The sublime (riding) and the ridiculous (all our gear)
We tandem bike 95% on rail trails, often somewhat remote. After six years we have developed a well-organized panoply of tools and spare gear to handle just about any mechanical or other emergency on the trail.
With a handicapped stoker, walking out in case of bike failure is not an option! Tyre, chain, electrical, bolt, and other failures up to ten miles from any road have occurred with some regularity.
So far so good, even in the depths of roadless river gorges having rail trails (PA, CO.) The only thing we are not equipped for is outright rim failure.
Here is the expedition equipment we carry on all rides, even locally. ALL of it goes in the panniers. Bike with gear can weigh 125#. With riders almost 400#. Steel frame, steel wheels, 26x2” schwalbe offroad tyres.
Rear Panniers, having tall drawstring rain collar. Secured with heavy zipties.
A couple of spare bungies in case of tear or failure. Short roll of repair tape.
Covid masks (yes, still), alcohol handcleaner, folded paper towels, protective gloves, and first aid kit live in outer pockets.
20’ coated wire rope cable and padlock, to secure entire bike frame.
Spare daypack- for use when locking up bike to walk or picnic: to store bike battery, toolkit, camera. Contingency if one of the overstuffed panniers blows up.
Medical cooling gear- water sprayers, full water bottles, phase-change cooling gear ±12#. In hot weather wear refrigerant-cooled water-circulation cooling vest, carry 12# spare 4-hour battery, distilled H20 fill, funnel, hardware. Another 20# of gear!
Clothing prepared for major changes in temperature and weather: rain/wind jackets; pile jackets; ear headband/hats and light gloves; spare socks; polypro shirts; other as required.
Two reflective vests for any on-road biking. Headlamps and battery bike flashers.
Spare tyre folded into 16” diameter and carried in the spare daypack.
8x15x2.5 snaplock box with:
· 3- 1.75x26 schraeder tubes
· Rim tape
· Tirepump- 12” long with fold-out footbrace and threaded hose
· Tire patch kit, tire levers, spare valve caps, spare valve stems, valve stem tool.
· C02 inflator head and two large cartridges
· Spare length of chain
· Set of two Rohloff speed cables in housing (specialty item)
· Three brake cables (Takes three to make a run on coupled frame)
· Length of cable housing, several housing ends
· Bundle of 6” zip ties
Fanny pack, two zipper, with:
Outer pocket = coupled bike assembly/disassembly tools for each ride:
· S&S coupler wrench, spray painted bright orange
· 6,5,4mm T-handle allen wrenches
· Tyre pressure gauge 120 psi
· Valve stem remover
Inner pocket- tools on rides:
· Chain tool
· 6” adjustable wrench
· cone wrenches
· packet of 8” zip ties
· tyre levers
· pitlock socket for secured rear wheel removal
· spoke tool
· needle nose pliers
· 6” vice grip
· Side cable cutter
· Multibit screwdriver
· Torque screwdriver and bits
· Awl to ream cable housings after cutting
· Quick change utility knife and blades
Spare Parts:
· 8” length of drive chain
· Full chain in box
· Spare cable splitters- one brake, one speed (used up other spares)
· Assorted bolts and nuts
· Safety ends to cover sharp fender stays
· Seatpost clamp, dual bolt. They tend to strip out.
· 16-24awg wiring splicers, close with pliers
· Spare fuse for inline battery protection
· Rubber battery connector covers
· Spokes and spoke nipples
Lunch/snacks in zippered insulated bag. Typically bread cheese apples and gorp, a few paper towels.
Collapsible tupperware for berry picking/foods. Two sporks for ice cream stops etc.
Additional tool kit that remains in truck:
· Lots more medical cooling gear, cold packs, clothing, water, snacks.
· Second spare tyre!
· Spare kickstand and bolt in case primary stand fails.
· Orange hand cleaner, roll paper towels, garbage bags
· Comprehensive socket and wrench set
· Battery wiring materials, terminals, heat shrink tubings, zip ties.
· 120v Soldering gun and gear (inverter in truck bed)
· 120v heat gun (inverter in truck bed)
· 120v Extension cord
Everything in the truck goes in Rubbermaid totes, nothing is loose, and is protected from rain and curious eyes, during loading/unloading.
We throw around a bunch of these totes unloading and loading the two bike halves.
It has been suggested to us:
- Get a bicycle trailer
- Hire a team of sherpas and a sag wagon
- Put saddlebags on a really big dog
What does your toolkit look like?
· Rim tape
· Chain tool
· cone wrenches
· tyre levers
· spoke tool
· 6” vice grip
· Side cable cutter
Spare Parts:
· Full chain in box
Quoted: 680 Post(s)
Liked 948 Times
man thats a lot. but we are usually 25 miles from home as thats as far as we can get and get back under our own power.
Battery with all the cables to charge anything I went to tubeless so now carry a dynaplug kit several co2 cartridges plus a pump and one tube. everything is sealed so we don't need a lot of tools. a first aid kit. these are most of the tools plus something to get a tire on and off and such. we signed up for AAA so if we need a lift home we have a solution.
Likes For fooferdoggie:
Bikes: CoMotion tandem, All City fixie, Cannondale road bike, fold-up bike
Liked 6 Times
This is a great post. Doing the C&O and Allegheny passage this summer. Had a couple issues during the summer with a cracked rim and a couple flat tires so I'm not sure what tools and extra parts to bring. I have front and rear panniers with my tent and camping supplies on the rack. I should have room for lots of extras, just worried about the added weight.
Old guy & bikes
Sounds like you have special requirements, so your kit will be more extensive than most. My suggestions are 1. Take more compact tools. A multi tool would replace T allen, full size screwdrivers, crescent wrench, spoke wrench, separate chain tool. Pocket knife instead of utility knife. Cable cutters unnecessary, leave uncut cable until you get home. Just make sure you can work every fastener. 2. Meticulous care of cabling, instead of full cable sets (but do take spare inner wires, 1 each brake and gear). 3. One spare chain link and two quick links.
Consider the risk. Cable casing rarely fails, but cables do. I understand that walking out isn’t an option, but carrying unneeded weight reduces the reliability of your rig.
Likes For canalligators:
