the correct sizes for the model I have.
Also it has grip shifters and I would like to swap them out to regular shifters, is this do-able? Anything else I should be aware of or check before purchasing?
Thanks
Thanks
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
Who knows what particular model you have (picture would help) but it is best to figure out the parts you need as it comes up. Who knows if in the past 20 years some things have been changed on the bike.
As far as the shifters:
How many speeds is this (front and rear)
What brand and model is the shifter? How about the rear derailleur? Again, pics will help if you don't know.
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,105 Times
yeah, not enough info.
I had a 2002 Hardrock and it was good enough.
Genesis 49:16-17
Genesis 49:16-17
Quoted: 1943 Post(s)
Liked 2,164 Times
I don’t have an answer, but I think it came with a suspension or steel rigid fork. Considering it was on the lower end of the models, it is more likely that the fork is original.
Regardless, it is actually a good thing. I would be surprised at almost 20 years of riding an original Jett would still work. Forks wear out and parts for old forks aren’t readily available and there are few new ones to fit your old head tube size.
And for your riding ia rigid fork shouldn’t be an issue.
John
John
Member in Training
Sorry, I'm to new to post pictures yet. From the looks of it, it's a 3x7 with Shimano components, Acera front derailleur, cant see the rear. It looks pretty stock to me, only upgrade I see is a set of bear trap type of pedals.
Thanks for the replies.
Disco Infiltrator
Liked 2,105 Times
Very, very likely any Shimano 3x7 or 3x8 shifter pod set will work fine. Back to your size question, 19" is a large. Mine was that size and was always a little too big for me at 5ft8.
You can post pics in your album and we can link them but you've only got two more posts to go til you can take care of yourself. I'm seeing photos of Hardrocks as late as 2000 with rigid forks. Seems like 2000-2001 was a transition year when they introduced the aluminum frame at the top build but still had steel frames below. By the time I bought mine in early 2002, this option was gone. Here's a googled-up example:
Genesis 49:16-17
Genesis 49:16-17
Member in Training
Pics added to Album, thanks for the great idea.
i'm 5'10, so a 19" frame should be ideal for me. But I haven't bought it yet, so I can still test ride it and see how it feels. I will want to upgrade to a 1x, so that should bring new shifters, right?
Advanced Slacker
Liked 2,537 Times
Whoa! That is one unique stem/steerer/headset setup. Never seen that before. Looks like a threaded headset/steerer with a threadless stem. And why is that stem sitting on the steerer all crooked like that? Looks like it was all designed that way. So that top cap bolt might not be what was saying it was.
Have you tried loosening the bolts on the side?
Member in Training
I haven't purchased it yet, and I haven't been able to see it yet, these are the pictures from the Ad. I did notice the top cap looking alittle off, but just thought it was something unique to Specialized.
Liked 2,164 Times
It would be interesting to know the brand of that stem. I don’t think it is Specialized, but it almost looks like an early attempt, (poorly executed?), at a multi-set type stem that Specialized does make.
It possibly could still be a quill with the top dome rotating and and the side bolts locking the stem angle in place. But I’ve never seen anything like it either; and not sure how it works.
John
Edit added: That logo does look like a Specialized “S” in the center.
John
Bikes: Soma Pescadero, Surly Pugsley, Salsa Fargo, Schwinn Klunker, Gravity SS 27.5, Monocog 29er
Quoted: 186 Post(s)
Liked 234 Times
That is just an old quill to threadless adaptor. The top cap bolt is offset because the wedge bolt would be in the way if it was centered. That isn't a 2000 model bike, more likely mid 90's. Doesn't matter really, they were decent bikes as long as it isn't worn out.
Bikes: Fuji S-12s, Trek Navigator 200, Dahon Vitesse D7, Raleigh Sprite Touring ('70's)
Wow, I pulled a Specialized HardRock from the 'recycle' corner of the town X-fer station last week, and have this bike's cousin (post #8 above). The identical odd looking angled offset threadless steerer. At first I thought it was some kind of owner threaded-threadless conversion, but all the parts have the stylized "S" on them and the same round stickers as shown above, so now I'm thinking it was either original equipment or a factory kit field upgrade??
Otherwise, it looks pretty 1999'ish.
Cr-Mo steel frame, Black & Silver with identical color transitions & fonts
Jett RockShox front suspension
3x7 Shimano drivetrain.
I'll try to get a picture up later today. I pulled the wheels for some repairs, so the frame is still sitting outside. I was going to do some basic restoration in preparation for donating it to the local bike advocacy group, but the steerer/bars really have me scratching my head as to what this is. And why does the center cap on the stem say Low-Hi? Can you change the angle?
Ah! Look what I found on a search! Identified as a year 2000 model.
I particularly liked the seat stay sticker pronouncing that the frame was "Designed on Sun Microsystems" hardware (same as shown in the photo above). Does it take a supercomputer to optimize a rather basic bicycle style geometry?
Inquiring minds had to know.... An overnight soak with some Kroil and disassembly revealed:
A conventional threaded headset at it's core, with a 1" steerer bore.
A Specialized by Kalin brand 25.4mm (1 inch) quill insert with a wedge bolt, with a 10 degree offset in the 1 1/8" upper half to where the handlebar stem bolts on. So you can add or subtract 10 degrees to the riser stem's 20 degree set angle. A small notch at the base guarantees alignment in only two positions (+/- 10 degrees). Interesting.....
I guess it added an air of modernity and adjustability to a late 1990's bicycle that was somewhat rare in this price point.
Disco Infiltrator
Liked 2,105 Times
In the Nineties? Haha, yeah for sure. Not to optimize, but to manufacture. One frame might seem simple but that's not what is going on here. It might not all be true, but it's implying that all the fixtures, butting, hydroforming molds, tube mitering, robot welding, paint and decals, for all the models and all the sizes, boxes and crates, component spec and keeping them all in just in time stock, and so much else are all using the same CAD, also carrying all the information to the factory floor that used to be on drawings and in manufacturing planning.
Genesis 49:16-17
Genesis 49:16-17
I did for a while have a Sun system for microchip CAD files interfaced to a nanometer-precise stage as part of a prototyping system. That they were good at. Design bicycle frames? Meh....
