Garmin Edge Explore Unboxed, now what?
Old 06-02-21, 01:23 PM
dhender02
dhender02's Avatar
Bikes: Felt Z85 & Trek 7.3FX
Quoted: 38 Post(s)
Liked 8 Times in 7 Posts
I did a Garmin Edge Explore GPS unboxing, however, the old man still has questions. When I tried to used route navigation, I’m not getting audio directions, nor do I hear a signal when I need to turn. If I stopped riding briefly (potty break, water break, etc), I always get a message, “…the current language is not supported by your phone…” I always have to hit the check mark to continue, can I prevent this from happening? Also can I add a time of day to map page when riding? Any thoughts/suggestions are greatly appreciated.
dhender02 is offline
Old 06-02-21, 01:24 PM
Steve B.
Quoted: 3142 Post(s)
Liked 1,971 Times in 1,127 Posts
What is this ?
Steve B. is offline
Old 06-02-21, 01:25 PM
dhender02
dhender02's Avatar
Quoted: 38 Post(s)
Old 06-02-21, 01:26 PM
dhender02
dhender02's Avatar
Quoted: 38 Post(s)
Originally Posted by Steve B.
What is this ?
First time posting video, I hit submit before I got to post text... I did a Garmin Edge Explore GPS unboxing, however, the old man still has questions. When I tried to used route navigation, I’m not getting audio directions, nor do I hear a signal when I need to turn. If I stopped riding briefly (potty break, water break, etc), I always get a message, “…the current language is not supported by your phone…” I always have to hit the check mark to continue, can I prevent this from happening? Also can I add a time of day to map page when riding? Any thoughts/suggestions are greatly appreciated.
Old 06-02-21, 01:33 PM
WhyFi
WhyFi's Avatar
Quoted: 20791 Post(s)
Liked 9,435 Times in 4,663 Posts
So, if I understand you right, you did a Garmin Edge Explore GPS unboxing, but you still have some questions?
WhyFi is offline
Likes For WhyFi:
Old 06-02-21, 01:37 PM
WhyFi
WhyFi's Avatar
Okay, not sure if it's the same on all Garmin devices, but on my 530, for audible TbT directions, I need to have some blue tooth earbuds connected to my phone and my phone connected to the Garmin. I've also found that, if I turn off my earbuds after I've started a route, my phone speaker will take over with announcing the turns. Not sure if this is a feature or a bug, or if there's an official way to get the phone's speaker to announce.
WhyFi is offline
Old 06-02-21, 01:38 PM
Steve B.
The device should beep for your turn by turn (if the Explore has beep). You might be able to get voice commands via BlueTooth to a phone, means you have to have the phone where you can hear it, or cobble together some BT headphones as well, Ive never done this,
Steve B. is offline
Old 06-02-21, 02:09 PM
dhender02
dhender02's Avatar
Quoted: 38 Post(s)
Yep... No instructions, so how do I get audio on navigation?
Old 06-02-21, 02:11 PM
dhender02
dhender02's Avatar
Quoted: 38 Post(s)
Do I need to turn any setting on? I used to ride with the Strava app on my phone, I had no problems hearing the direction with my phone's speaker, so it's not an phone issue. I don't think the audio navigation prompts are happening...
Old 06-02-21, 02:14 PM
dhender02
dhender02's Avatar
Quoted: 38 Post(s)
I normally keep my phone in my jersey back pocket. When I used the Strava app on my phone I hear the prompts fine from the back pocket. The Garmin is syncing with my phone, because text messages appears on my Garmin if I receive one while riding. When I finish my ride, it's goes to Strava immediately.. I think I'm missing a setting or something...
Old 06-02-21, 02:15 PM
dhender02
dhender02's Avatar
Quoted: 38 Post(s)
Correct. Voice audio prompts and I keep getting an error message about language not supported....
Old 06-02-21, 02:23 PM
redcon1
redcon1's Avatar
Bikes: Focus Arriba, Specialized Roubaix Expert, Bianchi Impulso Allroad
Quoted: 109 Post(s)
Liked 82 Times in 53 Posts
You need to have it connected via the Gamin Connect App to your phone. My Edge Explore works though the setting in Connect on my phone using: Activity Options - Audio Prompts - Navigation Alerts "on"
This should work via BT headphones or thru the phone's speaker. If you are getting a language message you must not have updated the language files on the Edge?
As for the display screens, you can add up to 2 data fields (including time of day) to the map screen. Do a Google or YouTube search for Gamin Edge Explore and it should held quite a bit in setting up and using the device.
redcon1 is offline
Old 06-02-21, 02:33 PM
njkayaker
Quoted: 4211 Post(s)
Liked 1,302 Times in 903 Posts
The error message shows up where?
What phone are you using?
I don't think the language setting for the Explore matters but you should verify that it's English.
njkayaker is online now
Old 06-02-21, 02:41 PM
dhender02
dhender02's Avatar
Quoted: 38 Post(s)
If I stop for over 2 minutes or so, the screen goes to sleep. When I start back up, I get a message on my screen that says “…the current language is not supported by your phone…” with the green check mark underneath. I just hit green check board, the continues on to the screen I was on when I stopped...
Old 06-02-21, 02:42 PM
dhender02
dhender02's Avatar
Quoted: 38 Post(s)
Thanks, I give this try later this evening!!!
dhender02
dhender02's Avatar
Quoted: 38 Post(s)
Google Pixel 4..
Old 06-03-21, 04:37 PM
philbob57
Quoted: 712 Post(s)
Liked 601 Times in 370 Posts
Does Garmin provide support?
philbob57 is offline
Old 06-03-21, 05:29 PM
shelbyfv
Expired Member
shelbyfv's Avatar
Quoted: 3626 Post(s)
Liked 5,286 Times in 2,685 Posts
https://www8.garmin.com/manuals/webh...0_OM_EN-US.pdf
shelbyfv is offline
Old 06-03-21, 06:30 PM
Steve B.
So basically you just purchased a technically complicated $250 computer and will now be using this forum and post as an on-line tutorial ?. Thats kind of tiring. The expression we use at work is ""RTFM", with Read The Manual being 3 of those words.
Steve B. is offline
Old 06-03-21, 07:07 PM
dhender02
dhender02's Avatar
Quoted: 38 Post(s)
Interesting comment, especially when I said instructions weren't in the manual. As usual, the community here in bike forums never siezes to help. Thank you for your helpful insight.
Old 06-03-21, 07:17 PM
Troul
Troul's Avatar
Liked 2,881 Times in 1,863 Posts
-Oh Hey!
Troul is offline
Likes For Troul:
Old 06-03-21, 07:18 PM
njkayaker
I wonder if the issue is with the phone. It seems it stops running Connect.
I tried the voice announcements with a 1030+ on an iPhone and it worked without any problems.
Old 06-03-21, 07:20 PM
dhender02
dhender02's Avatar
Quoted: 38 Post(s)
Thanks TROUL for the link, PERFECT!!
Old 06-03-21, 07:21 PM
dhender02
dhender02's Avatar
Quoted: 38 Post(s)
When I did a Google search on the error message others have the same problem however I didn't see a fix for it...
Old 06-03-21, 07:24 PM
Troul
Troul's Avatar
I think pdf page 4 is what you're after.
-Oh Hey!
Troul is offline
