Rim Tape Width
Quoted: 198 Post(s)
Liked 52 Times
Rim Tape Width
how critical is the "correct" width?
for 7 years i've used 16 mm velox bought bulk. new season tape is packaged x 2 rolls and has a width guide on the back. evidently i need 19 mm.
is it worth missing my truing appointment to get wider tape? or is this my OCD kicking in?
thanks
thanks
Happy With My Bikes
Quoted: 882 Post(s)
Liked 2,304 Times
After 7 years of no problems, I wouldn't sweat it. If it makes you feel better, buy the wider tape next time, but I don't think I'd be unmounting tires to replace the tape for this reason.
Old fart
Quoted: 3583 Post(s)
Liked 3,396 Times
Too wide tape can make mounting the tire difficult. If you have no problems with the current width, there's no compelling reason to change it.
Likes For JohnDThompson:
Sr Member on Sr bikes
As long as the spoke holes (and any other gaps) are complete covered...and you can still mount the tire...you should be OK. If there are any small gaps left at the spoke holes...that’s where you’ll potentially run into problems.
Dan
Dan
Quoted: 1572 Post(s)
Liked 643 Times
Doesn't take much of a gap. The way it shows up is semi-frequent rim side inner tube punctures. Your new tube may puncture right away but it more likely will wait until you are 30 miles from home.
Likes For Retro Grouch:
