4iii 105 R7000 left side crank pic with ruler
Old 05-12-20, 12:12 PM
Froomewannabe
Quoted: 10 Post(s)
Liked 8 Times in 6 Posts
I've got a 2018 Trek Emonda SL5 size 58. Wanting to get the 4iii 105 R7000 175mm left side crank power meter. Its going to be a tight fit. I printed their sizing guide but it is close, anyone have this actual crank with pictures and a ruler they could send, so I could better determine or have this combination with it already working by chance. thanks
Froomewannabe is offline
Old 05-15-20, 04:36 AM
rami_arna
Liked 7 Times in 5 Posts
I have the actual crank but the older 105 5800 series on my emonda ALR and it is a close fit but never had problems. My emonda is the 2018 model of that matters.
rami_arna is offline
Old 05-15-20, 08:00 AM
wirides
Quoted: 17 Post(s)
Liked 23 Times in 12 Posts
I belive they have a paper fit template you can print and cut out to double check for fit. Easy peasy.
wirides is offline
Old 05-15-20, 06:03 PM
Froomewannabe
Quoted: 10 Post(s)
Thanks for the insight.. Mine is also the 5800 series. From Shimano website I can use the 7000 as it is interchangeable. Good to know it worked for you on similar.
Old 05-23-20, 07:20 PM
Froomewannabe
Quoted: 10 Post(s)
Installed today with maybe 1mm to spare.
Likes For Froomewannabe:
Old 05-23-20, 10:39 PM
NoWhammies
NoWhammies's Avatar
Quoted: 694 Post(s)
Liked 329 Times in 216 Posts
Wow! That's a close fit!!
NoWhammies is offline
Old 05-24-20, 08:06 AM
Greiselman
longtime noob
Greiselman's Avatar
Bikes: 2018 Trek Domane SL 6 // 1999 Trek 5000 // Burley Encore X
Quoted: 46 Post(s)
Liked 62 Times in 27 Posts
If it causes any concern, I recently added 2x 0.5mm spacers to give my crank arm power meter a little more clearance. Didn't have any issues.
Greiselman is offline
Likes For Greiselman:
Old 11-25-21, 09:30 AM
dexterPOD
Did you add 2*0.5mm spacers to the left side only or 1*0.5mm to the left and 1*0.5mm to the right side?
dexterPOD is offline
Old 11-25-21, 11:30 AM
Iride01
Hits [ENTER] b4 thinking
Iride01's Avatar
Bikes: '20 Tarmac Disc Comp '91, '78 Raleigh Competition GS
Quoted: 3686 Post(s)
Liked 2,264 Times in 1,585 Posts
If you don't have the extra spindle length sticking out either side of the BB then you can't add spacers. At least not if you want the crank arm's stopper plate to be properly engaged.
I thought 4iiii also said to use a AAA battery to gauge if you will have enough clearance and specified how far out on the crank to be checking with that AAA.
I'm reasonably confident that Dura Ace, Ultegra and 105 pedals of all series (current and recent past back to 2016) have the same clearance on the backside of them as any other in those same series. Profiling on the outside is about all that changes along with materials, weight and maybe the insides.
Iride01 is online now
Old 11-25-21, 05:12 PM
PeteHski
PeteHski's Avatar
Quoted: 1173 Post(s)
Liked 1,240 Times in 798 Posts
I would put a small patch of protection film on the chain stay to prevent any witness marks appearing. Mine has about the same static clearance and it did rub slightly when deflected in anger. I didn't feel it when riding, but it did leave a small scuff on the chain stay.
Edit: Or add a spacer or 2 as suggested earlier
PeteHski is offline
