Generic T-BAR PHYSIS HANDLEPOST
Quoted: 20 Post(s)
Hi,
As you may noticed, I looking to improveme my riding position on my Tern C7.
Any kind of stem require changing the handelpost-steerer what so called (think so) to 'T' shape.
Tern have the PHYSIS.
Cost about 150$ which is way above.
Anyone seen A "generic" handelpost with fair quality that might do the job?
Example
Thank you very much
Example
Thank you very much
Quoted: 20 Post(s)
Hi,
Is it possible on the C7 doing this set-up?
Or installing one of the above(stems) without any change of steerer?
Thanks!
Thanks!
Quoted: 20 Post(s)
I dont think I asked wheather I just need the Haber Hallo and nothing else.
No Handlepost/steerer?
It is the C7 model..The basic entery model.
Thank you
Thank you
Bikes: Many Downtube Folders :)
Quoted: 282 Post(s)
Liked 24 Times
This forum is bringing up some great questions and ideas. Thanks for sharing!
Thanks
Yan
Thanks
Yan
Designer of Downtube Folding Bike
Ph.D. Temple University ( Math )
Biked across the USA twice
Semi-active chess player ( two time Bahamas National Champion )
Sivananda ( Bahamas ) Trained Yoga instructor ( 2013 ) and ThetaHealer since 2013
Bicycle delivery worker for Jimmy John's. Delivering is the best workout I have ever had.
55+ Club,...
Bikes: 9+,...
Quoted: 1111 Post(s)
Liked 843 Times
And yes, your other thread was asking for assistance with this same issue. The question was answered. This is the easiest option available.
Quoted: 20 Post(s)
And the ONLY stem that allowing me that is the Aber Hallow?
It only me or the "SATORI" is 100% same as the "Aber Hallo"?
On "Tranz-x" & "Promax" & "SATORI" options I would need to change anything or it same concept as the "Aber Halo"?
Thank you!
p.s:
I dont know why, but I could not understand from the previous post if any of these (including: Tranz-x + Promax + SATORI) are involving changing of handelpost/steerer/tube or anything else.
Thank you!
p.s:
55+ Club,...
Bikes: 9+,...
Liked 843 Times
Thank you!
p.s:
Thank you!
p.s:
THE ONLY WAY THOSE WOULD WORK IS IF YOU CHANGED THE HANDLEBAR STEM. THE PICTURES YOU POSTED SHOW THAT.
NO, THEY DON'T WORK. AN ABER HALLO WOULD WORK WITHOUT CHANGING THE HANDLEBAR STEM.
You have a non-adjustable stem, so none of them work. And the Tern stem is completely different than what is on your bike.
Look at the handlepost adjustment, it's nothing like what you keep posting. Without changing the handlebar stem, the stuff you posted will never work. An Aber Hallo will.
The Aber Hallo works perfectly.
Quoted: 20 Post(s)
THANK YOU SO MUCH!!!
Summerized:
Only the ABERHALLO stem WILL WORK just at is without any change.
I had to write it to be sure in 100% about it.
Summerized:
