ISO and for trade thread part 5
#4401
I can't locate the stem, must of used it on something, I'm sorry. I do for sure have a 90mm French Atax stem. If it's of any use to you it's yours for the cost of shipping.
Likes For brian3069:
#4402
Edumacator
Quoted: 2434 Post(s)
Liked 3,107 Times
I have a loooong Technomic that is 50. Not sure that will help you. I will never use it since none of my head tubes are long enough.
It is also a 25.4 clamp, 280 mm long.
#4403
buy my bikes
Bikes: my very own customized GUNNAR CrossHairs
Quoted: 519 Post(s)
Liked 426 Times
clamp is 26mm according to the calipers.
I was targeting this for a spring project, but if we’re swapping I think yours would work for me.
No charge for the blue tape.
#4404
Quoted: 1607 Post(s)
Liked 2,213 Times
Need cone for DA FH-7402 hub. A doner hub would work if the cones are good.
Purchase or select from stems (70 - 140), handlebars (Cinelli 26.4), and pedals (600/105 rat traps and Look Delta)
#4405
I was measuring center-to-center, but anyway I think I've got a swap worked out with someone. Thanks
Likes For ACH57:
#4406
I may have a single cone and axle assembly. Not sure of the condition, I'll check later today.
#4407
Quoted: 36 Post(s)
Liked 53 Times
ISO 28H Campagnolo Record hubset
ISO 28H Campagnolo Record hubset. 1970's to mid 1980's Record. Skewers not required. Small or large flange OK. Trade for like set in 32 or 36 hole? (I probably don't have a 32H high flange set for trade). Or let me know what you need.
#4408
Right cone is the damaged old one.
#4409
Liked 2,213 Times
I have an axle assembly (part # 354 9806) that is mostly NOS. A few years ago I had a 7403 hub with a totally borked cone that I struggled to find a replacement for. Ended up finding a NOS assembly on ebay and only swapped the cone that I needed. Part number is the same for 7402 and 7403 rear hubs. If interested please PM.
#4410
Quoted: 1300 Post(s)
Liked 1,900 Times
28 hole low flange set 6spd
28 hole low flange set reconditioned and polished
PM me Smiles, MH
Or perhaps these? 28hole high flange NIB 5spd
#4411
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
#4412
Prince of the Royal City
Not only that, they had another one advertised, this time demonstrating showing that they are measuring. Problem was, it was also wrong.
#4413
Bikes: 1972 Fuji The Finest | 1990 Bianchi Giro | 1999 LeMond Buenos Aires
Quoted: 151 Post(s)
Liked 303 Times
ISO 70s/80s Sugino Adjustable Cup (English) FOUND
Looks like I'm all set with getting the adjustable cup figured out, thanks!
So I'm looking for one of two potential Sugino adjustable BB cups, the ones with MADE IN JAPAN written on there. English threading (1.37x24). Would do just the adjustable, a pair of cups, or up to a total bottom bracket assembly (MW-68 or MT-68). Figured it's worth a try to use the partial MT-68 I have before mixing with a different brand cup, buying something unknown off eBay to carve it up, or buying a long cartridge BB and popping on a couple spacers.
Snip from the 1973 Sugino catalog (either of the adjustable cups, both have MADE IN JAPAN on there, instead of just JAPAN).
If you have anything of need let me know, I have some things available to trade, including Paypal and Venmo info.
#4414
Veteran, Pacifist
Quoted: 3897 Post(s)
Liked 4,828 Times
In need of Campy front derailleur clamp-on
Looking for Campy front derailleur, clamp-on 28.6 - in nice condition.
A Mirage model would match the 9 spd rear derailleur, but I don’t really care about matching rd.
Double chainring crankset, on mid-80s bike.
Have items to trade. Or I can buy.
I have an older Campy front der, that just looks wrong on this build. (Even if it works, there is a limit to ‘Frankenbuild’, at least on this frame)
thx in advance
thx in advance
#4415
Edit: I do, but it's all 36x24 Italian thread stuff. Probably why that bin of stuff has not been used up yet.
Likes For wesmamyke:
#4416
buy my bikes
Quoted: 519 Post(s)
Liked 426 Times
ISO:
i got a couple sets of Z401 stem shifters, and I'd like to use a set as DT shifters.
I'm looking for a down tube adapter, like this:
https://velobase.com/ViewComponent.a...062ef&Enum=104
It doesn't need to be this exact adapter, but I do want it to say "SHIMANO" on it. thanks.
I suppose I could trade a set of shifters or one of the quill adapters. Let me know what you might need.
