FSA megaexo BB - what thread do they use?
Old 07-09-22, 03:22 AM
alexk_il
Quoted: 142 Post(s)
Liked 34 Times in 26 Posts
Need to change FSA Megaexo BB (I think that's what I have) to square tapered JIS.
Do I simply remove old BB and install the new one or is it more complicated? I know square JIS use English thread but can't find info about the FSA, do they use the shame?
alexk_il is offline
Old 07-09-22, 06:14 AM
dedhed
SE Wis
dedhed's Avatar
Quoted: 2738 Post(s)
Liked 3,380 Times in 2,045 Posts
BB threads are based on what the frame is threaded for. Bottom bracket shells have been threaded in English (BSA), French, Italian, and Swiss threads over the years.
Most threaded BB built since say the mid 90's are English threaded (1.37" X 24) with a smattering of Italian.
The spindle length of your new BB will be determined by whatever new crankset you are installing on it.
dedhed is online now
Likes For dedhed:
Old 07-09-22, 09:15 AM
cxwrench
cxwrench's Avatar
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times in 1,489 Posts
As dedhed posted it has nothing to do w/ the brand of bottom bracket, it has everything to do w/ the frame and how it is threaded.
cxwrench is offline
Old 07-09-22, 09:37 AM
Iride01
Iride01's Avatar
Quoted: 6163 Post(s)
Liked 4,781 Times in 3,299 Posts
I think the FSA MegaEXO is for two piece cranksets with a 24mm spindle. No JIS or any square taper involved. If you are in the market for a new crank and BB, then in most cases I'd recommend you get a 2 piece crank.
What crank do you have or what crank are you intending to put on it. Get the part number off the backside of the crankarm if there is one.
Iride01 is online now
Old 07-09-22, 09:40 AM
deacon mark
Bikes: Habanero Titanium Team Nuevo
Quoted: 399 Post(s)
Liked 185 Times in 121 Posts
I had a nice FSA mega expo on my Wilier from 2013. I finally decide to upgrade got a Shimano r7000 but still have the 10 speed Ultegra 6700 groupset. These cranks are way better and spin much better. You have a BSA threaded BB so get an R7000 11 spd crank and a Shimano BBR60 Bottom Braket for that crank. The crank will run 10 spd components and it will spin much better. It probably will cost you about $210 to do this but well worth the money and easy to swap out.
deacon mark is offline
Old 07-09-22, 10:21 AM
Rolla
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times in 1,439 Posts
MegaExo is also available with a 19mm spindle bore, but I assume that the OP is replacing the whole crank/BB with a square taper.
Rolla is offline
Old 07-09-22, 02:19 PM
alcjphil
alcjphil's Avatar
Quoted: 1813 Post(s)
Liked 1,692 Times in 973 Posts
JIS bottom brackets do not necessarily have to use English threading. In all likelihood your frame is English threaded, but there is no way for us to know that without details about your actual frame and perhaps why you have to change the bottom bracket which will also require a new crank
alcjphil is offline
Old 07-09-22, 04:34 PM
alexk_il
Quoted: 142 Post(s)
Changing the stock components to Sugino JIS cranks on the front and M8000 cassette, derailleur and shifters on the back. Probably costs more than $210 all together.
alexk_il is offline
Old 07-09-22, 04:39 PM
alexk_il
Quoted: 142 Post(s)
Boardman Hybrid bike, roughly 2011-2014 in relatively mint condition. The frame has different BBs depending on the year, some were built with BB30, some with PF30 and some with FSA megaexo. Will use Sugino 42/26 JIS instead of the original FSA compact 50/34.
alexk_il is offline
Old 07-09-22, 04:40 PM
alexk_il
Quoted: 142 Post(s)
Will use Sugino 42/26 JIS instead of the original FSA compact 50/34. If my bike has English thread, then will use Tange 3922 BB.
alexk_il is offline
Old 07-10-22, 09:22 AM
Hondo6
Bikes: Yes
Quoted: 549 Post(s)
Liked 665 Times in 462 Posts
Might want to hold off ordering anything else until you determine what type of BB shell you have. FSA's website says that their MegaExo bottom brackets were made in English thread (various lengths), Italian thread, and "several press-fit bottom bracket standards" versions. If I recall correctly, BB30 and PF30 are two different press-fit bottom bracket standards.
https://www.fullspeedahead.com/en/technology
I'd recommend determining with certainty which BB shell you have before proceeding further.
Hondo6 is offline
Old 07-10-22, 09:31 AM
Iride01
Iride01's Avatar
If you take the bike by a bike shop when it's slow, you can probably engage the mechanic in a lengthy conversation about your bike and cycling and get all kinds of information about what you might have on your bike. Mechanics and shops owner's at LBS around me will talk your head off once you get them going. And all for FREE!
Old 07-16-22, 04:33 PM
alexk_il
Quoted: 142 Post(s)
And the answer is...
FSA Mega Exo uses English thread. Removing the FSA and replacing it with square tapered BB was a straightforward task on my bike.
alexk_il is offline
Old 07-16-22, 05:38 PM
Rolla
Guest
Originally Posted by alexk_il;[url=tel:22576846
22576846[/url]]FSA Mega Exo uses English thread. Removing the FSA and replacing it with square tapered BB was a straightforward task on my bike.
MegaExo BBS also come in Italian threading. While it’s unlikely that that’s what the OP has, it’s worth confirming.
Rolla is offline
Old 07-16-22, 05:49 PM
alexk_il
Quoted: 142 Post(s)
I am the OP, so I can confirm that the bike in question came with English thread. Not surprising for a bike designed and built in the UK.
alexk_il is offline
Likes For alexk_il:
