scraping paint
Quoted: 339 Post(s)
Liked 632 Times
scraping paint
People spend lots of time removing paint from their bicycle frames to paint them. I thought I would pass on a tip .
I scraped this paint off a Richey frame using the disposable utility knife shown that you can buy for a dollar at many big box hardware stores. What you see took about 15 minutes or less. Using this method you can remove maybe 80% of the frame paint in a couple hours, then using a electric vibrating or orbital sander, remove almost all the remaining paint except the lugs in another hour. The lugs will need stripper or, in my case, a small home sand blast kit. This is a lot faster and less messy than using stripper or sand blasting on the the whole frame. I have done it on three bikes so far and am sold on the method.
Quoted: 472 Post(s)
Liked 1,028 Times
Agreed, for some cases. My very fine '74 Gitane Gypsy Sport had some odd purple paint that was still soft. Stripper was a messy fail so I scrapped most of it off. Not hard at all. I've also had good luck making scrapers out of steel banding material, like what secures pallets of lumber or bricks or pipe. Higher carbon steel than normal and holds an edge fairly well. You can sharpen it with a file and easily vary how sharp it is. I've not tried rolling an edge on it yet. No need.
I'll guess that scraping may not work well on some paints though. Can't hoit to try, eh?
When I painted frames for Rocky Mtn. I used a three sided knife like this....
The rigid point allows you to scrape in some pretty tight spaces.
Quoted: 887 Post(s)
Liked 335 Times
I just use wettable sand paper to get the tube paint off, and then dental picks and such for detail areas. It doesn't take very long and causes no fumes or dust. Doubt it would well on Imron though. I haven't done it in a while - I have reconsiled with patina.
Edumacator
Quoted: 2436 Post(s)
Liked 3,119 Times
Does it double as a potato peeler? Seriously, though, where does one get one of these?
Haven't wielded one of those in over twenty year. But now that I've sourced one, I want one! lol...
Would this method be safe for aluminum frames too?
Also depends on product your removing. If it's powdercoated just fuggedaboutit and use copious amounts of paint stripper. And be cautious media blasting aluminium. I think most brands tell you it'll void your warrenty but after chemical stripping, scraping, and soft wire brushing I would lightly media blast the frame to blow out any crud or specks that would show up under a coat of paint. Of course I could sand out the primer coat if needed but time money yada yada.....
Bikes: Drysdale/Gitane/Zeus/Masi/Falcon/Palo Alto/Raleigh/Legnano
Quoted: 981 Post(s)
Liked 631 Times
That said, I'm still all in for chemicals, but whoever suggested a wooden roux spoon to get loosened paint off a frame... thank you!
Larry:1958 Drysdale, 1961 Gitane Gran Sport, 1974 Zeus track, 1988 Masi Gran Corsa, 1974 Falcon, 1980 Palo Alto, 1973 Raleigh Gran Sport, 1974 Legnano. Susan: 1976 Windsor Profesional.
Quoted: 981 Post(s)
Liked 631 Times
Ideally, we need to be able to teleport the frame to one place, and the paint finish to another. "Energize, Scotty!"
Passista
Bikes: 1998 Pinarello Asolo, 1992 KHS Montaņa pro, 1980 Raleigh DL-1, IGH Hybrid, IGH Utility
Quoted: 866 Post(s)
Liked 721 Times
I make my own scrapers from old hacksaw blades. For the handle, just wrap an old rag on it. Recycler or cheapskate? 😄
Bikes: Yes
Quoted: 3230 Post(s)
Liked 3,868 Times
It's super simple for paint over chrome, such is in the example above. For paint that's well bonded to the surface, I find that pre-sanding before applying the stripper helps. For areas where the paint doesn't cooperate as well as in the pic above, the stripper still softens it substantially so that I can get most of it off with a putty knife (which is what I actually use for the easy spots too). This generally gets me 90% of the way to the finish line. For the main tubes, a belt sander strip makes for easy work. For the crevices I start with a wire brush attachment on a drill. If I want to be super thorough, a smaller wire brush on a Dremel tool will clean up the smallest of spaces.
That said, the wire brush step is very messy and your point about flying stripper at this point is well taken. It's probably mostly gone by then with my typical technique, but it's definitely something I'll pay attention to next time.
My Bikes
My Bikes
Mother Nature's Son
Quoted: 852 Post(s)
Liked 1,433 Times
I finished stripping a 1989 Fuji Ace a couple of weeks ago. I did what worked for me on the other two framesets I did: chemical stripper and let stand overnight in a garbage bag. Next day used a scraper and a utility knife to remove the broken down paint and pressure washed it to get the rest off. I do not have any idea what paint was used, but it was very difficult to strip. I had to give up on the utility knife as it would get hung up and scrape/scratch the steel too much. I still had to use a good bit of sandpaper and manual labor to get the frameset to bare metal, and then to get it smoothed out. The other framesets I stripped were much easier and less time consuming. The Fuji is Ishiwata steel, the Ochsner is Columbus Aelle, and the Lemond Tourmalet is Reynolds 853. I have no idea if the grade of steel makes a difference, or if it is just whatever paint/process was used. I put the final coat of rattle can spray paint on the frame yesterday. My first time painting a bike and I think it came out pretty good, better than I was expecting. No pictures yet.
