Mavic Ksyrium Elite
Mavic Ksyrium Elite
Hello, I was going to order Shimano Ultegra RS-500 wheels. However, I learned that the valve stem core on those wheels is not removable. I am now looking at getting a Mavic Ksyrium Elite UST wheelset. I just wanted to double check that these wheels have a removable valve stem core before I buy them. Thanks!
Thread Killer
Bikes: 15 Kinesis Racelight 4S, 76 Motebecane Gran Jubilée, 17 Dedacciai Gladiatore2, 12 Breezer Venturi, 09 Dahon Mariner, 12 Mercier Nano, 95 DeKerf Team SL, 19 Tern Rally, 21 Breezer Doppler Cafe+, 19 T-Lab X3, 91 Serotta CII
Quoted: 3078 Post(s)
Liked 1,631 Times
Valve stems are not something specific to wheels, so should not be a factor in your purchase decision.
Valves, and whether their cores are removable, are either to do with the innertube, or if you’re running tubeless, a totally separate and individually changeable component.
So, even if the Mavic wheels include stems without removeable cores— which they probably don’t— you can easily and inexpensively buy a pair of removeable core valves and use them for your tubeless setup.
Likes For chaadster:
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Buy the Shimano wheels and replace the entire valve with aftermarket valves w/ removeable cores.
Likes For cxwrench:
Bikes: lots
Liked 2,932 Times
My original plan was to get the Ultegra 500 wheels. However, I've read that they don't have the removable core. Some people have said that this makes it harder to install the tubeless sealant. My plan is to run my wheels tubeless. I'd like to learn how to install the sealant myself. For a beginner, how important is having a stem with a removable core in terms of installing tubeless sealant?
Likes For cxwrench:
Thread Killer
Liked 1,631 Times
For what it costs and the ease-of-use, it’s best just to get valve stems with removeable cores from the get-go.
I’d be surprised if any tubeless wheelset shipped with valves with non-removeable cores.
EDIT: As an aside (since you didn’t ask), I’d certainly get the Mavic Ksyrium Elite over the Shimano RS500 not only because they’re both wider internally and lighter, but also because the UST spec is easier to set up tubeless and the Mavics are supplied with good tires included.
Having removeable valve cores is moderately important for a beginner, but not necessary. One can add sealant to the tire before popping on the last section of tire bead. It’s a bit trickier than adding sealant through the valve stem after fully seating the tire, but totally do-able. The big benefit of removeable cores comes when you want to top up sealant, because it’s a lot easier to fill through the stem, which can be done with the wheel on the bike, than it is to remove the wheel and partially unseat the tire.
Likes For AMoney:
