Seat Tube gap & clamp force
buy my bikes
Bikes: my very own customized GUNNAR CrossHairs
Quoted: 519 Post(s)
Liked 426 Times
Picked up this lovely 89 Panasonic MountainCat from a fellow BF member.
The seatpost is 26mm. I think original. The catalog doesn’t say.
To make sure the seatpost doesn’t slip, should I file that spot where the collar is touching?
I don’t want to create a new problem. Like a cracked collar.
I don’t believe a 26.2mm would fit.
Thanks.
Thanks.
Quoted: 980 Post(s)
Liked 580 Times
You could relieve the "close contact" with a file or Dremel disc, but if the seatpost stays put, why mess with it?
Likes For sweeks:
Quoted: 504 Post(s)
Liked 637 Times
Quoted: 4195 Post(s)
Liked 3,837 Times
By using the darn QR lever too often Unlike an axle and drop out where all the parts are very solid/rigid, the seat lug often has hollow ears and the metal is usually not a very strong type. So the lug deforms a tiny bit with each clamping. Add in an aggressive clamping a few times and this result is not uncommon. If the post is steel it can slip more easily, so more clamp tightening is the first effort to keep the seat in place. The last bit is the fit of the post. I would suggest trying a one size larger one just to be sure one has the snuggest fit possible yet still be able to move the post when wanted. If the OP doesn't need to move the seat height after a correct positioning I would ditch that QR for a common bolt. Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
buy my bikes
Quoted: 519 Post(s)
Liked 426 Times
Thanks everyone
I will follow Andrew R Stewart advice
Kalloy make a 26.2 post, and I was planning to use aluminum eventually- to get away from the pipe clamp style seat attachment.
I already stuck some tape on the seatpost to see it is slipping, or I’m imagining things.
Quoted: 980 Post(s)
Liked 580 Times
Thanks everyone
Before you purchase a new seatpost, it might be a good idea to take the bike to a shop that has a seatpost sizing gauge. Then you'll know if a 26.2mm post is the right size. An alloy post tried-in on a steel frame will probably be marked up and not returnable.
Liked 3,837 Times
Andy always gives good advice!
AndrewRStewart
AndrewRStewart
buy my bikes
Quoted: 519 Post(s)
Liked 426 Times
Biked to church this AM and it slipped right away.
Adjusted up and tightened, but a longer ride after church was just more slipping, but slower.
I’ll visit my a LBS Tuesday & get it sized.
buy my bikes
Quoted: 519 Post(s)
Liked 426 Times
closing the loop
Picked up a new 26.0mm Kalloy post from my LBS. The budget oriented Kalloy has those machining grooves from turning the post to the spec diameter. That’s good for preventing slipping, I think.
Got home and the post doesn’t want to fit. The seat tube doesn’t look so round, so I miss used a screw driver and hammer to persuade the tube to more roundish
The post is now a slip fit- so I’m kind of hoping I don’t really need a 26.2mm. I’m sure I don’t. Maybe.
Couple of test rides and everything stayed where I wanted it. Going to switch to a binder bolt and get rid of the QR.
I’ll update again if I end up with a 26.2mm post. Probably I’ll do a while PanaCat Project thread, since these bikes Seem rare ish.
