Peugeot PX10 (I think?)
Old 01-04-21, 11:23 AM
Shwuno
Liked 6 Times in 3 Posts
Hi everyone, Iím a complete newbie looking for some advice sorry if Iím breaking any forum rules here!
So Iíve recently purchased this beauty, it was listed as a PX10 but guessing it could be a PFN10 - decals are new so are not helpful and the forks are from another Peugeot so again, not helpful. I bought this as my first project (French bike, ambitious for a first time I know!) but it seems like not much needed restoring on it. So instead I am taking it apart for a full service, polishing up all the relevant bits and upgrading some parts. Hereís what I know...
Mafac racer brakes, levers and cables
Stronglight 49D crankset
Normandy hubs. Mavic700 rims, schwalbe tyres
Simplex front and rear derailleur & shifters (unsure of models?)
aftermarket Japanese seatpost
Atax stem
Maillard Atom pedals I believe?
Peugeot leather saddle
stronglight headset
and hereís what I donít know/am looking to upgrade...
Seatpost to be upgraded with fluted simplex or stronglight (any preference?)
bars - unsure what these are, does anyone know if worth keeping or upgrading?
stem - to be more upgraded to something more fitting with rest of the bike, do simplex or stronglight make stems?
money really isnít a issue here as Iím go to be giving this bike a lot more love than it deserves and it will be a sunny rider only, however I do live in a very hilly place so wondering what peoples thoughts are on a tripiliser?
Maillard atoms?
Peugeot seat
GUID T7
Strong light 49d not sure of simplex parts?
Thanks!
Sean
Shwuno is offline
Likes For Shwuno:
Old 01-04-21, 11:51 AM
rando_couche
Quoted: 225 Post(s)
Liked 159 Times in 105 Posts
Based on the chrome on the rear triangle, it looks like a PX10. Can you share a pic of the frame tubing decal (by the shift levers)?
With the 49d crankset, you can use TA chainrings which will get you down to 26 teeth if you want. No need to mess with a tripleizer.
rando_couche is offline
Likes For rando_couche:
Old 01-04-21, 01:19 PM
Shwuno
the 531 decal? The decals arenít original so not sure if an accurate marker..
ah great thanks re the crankset, Iíll give that a look!
Shwuno is offline
Old 01-04-21, 01:29 PM
bikemig
bikemig's Avatar
Quoted: 5872 Post(s)
Liked 3,427 Times in 2,056 Posts
Yeah that's a PX 10 with a chrome on the rear triangle. That's a very pretty bike. Yeah you don't need a triplizer with that 49d crank. You have a lot of gearing choices with that. For a seatpost, a campagnolo nuovo record 2 bolt is a good alternative.
You will need a special stronglight crank puller.
bikemig is offline
Likes For bikemig:
Old 01-04-21, 01:31 PM
jcb3
jcb3's Avatar
Quoted: 140 Post(s)
Liked 13 Times in 12 Posts
Keep an eye out for long cage simplex RD cages - they can usually be swapped onto your RD to give you extra range
jcb3 is offline
Old 01-04-21, 01:32 PM
Shwuno
Thanks managed to get a suitable crank puller on eBay which proved difficult! Do you have any other suggestions re seat post? I was hoping to keep as many French parts as possible.
Shwuno is offline
Old 01-04-21, 01:33 PM
Shwuno
Interesting - thanks!
Shwuno is offline
Old 01-04-21, 01:47 PM
Pcampeau
Pcampeau's Avatar
Bikes: 1968 Raleigh Super Course. 1972 Raleigh Professional, 1975 Raleigh International, 1978 Raleigh Professional, 1985 Raleigh Prestige, 1972 Schwinn Paramount, 1980 Schwinn Voyageur 11.8, 1960 Carlton Franco Suisse Peugeot PX10, 1972 Motobecane Le Champ
Quoted: 317 Post(s)
Liked 663 Times in 343 Posts
Very nice bike! It looks quite a bit like my 74 French market PX10. You seem to be aware that some of the parts have been swapped out but what you have will make a plenty nice ride. Seat post on mine is Laprade.
Pcampeau is offline
Likes For Pcampeau:
Old 01-04-21, 02:45 PM
bikemig
bikemig's Avatar
I'm going to use a campy 2 bolt seatpost on my Mercier 300. The campy seatpost will likely cost you less than a simplex and it is a very strong design. But if you want to to tout French, I understand. Also you can run, if you wish, a 22.2 stem but you may have to sand it down to fit.
Simplex rear derailleurs often have a pretty decent chain capacity and can handle a decent sized max cog. I'm running a 13-30 freewheel on my PXN 10 with a simplex rear derailleur. The gearing choices for a French vintage bike tend to be pretty good.
bikemig is offline
Old 01-04-21, 03:21 PM
dddd
Ride, Wrench, Swap, Race
dddd's Avatar
Quoted: 1547 Post(s)
Liked 1,255 Times in 835 Posts
Looks like a 1973/74 model PX10LE, which means it has super-steep frame angles in excess of 75 degrees.
This bike will make for a very spirited ride and is best for aggressive riding and climbing with the rider perhaps jumping out of the saddle with some regularity to sprint (accelerate) or to "attack" steep switchback turns going uphill.