#4417
I'll be posting a few things for trade here soon. I don't need too much in the way of parts, but there are a few things holding progress back a bit. Postage would be from Manitoba in Canada. Haven't sent anything Stateside in long time. They've made it more of a pain in the a$s now. All customs forms must be filled in online by the sender.
#4418
Bikes: '80 Medici Tourismo, '82 Merckx, '85 Peugeot PSN10, '86 Ironman, '89 Trek 520, '96 Steelman, '96 Torelli CX, '97 Friday Two'sDay, '02 CoMo Speedster, '09 Giant Reign, '10 Canfield, '13 Turner DHR, '16 Chase BMX
Quoted: 40 Post(s)
Liked 256 Times
(quote)
WTB or WTT
I need 165mm crank arms or crankset for a triple set, square taper, JIS, for my '89 Trek 520. Something in silver, not too particular about the brand. I have a Deore FC-MT60 in 170mm for trade if you have a 165mm. Rings are Biopace 50-44-28. I can do just the arms or with the rings.
I found the cranks I needed, if anyone needs my 170mm they are still available for trade. I like bike stuff
WTB or WTT
#4419
Randonneuring bars for trade
I have two sets of randonneuring bars I would like to trade for standard parallel drops in 40-42 cm center to center at the bottom of the drops and 25.4 clamp size, silver only, no ergo/angled bars.
The first one is an SR Sakae “Randnnr Road Champion “ with 25.4 clamp, about 33cm c-to-c on the tops, 41cm c-to-c in the drops, drop is about 125mm.
The 2nd set is a Nitto “Grand Randonneur135”, 25.4 clamp, 33/41 c-to -c, 125 mm drop.
Both are in good shape but the Nitto is much newer. The SR came on a mid 70s Centurion.
Likes For ACH57:
#4420
buy my bikes
Quoted: 519 Post(s)
Liked 426 Times
I have two sets of randonneuring bars I would like to trade for standard parallel drops in 40-42 cm center to center at the bottom of the drops and 25.4 clamp size.
The black Ritchey bars are from this millennium, I believe. I think they meet your width requirement, but they are black and ergo-shaped. CLAMP DIAMETER: 26.0mm
WELP- I think I just sold the CODA bars….
There's also a set of wider CODA bars. Made in the USA. Slightly wider, about 45cm CtC. Not sure if these are from the '80s or '90s. CLAMP DIAMETER: 26.0mm
I'd be willing to swap for a bike seat! HA!
lemme know. The Ritchey's are already posted for sale in the C&V section. Probably why I haven't sold them yet.
- just typed all this up an realized you said 25.4mm . . . welp, lemme know...
#4421
I've got two sets of drop bars: https://www.bikeforums.net/g/album/19676741
#4422
Old bikes, Older guy
Location: Fiscal Conservative on the Lefty Coast - Oregon
Bikes: A few modern, Several vintage, All ridden when weather allows.
Quoted: 250 Post(s)
Liked 165 Times
ISO Dura Ace 7800 STI left "brifter"
Hi folks,
I’m looking for a left side/front Dura Ace 7800 STI shifter/lever to match the right side 7800 0n my Ridley CX bike. This may be labeled 7801 because it would be for a double chain set. For trade I have a 7400 derailleur set with some rough 7 speed Dura Ace SIS DT shifters. The RD is labeled 6 SIS/7 SIS, but I have used it successfully with the above shifters as well as Shimano 600 8 speed SIS DTs and 105 8 Speed STIs. The derailleurs are in good condition. I also have other parts to trade. Please send me your e-mail adr if you would like pix or other info.
Thanks & regards,
Van
Looking for mate
Close up of right one
Thanks & regards,
Van
Looking for mate
Remember: Real bikes have pedals.
...and never put a yellow tail on a Red, White and Blue kite!
#4423
Stop reading my posts!
Quoted: 1440 Post(s)
Liked 1,055 Times
Hi folks,
Thanks & regards,
Van
Looking for mate
Thanks & regards,
Van
Looking for mate
EDIT: I found it and it's a 7800 (had to hunt for the part number, now I know where to look!). I will PM you with details.
#4424
Edumacator
Liked 3,107 Times
I might have an extra. I’ll check.
#4425
buy my bikes
Quoted: 519 Post(s)
Liked 426 Times
Originally Posted by hazetguy;[url=tel:22326959
22326959[/url]]ISO/NEEDED/WANTED: Shimano 600 Tri-Color FD-6401 front derailleur with 28.6 clamp. Doesn't have to be in mint condition, but can't be trashed/rusted/super fugly. Please be willing to post or send me a few pics.
I have stuff to trade, will buy outright, etc.
Thanks
Thanks
I was planning on sticking them up for sale.
lemme know if your other offer falls through.
pics here https://www.bikeforums.net/g/album/19619948
