Converting from 700c to 650b
Old 08-13-18, 06:57 PM
hokicake
hokicake's Avatar
Quoted: 17 Post(s)
So I just got a aero frame road bike in the smallest size avail and the top tube still touching my privates but at least I can stand over it but I would like a like some clearance so I'm gonna put on 650b tires to drop the frame a little bit. I just got some mavic wheels in the mail and got some 27.5 x 1.5 tires so I'm hoping it'll fit cause I'm just playing it by ear. The main concern I'm having is the brakes cause the ones I have on there now are very short arm ones so I'm wondering what size do I need to reach if I can even do that cause these wheels I got just say disk brake wheels and I donno if I can use pads on those rims but they say they are s6000 double wall aluminum so shouldn't that be strong enough? I might be able to put on disk brakes and I already ordered all the disk brake hardware for it in case I wanna do that but the thing is the bike doesn't have the built in holes to mount the stuff so I ordered disk brake adapters that clamp onto the frame and spindle thingy to provide the two holes but I wasn't sure about that cause I was reading where people have said it might bend the frame cause the frame isn't ment to support that force or something so I was thinking should I just put on long arm brakes to do a rim brake even if the rim doesn't specifically say it can do that cause it's not like I'm going to be doing some serious speed and hard stops anyways and I would think if braking is done on both wheels it's not like one side is getting all the force anyways and I feel same thing can be said about the disk brake adapters too. So what should I do? I'm so confused.
hokicake is offline
Old 08-13-18, 08:34 PM
JonathanGennick
JonathanGennick's Avatar
Bikes: Priority 600, Priority Continuum, Devinci Dexter
Quoted: 685 Post(s)
Liked 55 Times in 37 Posts
What you are talking about doing does not seem safe. I would not use adapters to force disk brake calipers onto a frame and fork not designed for them, nor would I run rim brakes on a wheelset without a braking track.
JonathanGennick is offline
Old 08-13-18, 08:52 PM
DanBraden
Often on Fritz
DanBraden's Avatar
Bikes: Franken-Fritz, Horse-Feathers, Junker
Quoted: 117 Post(s)
I really wish I could help, I do!
But since I can't, allow me to express my feelings in an image.
How I felt after reading the post
DanBraden is offline
Old 08-13-18, 08:54 PM
ThermionicScott
working on my sandal tan
ThermionicScott's Avatar
Quoted: 3681 Post(s)
Liked 2,156 Times in 1,362 Posts
Long reach caliper brakes should do the job just fine. Check out Tektro R559s.
Originally Posted by noglider
RUSA #7498
ThermionicScott is offline
Old 08-14-18, 12:04 AM
hokicake
hokicake's Avatar
Quoted: 17 Post(s)
Yayyyy
Already ordered. Wellll what us a track anyways cause on my stock wheels i dont see a track its just the side of the rim. I know some rims have a noticeable track but i dont think all do.
hokicake is offline
Old 08-14-18, 10:57 AM
Elvo
Quoted: 621 Post(s)
Liked 357 Times in 196 Posts
People convert to 650B all the time, especially to run Road Plus tires like WTB Horizons and WTB Byways. However, you will need a bit of tyre clearance to run anything larger than 1.2" which is not very likely on an aero bike.
Elvo is offline
Old 08-14-18, 11:20 AM
Wildwood
Veteran, Pacifist
Wildwood's Avatar
Quoted: 3361 Post(s)
Liked 3,247 Times in 1,587 Posts
So I just got a aero frame road bike in the smallest size avail and the top tube still touching my privates but at least I can stand over it but I would like a like some clearance so I'm gonna put on 650b tires to drop the frame a little bit. I just got some mavic wheels in the mail and got some 27.5 x 1.5 tires so I'm hoping it'll fit cause I'm just playing it by ear. The main concern I'm having......
After you sort out brakes, sort out the rim size and tires. 650b rims will not fit 27 1/2 tires. Conversely, 27 1/2 rims will not fit 650b tires.
Wildwood is offline
Old 08-15-18, 11:53 AM
JanMM
rebmeM roineS
JanMM's Avatar
Quoted: 646 Post(s)
Liked 331 Times in 215 Posts
can you post a pic of the wheel sidewall? Now that you have 10 posts.
I'm using a double pivot caliper rim brake on a rear wheel with a disc hub and non-machined sidewalls. Works fine. But, if your rims' sidewalls do not have flat surfaces suitable for braking, you may be out of luck on rim braking with your new wheels.
Disk brake adapters might do the job for you but that's not a sure thing.