The steering will always be extremely light and responsive, but may have enough stability for you if the headset bearings are completely free-turning and if the stem extension is 10cm or greater (more length here puts more weight on the front tire, and also positions body weight better with respect to the steering axis for greater steering stability. This will always be an exceptionally-quick steering bike however, and steering stability will suffer further with any raising of the handlebar height.
Your rear derailer appears to have it's top sprung pivot fully de-tensioned. These derailers are NOT to be removed by turning the chromed hex socket on the mounting bolt(!), actually the bolt is un-threaded but for a smaller screw that threads into the other end of the mounting bolt behind the dropout (and facing the opposite direction). Likely someone has forcefully turned the mounting bolt and sheared it's positioning out of the stop plate on the reverse side of the top pivot (sorry for this bit of bad news). Sometimes the situation can be remedied by turning the chromed mounting bolt clockwise and then tightening the small screw on the other end of the mounting bolt (accessed with the rear wheel removed). The spring may thus be re-tensioned enough so that the top pulley clears the largest freewheel sprocket by 1/4" when the chain is on the small chainring.
The PX10LE's rear derailer was I believe NOT the vaunted LJ model but was the almost equally hard to find model SX610 (as stamped into the outer parallel link's "tin" cover). Hopefully this one can be restored, it may take disassembly and some "peening" around the hole in the stop plate to restore it's solid rotational engagement with the mounting bolt (see photo below of a round hole with it's flat restored by peening with a sharp punch).
Below is a picture of a similar Campagnolo stop plate with the hole having become stripped round, but with the flat having been restored (your derailer's stop plate should I believe have two flats along the stripped hole instead of just one).
After restoration of the stop plate, the mounting bolt would be rotated into spring tension before the stop plate is pressed back on and the tensioned assembly carefully re-installed onto the dropout without releasing the press-fit and the spring tension. The positioning of the derailer body could then be fine-tuned by adjusting the cage pivot with it's external hex nut and hex socket. Yes this all requires some investigation and perseverance, but ultimately is not hard to do.
dddd is offline
Old 01-04-21, 03:45 PM
unworthy1
Stop reading my posts!
unworthy1's Avatar
Quoted: 1399 Post(s)
Liked 1,013 Times in 754 Posts
you get major "OMG points" for working on any bike (even one this clean) on an off-white carpet!
unworthy1 is offline
Likes For unworthy1:
Old 01-04-21, 03:59 PM
bikemig
bikemig's Avatar
The OP may be single . . . . Just sayin.
bikemig is offline
Likes For bikemig:
Old 01-04-21, 04:49 PM
rjhammett
rjhammett's Avatar
Bikes: 85 De Rosa, 92 Merckx MX Leader, 99 Tommasini Sintesi, 08 Look 585, 89 Merckx Corsa Extra, 72 Holdsworth Professional
Quoted: 358 Post(s)
Liked 537 Times in 236 Posts
It's a UX-10. UX-10 were a PX-10 with clincher wheels. The fork is slightly different from a PX-10. I sold this one this past summer.
rjhammett is offline
Likes For rjhammett:
Old 01-04-21, 05:41 PM
unworthy1
unworthy1's Avatar
If there was nothing but a drum kit in that music room, then...case closed!
(I'm allowed drummer and bachelor jokes!)
Old 01-04-21, 05:57 PM
KenNC
KenNC's Avatar
Quoted: 68 Post(s)
Liked 114 Times in 63 Posts
Nice looking bike with an interesting set of components. It would be great if your clincher rims had an inner lip that retains higher pressure tires, with or without wire beads. I recently re-did a PRN10 (lesser frame) of about the same era, and by stroke of good luck it had clincher rims that included an inner lip. Here's the thread: https://www.bikeforums.net/classic-v...-e-rescue.html Also you will see on my thread a discussion of the rear derailleur, how the tension looked too weak and the parallelogram body was pulled too far forward, and how that was resolved--not saying you have a problem but you may want to check it out. Again, nice bike and good luck with it!
KenNC is offline
Old 01-05-21, 12:46 AM
Shwuno
Sheís a beauty!
Shwuno is offline
Old 01-05-21, 12:47 AM
Shwuno
Thanks thatís useful to know, looks like a bit of experimentation on the gearing is in order
Shwuno is offline
Old 01-05-21, 12:49 AM
Shwuno
hahah yeah risky one I know, but this is ďmyĒ lounge after all
Shwuno is offline
Old 01-05-21, 12:54 AM
Shwuno
Ďthanks so much for this, I knew there was something wrong with the RD but hadnít yet removed for inspection. I suspect I would have been clueless! Still might be past my knowledge but hopefully I can work it out based on this information. If not, not sure what Iíll do!
Shwuno is offline
Old 01-05-21, 12:56 AM
Shwuno
ah ok thanks but these forks arenít from the original bike, annoyingly! I donít mind too much what this actually is just trying to figure it out so I can attempt the impossible and source some correct forks...
Shwuno is offline
Old 01-05-21, 12:58 AM
Shwuno
thanks so much - this forum is amazing! Learning lots and will definitely take some tips from your thread.
Shwuno is offline
