Oiling the bike
Forum Moderator
Quoted: 3090 Post(s)
Liked 6,593 Times
No.
Veggie oils create problems without benefits. They are likely to gum up and will attract dirt. Beyond that, you'll find viscosity, oxidation, and low temperature issues. For the most, veggie oils are the go-to lube in situations where mineral oils may contaminate.
On a bike, I'd only use it to put on grips - although I prefer alcohol. And, BTW, not the drinking kind.
Pennylane Splitter
Bikes: Yes
Quoted: 1796 Post(s)
Liked 1,439 Times
Try Oil of Olay. It'll keep your chain running smooth and make it look younger than it really is, and make all the other trolls jealous of your pretty bike. (Some pink streamers at the end of the handlebars would look nice, too!).
aren't ya oil being a bit tough on da guy?
friends of mine many many moons ago tried some cooking oil as chain lube and it caused a great mess, super hard to clean off. Doesn't seem to be worth it.
I have found myself having to use 3-in-1 oil on two separate occasions during the last 20 years. Once was on a tour in South Texas. Once was in Ireland. It's a friggin' mess to use anything other than dedicated chain lube. Other oils will get you home, but its pretty nasty.
Quoted: 671 Post(s)
Liked 49 Times
Some mechanics say chain cleanliness is more important than lube type, even water can reduce friction a lot. Vegetable oil is not optimal but OTOH pretty easy to wash away with detergent/degreaser.
Quoted: 18410 Post(s)
Liked 15,530 Times
Let's turn this into a best chain lube thread. I'll start: NFS is the best lube.
