Rebuilding Mongoose XR250
Rear hub / gears / ?
I know that there are 7 gears in the rear. As far as the hub, and or cassette, I have NO idea what any of that means. It does have the v brakes, (I think) in which it rubs, because of the slight bend in the rear. Overall it is just the stock Mongoose XR250 with disc on the front.
Thanks.
Thanks.
Quoted: 581 Post(s)
Liked 921 Times
dmfriend Just get a new rear wheel. If the rim isn't borked then V brakes will provide all the stopping power you will need. You will have to replace the hub to fit disc brakes anyways, and buying a separate hub and spokes and building into your rim is usually more expensive than buying a complete rear wheel. Discs on the front and rim brakes on the rear is a very logical arrangement, hence why the bike was specced that way from the factory.
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
Thanks.
Thanks.
Google “freehub vs freewheel”.
Then google “how to measure dropout spacing”.
Bikes: Too many to list
Quoted: 1765 Post(s)
Liked 1,124 Times
I know I am about 12 years late on this thread, but I have an XR250 that I would like to put disk brakes on the rear. The front has disc brakes, and there is 2 holes near the rear wheel that looks to be for disc brakes. The links from above are not valid any longer. Can someone give me a hand as to what may need to be done to get rear disk on the XR250?
I like this bike because it is a tougher frame. The rear rim has been bent from hard use, the regular brakes are just not working as they used to from the bent rim.
Thanks, in advance.
Matt
Thanks, in advance.
Matt
Why dont you have the rim fixed? To go discs, you will need a new back wheel, the disc brake caliper and lever
To fix what you have now, you may need just to have your back wheel trued (straightened) - or at worst case, replace the rim and it may be cheaper to find a complete wheel rather than re-lace a new rim on there
Advanced Slacker
Liked 2,537 Times
If he goes with mechanical disc, he does not need to replace his brake lever.
But I agree that he should try to get the rim straightened. I had sort of assumed that he had already looked into that, but maybe not.
