rear qr axle keeps loosening
So i got a new mtb last year and one day the rear wheel just fell out the dropouts, luckily not while i was riding! I've probably just identified the cause. Every time i coast, the cassettes keep inching forward, and i'm not talking about wobbling about, but really moving slowly but surely in the direction of wheel rotation and that's probably what's loosening the qr axle and causing that grinding sound caused by an improperly seated wheel or loose axle, not to mention the stand also buckling. I've no idea why the cassettes are doing this though but it's causing me to have to unlock and lock the lever to silence the grinding noises. What could be causing this and what should i do?
Expired Member
Quoted: 3661 Post(s)
Liked 5,408 Times
Try a Shimano QR of the internal cam variety.
Quoted: 4199 Post(s)
Liked 3,851 Times
With this description I have little idea to what's going on. If you bought the bike from a local shop go back to them first. Can you post a photo or vid? Andy
AndrewRStewart
AndrewRStewart
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
"Cassettes"?
Insane Bicycle Mechanic
Quoted: 802 Post(s)
Liked 703 Times
If you are seeing the cassette sprockets wobble while the wheel is coasting... that is a well-known condition caused by manufacturing tolerances. (All my bikes have this to one degree or another.) It's not related to your wheel moving in the dropout.
You need at least ten posts before you can post pictures here.
As Andy said- we more details. Make and model of bike, type of quick-release, how you've maintained the bike... all of this is relevant. Probably your first step is having the bike examined by a qualified mechanic, preferably at the shop where you bought the bike.
Jeff Wills
Jeff Wills
Likes For Jeff Wills:
Quoted: 1943 Post(s)
Liked 2,164 Times
I’m not sure what is going on, but I have a question.
Are you tightening the QR just by turning it; i,e. threading it into the QR skewer nut until it is tight?
John
John
Likes For 70sSanO:
Quoted: 1438 Post(s)
Liked 1,092 Times
https://www.bikebarn.com/how-to/be-s...ctly-pg247.htm
Likes For dsbrantjr:
Quoted: 581 Post(s)
Liked 921 Times
It certainly sounds like you are not properly or sufficiently tightening the QR. If it is not good and tight, there can be miniscule movements of the axle which will gradually loosen the QR. Thisw was a problem identified years ago with F QRs on wheels with disc brakes, but that is because the front discs impart a force that QRs were not intended to handle.
If it's happening on the rear wheel, though, it's almost definitely user error.
Old fart
Quoted: 3587 Post(s)
Liked 3,400 Times
Two possibilities come to mind:
1) improper tightening of the quick release, e.g. using it as a wing nut rather than a cam.
2) using an open-cam type quick release on a horizontal dropout.
Firstly, thanks for everyone's replies!
From the replies I've got, I've learnt about int and ext cam skewers. Mine is of the latter sort, which after some reading isn't the best due to compression of the soft plastic material. Looks like I'll be changing them out with int cams. My bike is a Polygon Xtrada 5 2021, don't think it has a big following. In the way of maintenance, I've only fine-tuned gear indexing and cleaned the chains, haven't got to replacing grease on the cranks or wheel axles yet, but the qr problem already presented itself a month after purchase.
The cassette doesn't only wobble, it actually rotates in the direction of wheel travel when coasting and that is what i suspect is slowly loosening the tension on the skewer.
I'm unable to tighten the skewer in any other way than turning the lever because my bike stand is attached to the threaded end of the skewer in place of the nut. That makes it impossible to fine tune the tightness.
Perhaps it's also worth mentioning that after a short distance and when i put the stand down, it oftentimes buckles with an audible creak coming from the axle and that causes the rattling sounds caused by improperly seated wheel in the dropouts when spinning the wheel. Opening and closing the lever temporarily solves it until i ride it a distance again
I am potato.
Quoted: 1788 Post(s)
Liked 1,628 Times
Which is more important: Kickstand or rear wheel?
Nix the kickstand or find one that attaches by way of a different method.
Likes For base2:
Great, I'll do that, thanks! That kickstand was a last minute add on during bike purchase, didn't anticipate such problems, being my first bike after 16 years anyway...
Liked 3,851 Times
If the cog set bearings are not freely moving they will try to keep the cogs rotating (as is happening when pedaling, when coasting the cog set is stationary) when coasting. Usually the chain will droop along the upper run when this happens. Andy
AndrewRStewart
AndrewRStewart
Half way there
Quoted: 986 Post(s)
Liked 880 Times
Thanks - always a pleasure to learn something new. So the bearings bind and lock the cog set to the hub? How common is this and what would cause it on a relatively new bike?
Liked 3,851 Times
Common enough for shop wrenches to deal with it a few times a year. Ice, grit/mud, rust can all collect inside the FW core and cause the balls to not roll, thus drag the outer portion of the core along with the wheel's spin. Rarely we see it on fairly new stuff, usually from poor factory assembly (as in not having zero preload). But there are other outside of the cog set causes like stuff wrapped up behind the cog set and jammed against the spoke ends (hair, foliage being usual). Sometimes a spoke guard is not well mounted and presses against the cogset's back side. Andy
AndrewRStewart
AndrewRStewart