JanMM is offline
Old 08-15-18, 12:33 PM
ksryder
Bikes: yes
Quoted: 1281 Post(s)
Liked 641 Times in 328 Posts
BWAHAHAHAHAHAHAHAAHAHAHAHAHAHA ok.
ksryder is offline
Old 08-15-18, 07:02 PM
hokicake
hokicake's Avatar
Quoted: 17 Post(s)
My veel
i actually think i can do a good rim job with this cause its flat
hokicake is offline
Old 08-15-18, 07:08 PM
hokicake
hokicake's Avatar
Quoted: 17 Post(s)
Buuuuuuuuuuuuut I'm having one issue. So I went to put the rims on the bike and both rims fit but this tire I got which you see in the pics it's 27.5 x 1.5 and rubs the dies of the folk by a hair so I'll need to find a thinner tire so I need to know what kind AND so I put the tire on the rear wheel to see how it fits there but it's totally to far off center so the tire is really rubbing against the one side witch a big gap on the other side from the frame. So I reckon it has something to do with the axle thingy so I been mucking with it and I see one side were the poky turny thingy goes has a weird screwy thingy and the other side has a washer and a nut so what I did was I took out the washer from the other side and put it on the opposite side where it was to close to the frame so I'm thinking maybe that will center it better. I'm so confused.
hokicake is offline
Old 08-15-18, 11:02 PM
DanBraden
Often on Fritz
DanBraden's Avatar
Quoted: 117 Post(s)
Rim job?
Really???
I mean there are matzo balls then there are MATZO BALLS... oy vey!
Old 08-15-18, 11:13 PM
hokicake
hokicake's Avatar
Quoted: 17 Post(s)
Wha
Huh? I could use some advice
hokicake is offline
Old 08-15-18, 11:22 PM
Elvo
Quoted: 621 Post(s)
Go to a bike shop and have them take a look at it. My guess is the wheel is too big for your frame as it is probably 142x12mm thru axle or 135mm QR while your frame spacing is 130mm. A 1.5" tyre is 38mm which is too big for most road frames. And you will need to install disc brakes and rotors to use that wheel as it is not designed for rim brakes.
What bike are you installing it on?
Elvo is offline
Old 08-15-18, 11:28 PM
hokicake
hokicake's Avatar
Quoted: 17 Post(s)
hokicake is offline
Old 08-15-18, 11:42 PM
Elvo
Quoted: 621 Post(s)
No idea what bike that is but it doesn't look like a typical bike designed for 650B, disc brakes, or wide tyres. I would recommend returning the bike and the Mavic wheelset and buying a bike that fits. Something like this might be a good start:
https://www.bikenashbar.com/cycling/...try-drop-yb-sd
But your best bet is to go to a shop and get fitted
Elvo is offline
Old 08-15-18, 11:48 PM
hokicake
hokicake's Avatar
Quoted: 17 Post(s)
I ordered it from china! Im not sending it back. I orderes the wheels from Taiwan! Not happening. It fits ok but i just wanted the frame a bit lower.m so just trying some stuff. I already tried the new wheels on it and they fit fine the only issue is that particular tire being 1.5 is just a hair to fat for the front forks it will spin but theres a slight rub so i think i can find a slighty narrower one that will work and when i put it on the rear it fits and looks like itll be good there except for the wheel itself being not centered so imma try to adjust the axle to make the wheel move the the right a few mm
hokicake is offline
Old 08-15-18, 11:58 PM
Elvo
Quoted: 621 Post(s)
Those Mavic Crossride wheels are not designed for rim brakes. I doubt your current brakes can even reach the sidewall of the 650B rim. It is NOT SAFE to ride your bike with those wheels, especially if they don't even fit in the first place. Good luck.
Elvo is offline
Old 08-16-18, 04:10 AM
hokicake
hokicake's Avatar
Quoted: 17 Post(s)
I just got long reach brakes in the mail
hokicake is offline
Old 08-16-18, 09:09 AM
hokicake
hokicake's Avatar
Quoted: 17 Post(s)
hokicake is offline
Old 08-16-18, 09:12 AM
ksryder
Bikes: yes
Between the "I want advice but I'm not actually going to listen to it" and the guy who thinks that 27.5 and 650b aren't the same thing, this thread delivers!
ksryder is offline
Old 08-16-18, 09:13 AM
Rock71
Bikes: Fuji Gran Fondo 2.1 and Scott Sportster P45
Quoted: 81 Post(s)
Originally Posted by DanBraden View Post
Rim job?
Really???
Glad I wasn't the only one wondering WTF, when I read that.... LOLOLOL
Rock71 is offline
Old 08-16-18, 09:24 AM
hokicake
hokicake's Avatar
Quoted: 17 Post(s)
The long reaches fits!!
i think im doing it!! Just gotta wait to get my innertube. Its just a tire with not tube for now
hokicake is offline
Old 08-16-18, 09:31 AM
hokicake
hokicake's Avatar
Quoted: 17 Post(s)
See the diff size
front 700c. Rear 650b
hokicake is offline
Old 08-16-18, 09:43 AM
mrv
BIKE RIDE
mrv's Avatar
Bikes: my very own customized GUNNAR CrossHairs
Quoted: 403 Post(s)
Liked 213 Times in 141 Posts
lots people like the bars higher for more upright comfort. you are definitely on something!
mrv is offline
